Make elf file from hex and fuse bits in command line?
9 posts / 0 new
Hi. I have an hex file(combined of Bootloader and main program), and fuse bits. I want to make ELF file,for fast production. Is there any way to make ELF from HEX and FUSE bits in command line? I know there is a GUI tool in atmel studio(Device Programming-> Production file) but i need command line. Is there any way?
The command line too you want is called "objcopy", and for AVRs often specifically "avr-objcopy".
It can take an ELF file as input and extract parts of it to Intel hex format.
The exact options to feed it to have id do what you want depends to a large extent to exactly what you want to do and what your ELF file contains. No one-stop cook-book advice is possible.
The general look of an objcopy command line is
avr-obcopy -O output-format [-j section-to include]... [-R section-to-remove]... input-file output-file
but there are more options availiable that thjese basic ones shown above.
If you are familiar with GNU Make and makefiles then you could look at some makefiles targeting the avr-gcc toolchain to see how it is done there.
Here are rough examples adapted from a makefile I often use. First, create a hex file for flash (by simply removing the EEPROM section (assuming that the ELF only contains flash- and EEPROM-destined content):
avr-objcopy -O ihex -R .eeprom filename.elf filename.hex
And then an example creating a file with EEPROM contents (by explicitly including the .eeprom section of the ELF, and also demonstrating more options - here "rebasing" the .eeprom addresses to start at zero):
avr-objcopy -j .eeprom --set-section-flags .eeprom=alloc,load --change-section-lma .eeprom=0 -O ihex filename.elf filename.eep
You could also have a look at the build output from Studio - it engages objcopy as one of it's last steps in a build.
Documentation for GNU objcopy is here.
But OP is asking to do the opposite:
sabuniver5 wrote:
I have an hex file ...  I want to make ELF file,for fast production.
But that makes no sense - how would having an ELF file help production??
It is usually the HEX file that made for production!
Doh! Sorry for the confusion.
While you can convert hex back to elf why didn't you just have the original build put it all together in an ELF?
Because the ELF would come to the production point as one monolithic file rather than a set of files for the different memories.
There's certainly programming software that uses, or can use, the ELF file as the sole source for programming different memories. Look no further than Atmel Studio..
Ah, I think it's my turn to mis-read the OP - I thought it said the Hex file was all "combined" - but perhaps not ...
how to merge elf and eep file and generate elf file by using command prompt
Varun
Please do NOT cross post - you have a thread about that here: https://www.avrfreaks.net/forum/... already.
