How to show the ADC value in the USART?
17 posts / 0 new
Hi! i´m trying to show the adc value in the usart but i can´t because i need to convert an uint16t[] with the accumulate samples of the ADC of the sensor
to uint8 value that´s  required for  "usart_write_buffer_wait(&usart_instance,ADC_value,sizeof(value));" what can i do?
this is my main without the configurations but with debugging i got the adc values in an array of 100 elements
#include <asf.h>
#include <string.h>
#include <stdio.h>
#include <stdlib.h>
struct usart_module usart_instance;
struct tcc_module tcc_instance;
struct adc_module adc_instance;
//DEFINICIONES
//#define PWM_TOP_VALUE 1023
#define FILTER_SIZE 100
volatile uint8_t tx_character;
volatile uint8_t rx_character;
volatile bool command_flag;
uint16_t ADC_value[FILTER_SIZE];
uint8_t Text1[] = "Alarm on, ADC_value is:";
uint8_t Text2[] = "Alarm off, ADC_value is: ";
int main (void)
    system_init();
    adc_setup();
    usart_setup();
    tcc_setup();
    system_interrupt_enable_global();
    port_setup();
    adc_read_buffer_job(&adc_instance, ValorADC, FILTER_SIZE);
while (1)
        if ( ADC_value < 500){
            port_pin_set_output_level(PIN_PB08,1);
            usart_write_buffer_wait(&usart_instance, Text1,sizeof(Text1));
             port_pin_set_output_level(PIN_PB08,0);
            usart_write_buffer_wait(&usart_instance, Text2,sizeof(Text2));
You can't output all values with one call but to convert a single uint16_t to ASCII you can, e.g.,
char buf[10]
sprintf(buf, "%d", value);
which you can output
usart_write_buffer_wait(&usart_instance, (uint8_t*)buf, strlen(buf));
BTW, try to show the actual code you are using, there is no way the code above compiles (ValorADC ?).
/Lars
ok, here is my code for this fire alarm
#include <asf.h>
#include <string.h>
#include <stdio.h>
#include <stdlib.h>
//CONSTRUCT
struct adc_module adc_instance; //////////////
//DEFINItions
//INSTANCes
void usart_setup(void);
void usart_callback_read(struct usart_module *const usart_module);//(struct usart_module *const usart_module);
void adc_setup(void);
void tcc_setup(void);
void adc_callback_data(struct adc_module *const module);
uint8_t Text1[] = "Alarma on, ADC value is: ";
uint8_t Text2[] = "Alarma off, ADC value is: ";
volatile uint16_t adc_value[FILTER_SIZE];
        struct adc_config adc_configuration;
        adc_get_config_defaults(&adc_configuration);
        adc_configuration.clock_source = GCLK_GENERATOR_0; // 8 MHz
        adc_configuration.clock_prescaler = ADC_CLOCK_PRESCALER_DIV16; // 500 kHz (max. ~2 MHz) 1250
        adc_configuration.reference = ADC_REFERENCE_INT1V;
        adc_configuration.gain_factor = ADC_GAIN_FACTOR_1X;
        adc_configuration.positive_input = ADC_POSITIVE_INPUT_PIN0; // PA02
        adc_configuration.negative_input = ADC_NEGATIVE_INPUT_GND;
        adc_configuration.resolution = ADC_RESOLUTION_10BIT;
        adc_init(&adc_instance, ADC, &adc_configuration);
        adc_enable(&adc_instance);
        //Configure READ_BUFFER callback
        adc_register_callback(&adc_instance, adc_callback_data, ADC_CALLBACK_READ_BUFFER);
        adc_enable_callback(&adc_instance, ADC_CALLBACK_READ_BUFFER);
    uint8_t index;
    uint32_t adc_data = 0;
    ///Accumulate samples
    for(index = 0; index < FILTER_SIZE; index++) {
        adc_data += adc_value
    /* Launch a new asynchronous ADC read */
    adc_read_buffer_job(&adc_instance, adc_value, FILTER_SIZE);
void port_setup(void){
    struct port_config pin_configuration;
    port_get_config_defaults(&pin_configuration);
    //pin del buzzer
    pin_configuration.direction=PORT_PIN_DIR_OUTPUT;
    port_pin_set_config(PIN_PB08,&pin_configuration);
void usart_setup(void) {
    struct usart_config usart_conf;
    usart_get_config_defaults(&usart_conf);
    usart_conf.generator_source = GCLK_GENERATOR_0;
    usart_conf.transfer_mode = USART_TRANSFER_ASYNCHRONOUSLY;
    usart_conf.parity = USART_PARITY_NONE;
    usart_conf.stopbits = USART_STOPBITS_1;
    usart_conf.character_size = USART_CHARACTER_SIZE_8BIT;
    usart_conf.baudrate = 9600;
    usart_conf.mux_setting = EDBG_CDC_SERCOM_MUX_SETTING;
    usart_conf.pinmux_pad0 = EDBG_CDC_SERCOM_PINMUX_PAD0;
    usart_conf.pinmux_pad1 = EDBG_CDC_SERCOM_PINMUX_PAD1;
    usart_conf.pinmux_pad2 = EDBG_CDC_SERCOM_PINMUX_PAD2;
    usart_conf.pinmux_pad3 = EDBG_CDC_SERCOM_PINMUX_PAD3;
    usart_init(&usart_instance,EDBG_CDC_MODULE,&usart_conf);
    while(usart_init(&usart_instance,EDBG_CDC_MODULE,&usart_conf)!= STATUS_OK){}
    usart_enable(&usart_instance);
    usart_register_callback(&usart_instance, usart_callback_read, USART_CALLBACK_BUFFER_TRANSMITTED);
    usart_enable_callback(&usart_instance, USART_CALLBACK_BUFFER_TRANSMITTED);
    command_flag = true;
    usart_read_buffer_job(&usart_instance, (uint8_t *)&tx_character, 200);
void tcc_setup(void){
    struct tcc_config tcc_configuration;
    tcc_get_config_defaults(&tcc_configuration, TCC0);
    tcc_configuration.counter.clock_source = GCLK_GENERATOR_0;
    tcc_configuration.counter.clock_prescaler = TCC_CLOCK_PRESCALER_DIV1;
    tcc_configuration.compare.wave_generation =TCC_WAVE_GENERATION_SINGLE_SLOPE_PWM;
    tcc_configuration.compare.match[0] = 0;
    tcc_configuration.pins.enable_wave_out_pin[0] = true;
    tcc_configuration.pins.wave_out_pin[0] = PIN_PB30E_TCC0_WO0;
    tcc_configuration.pins.wave_out_pin_mux[0] = MUX_PB30E_TCC0_WO0;
    tcc_configuration.wave_ext.invert[0] = true;
    tcc_init(&tcc_instance, TCC0, &tcc_configuration);
    tcc_enable(&tcc_instance);
int main (void)
    system_init();
    adc_setup();
    usart_setup();
    tcc_setup();
    port_setup();
    adc_read_buffer_job(&adc_instance, adc_value, FILTER_SIZE);//////////////
    while (1) /////////////////////////////
        if ( adc_value < 500){
            usart_write_buffer_wait(&usart_instance,adc_value,sizeof(adc_value));
            usart_write_buffer_wait(&usart_instance, adc_value,sizeof(adc_value));
Still not ok code
volatile uint16_t adc_value[]FILTER_SIZE;
BTW are you sure about this (given that adc_value is going to be an array)?
/Lars
sorry i just edited that to
sorry I have not expressed my doubt well
my question is how to go from uint16 [] adc_value to uint8 for this
It's still not clear, what do you need to do with every adc value?
/Lars
thanks /Lars,
i´m trying to show the adc_value in the USART, my adc_value is an array of 100 elements and i want to make an uint8 with the average of this array
i tried with itoa but nothing, also tryed to calculate the average of the array with this
int i;
int sum=0
uint8_t average;
for(i=0; i<100; i++)
    sum = sum + adc_value[100];
    average=sum/100;
but it didn´t work
what can i do?
/Lars
thanks /Lars,
int i;
int sum=0
uint8_t average;
    average=sum/100;
but it didn´t work
what can i do?
int i;
int sum = 0
int average;
for(i = 0; i < 100; i++) {
    sum += adc_value[i];
average = sum / 100;
char buf[10]
sprintf(buf, "%d", average);
maybe
/Lars
it compiles but didn´t work
adc_read_buffer_job is not done there, it's done when the callback happens.
/Lars
then were i should put it?
this is my code now:
#include <asf.h>
#include <string.h>
#include <stdio.h>
#include <stdlib.h>
//CONSTRUCT
//DEFINItions
//INSTANCes
//declaciones media
//volatile uint16_t adc_value[FILTER_SIZE];
	uint8_t index;
; } /* Launch a new asynchronous ADC read */ adc_read_buffer_job(&adc_instance, adc_value, FILTER_SIZE); } void port_setup(void){ struct port_config pin_configuration; port_get_config_defaults(&pin_configuration); //pin del buzzer pin_configuration.direction=PORT_PIN_DIR_OUTPUT; port_pin_set_config(PIN_PB08,&pin_configuration); } void usart_setup(void) { struct usart_config usart_conf; usart_get_config_defaults(&usart_conf); usart_conf.generator_source = GCLK_GENERATOR_0; usart_conf.transfer_mode = USART_TRANSFER_ASYNCHRONOUSLY; usart_conf.parity = USART_PARITY_NONE; usart_conf.stopbits = USART_STOPBITS_1; usart_conf.character_size = USART_CHARACTER_SIZE_8BIT; usart_conf.baudrate = 9600; usart_conf.mux_setting = EDBG_CDC_SERCOM_MUX_SETTING; usart_conf.pinmux_pad0 = EDBG_CDC_SERCOM_PINMUX_PAD0; usart_conf.pinmux_pad1 = EDBG_CDC_SERCOM_PINMUX_PAD1; usart_conf.pinmux_pad2 = EDBG_CDC_SERCOM_PINMUX_PAD2; usart_conf.pinmux_pad3 = EDBG_CDC_SERCOM_PINMUX_PAD3; usart_init(&usart_instance,EDBG_CDC_MODULE,&usart_conf); while(usart_init(&usart_instance,EDBG_CDC_MODULE,&usart_conf)!= STATUS_OK){} usart_enable(&usart_instance); usart_register_callback(&usart_instance, usart_callback_read, USART_CALLBACK_BUFFER_TRANSMITTED); usart_enable_callback(&usart_instance, USART_CALLBACK_BUFFER_TRANSMITTED); } void usart_callback_read(struct usart_module *const usart_module) { command_flag = true; usart_read_buffer_job(&usart_instance, (uint8_t *)&tx_character, 200); } void tcc_setup(void){ struct tcc_config tcc_configuration; tcc_get_config_defaults(&tcc_configuration, TCC0); tcc_configuration.counter.clock_source = GCLK_GENERATOR_0; tcc_configuration.counter.clock_prescaler = TCC_CLOCK_PRESCALER_DIV1; tcc_configuration.compare.wave_generation =TCC_WAVE_GENERATION_SINGLE_SLOPE_PWM; tcc_configuration.compare.match[0] = 0; tcc_configuration.pins.enable_wave_out_pin[0] = true; tcc_configuration.pins.wave_out_pin[0] = PIN_PB30E_TCC0_WO0; tcc_configuration.pins.wave_out_pin_mux[0] = MUX_PB30E_TCC0_WO0; tcc_configuration.wave_ext.invert[0] = true; tcc_init(&tcc_instance, TCC0, &tcc_configuration); tcc_enable(&tcc_instance); } int main (void) { system_init(); adc_setup(); usart_setup(); tcc_setup(); system_interrupt_enable_global(); port_setup(); int i; int sum = 0; int average; for(i = 0; i < 100; i++) { sum += adc_value[i]; } average = sum / 100; adc_read_buffer_job(&adc_instance, adc_value, FILTER_SIZE);////////////// while (1) ///////////////////////////// { if ( average < 500){ port_pin_set_output_level(PIN_PB08,1); usart_write_buffer_wait(&usart_instance, Text1,sizeof(Text1)); char buf[10]; sprintf(buf, "%d", average); usart_write_buffer_wait(&usart_instance, (uint8_t*)buf, strlen(buf)); } else { port_pin_set_output_level(PIN_PB08,0); usart_write_buffer_wait(&usart_instance, Text2,sizeof(Text2)); char buf[10]; sprintf(buf, "%d", average); usart_write_buffer_wait(&usart_instance, (uint8_t*)buf, strlen(buf)); } } }
This is one way to do it
volatile bool adc_done = false;
    adc_done = true;
// In main
    while (1) {
        if (adc_done) {
            adc_done = false;
            int i;
            int sum = 0;
            int average = sum / 100;
            if (average < 500) {
            else {
/Lars
thanks /Lars!! but it doesn´t work it stops at this loop
while (1) {
        if (adc_done) {
            adc_done = true; //with debugging it crash here!!
            uint8_t i;
            uint16_t sum = 0;
And without debugging? Do you get any output? adc_done = true there is not what I wrote BTW.
/Lars
i tryed  adc_done = true and  adc_done = false      but it doesn´t work, it not get any output with or without debugging
i´m working on the sam d21 xplained pro board BTW
ITS WORKING!!!! enlightened laugh  JUST QUIT THE
if (adc_done)
AND NOW IT PRINTS THE VALUE
THANKS LARS!!!!!
