Code to Configure timer and generate interrupt
5 posts / 0 new
Hello All,
I am using SAME54 Xplained Pro Evaluation kit. I want example code to configure timer using registers which are available under "Atmel\Studio\7.0\packs\atmel\SAME54_DFP\1.0.67\include\instance\tc.h" file.
I am new to this controller so any example code to configure the timer using registers like REG_TC1_CTRLA etc. will be helpful to me.
Thanks in advance.
You can search here for REG_TC or similar, note that the TC is not unique for SAME54 so even if you find an example for SAMD20, SAMD21, SAMC21 etc. it can be useful.
Here is another resource:
https://github.com/ataradov/mcu-starter-projects
/Lars
Hi Lajon,
I have modified the code given the link below to configure timer. I wonder why it is not going into the Timer_Handler() function.
https://community.atmel.com/forum/tc-configuration-samc20?skey=REG_TC
My modified code is:-
#include "sam.h"
volatile uint32_t tick;
volatile uint32_t loop;
void TC2_Handler(void)
	tick++;
	REG_TC2_INTFLAG = TC_INTFLAG_OVF;
    /* Initialize the SAM system */
    SystemInit();
	REG_GCLK_GENCTRL0 = GCLK_GENCTRL_GENEN | GCLK_GENCTRL_SRC_DFLL;   //GCLK_GENCTRL_SRC_OSC48M; //set GCLK0 to operate from 4Mhz frequency (48Mhz/12 = 4MHz. see errata)
	//enable all peripherals clock in MCLK module
	REG_MCLK_APBBMASK =	MCLK_APBBMASK_SERCOM2 | MCLK_APBBMASK_TC2 |  MCLK_APBBMASK_TC3 |  MCLK_APBBMASK_TCC0;
	// Enable TC2,TC3 clock from GCLK1
	REG_GCLK_PCHCTRL31 = GCLK_PCHCTRL_GEN_GCLK0 | GCLK_PCHCTRL_CHEN;
	REG_TC2_CTRLA = TC_CTRLA_MODE_COUNT8 | TC_CTRLA_PRESCALER_DIV1024;
	REG_TC2_COUNT8_PER = 200;
	TC2->COUNT8.INTENSET.bit.OVF = 1; // set overflow interrupt
	NVIC_EnableIRQ(TC2_IRQn); // enable interrupts for TC2
	TC2->COUNT8.CTRLA.bit.ENABLE = 1; // enable TC2
	while(TC2->COUNT8.SYNCBUSY.bit.ENABLE == 1); // wait for TC2 to be enabled
    while (1)
		loop++;
Why it's not going into TC2_Handler() function while we set a breakpoint during debugging. What is missing over here??
You could also configure the timer/interrupt in Atmel START, and review the generated code as well.
JIm
REG_GCLK_PCHCTRL26 not REG_GCLK_PCHCTRL31.
/Lars
