How do I avoid a bus collision? A question for true experts.
44 posts / 0 new
Hello everyone,
There are two devices which are trying to communicate via RS485 bus, half-duplex variant.
The point of issue is, a slave is always replies too early, thus causes a bus collission. It's clear that I have to delay replying. However, there's no access to firmware of the slave.
Any comments, ideas, please.
BR
Rouska wrote:
The point of issue is, a slave is always replies too early, thus causes bus collission. It's clear that I have to delay replying. However, there's no access to firmware of the slave.
Not enough info to give you an answer other then, can the slave device be replaced with one of your own design, or can you contact the manufacturer of the slave device to discuss the problem?
Can you give more context to the issue?
What type of slave device, line lengths, are proper line termination and biasing being used?
Define too early? Surely it cannot start to respond until the last bit of the last byte has left the master to trigger its response? This is the whole reason AVRs have the TXC (versus UDRE) interrupt. So you can know the moment the last bit is out then you can switch the bus direction so it's immediately ready for the response.
Or are you saying the slave is attempting to be full rather than half duplex and is attempting to respond even while the master is still sending cmd/data to it?
The slave comprises 16-bit microcontroller with 2 UARTs on board, MAX485 at output, cable length is about 2 meters.
The termination and biasing have nothing to do with this kind of issue.
everything goes half-duplex way. And slave's reaction is being triggered by last stop bit of the master's frame.
it's quite hard to explain, so please wait for a GRAPH. A few minutes.
Updated:
Then if you write UDR and then just sit a poll loop waiting for TXC you should be able to get the direction changed before the last stop bit out is processed. As I say, this is why the UARTs have TXC alongside UDRE (which you would otherwise use in "normal" (ie non-485) comms).
Well the OP has not said the master here is an AVR!
OP, why does the master take so long to change directions after the stop bit is sent?  What AVR is the master?
Can you post your 485 tx code?
I can recall is similar issue with a beagle bone driving a 485, we had to change the RS485 driver chip to one that could change directions quicker, I'll see if I can find that info on what we used.
Never mind, it was a change in the kernel driver that was the solution to that issue!
Are you sure you are sending the proper characters, and not too many?...Maybe you sent it too much & it is simply replying & happens to collide with the last byte you are sending.
Try removing the last byte you are sending..does it still reply & without collision?
Guys, the master comprises not AVR at all, I think.
This question is just last hope. I tired to struggle with manufactures of both devices. smiley
The master's manufacturer wrote us a letter. "Since millenium we are producing that device, we never heard that anyone faced with such kind of issues.
The slave's manufacture says the same.
But the problem still persists!
So, I need either to speed up Master's going to idle state or to delay slave's query. There's no an access to both firmwares.
So, any ideas please. The Graph is provided at #5.
Seems clear from your graph that the master is at fault for not switching off its driver quickly enough.  Not sure what you can do about that if you have no access to either firmware.  One approach would be to lower the baud rate and see if that fixes the problem (but then you're stuck with a lower baud rate...).
the manufacturer doesn't consider that as an issue at all. smiley
It doesn't matter low baud rate or high, the problem persists within a whole range of BDR.
What are these devices?, give links to the datasheets..you say these are something purchased?  Maynbe there is some option.
Well, if you don't have access to anything, I guess you will have to put some kind of buffer between the devices.
That is: Master -> delay -> Slave / Slave -> no delay -> Master
more an arbiter
https://en.wiktionary.org/wiki/arbiter#Noun (scarce is time, there's a timing issue)
what happens of you add a kilometer to the cable length?
Sorry, my misguided assumption was that a question about 485 on an AVR board might actually involve an AVR - silly me! blush
That tells me that the excess master delay is tied to the baud rate, not just e.g. interrupt latency in switching the bus driver.  Is the master configured for two stop bits?  If so, configure it for one stop bit.
Master 9600, even, 1 stop = Slave 9600, even, 1 stop bit.
Where are your links to the devices datasheets?....there will be information to understand the culprit & make the needed changes.
I can't see how you can do that with no access to the firmware at either end.
The best you can do is make something that sits in the middle, receives the data from the master, waits, sends it to the slave, receives the data from the slave, waits, and sends it back to the master.
Totally looks like the TX Enable of the master is staying active too long.
Is the master using a crappy USB to RS485 adapter that simply uses  an RC-Diode time constant to decide when TX-EN is active?
What does the schematic around the RS485 transeiver look like?
If you can hack the slave hardware with some "blue wire" then you could also add some delay to the slaves TX line.  Maybe an 8 bit shift register clocked at 4x the baud rate.
Then the problem should go away at lower baud rates, where the fixed RC time becomes less of a single bit time, but OP says lowering the baud rate gives no improvement.  That does seem odd, because whether the delay in reversing the driver is related to software (interrupt response time) or to an RC time constant, lowering the baud rate should eventually fix the problem (even it the slower rate may be unacceptable for other reasons).
So!  Show them the issue, with scope traces and explain the issue again, just because no one else has had the problem, does not mean it does not exist....
Example, no BA 737 max had ever crashed, until it did (twice)!  How many of these (defective) devices do you buy/yr?  Time to put the pressure on them!
Jiim
PS: did you try adding some length of wire to see what happens as suggested above?
...I was going to say to look carefully both ways before stepping on the road to make sure a bus or any other vehicle is not going to run you over.....
I had issues in the past with certain PLCs not liking the response too fast. This was with modbus protocol. I wrote the slave, so i needed to delay the response. The diagram posted is confusing as the terms ‘idle’ and ‘mark’ aren't used correctly. A stop bit is an idle level and a start bit is mark level.
I haven't worked much with RS-485, but it seems that, given all the different master and slave hardware possible to hang on the bus, some sort of configurable delay before responding (in either direction) would be an absolute must.  Just ruminating here.
BTW, does a collision show up on a scope on the data line(s)?  Something like a half-voltage when the master is sending a 1 and the slave is sending a 0?  Otherwise I guess watching both master and slave driver direction bits would show the same info, or inserting a small series resistor to generate a voltage when one driver is driving hi and the other is driving lo.  I'd sure want to explore the relationship between the collisions and differing baud rates.
my small input:
Can you get the master to make 2 stop bit's ? (perhaps that can help depending of what the real problem is).
Delay the signal from slave (and only that way I guess), with a long cable (100m+ ).
And the stupid one that will work, is to delay the output from the slave with a small micro, even a tiny4 can do that job. (something like a 30kHz timer ISR, that sample output from slave, and output it 4-6 ISR's later)
Interesting and clever idea.
hello everyone,
Jiim
You know... A large world known company. Which way works its support system. There's a person having an Email e.g. Automato-tomato.support.com. If you are lucky it won't be a moonlighting student or sales manager.
When he or she got an email from you, he, at best, runs or makes a call to technical level to ask what he should answer on this issue or just resends your email further. At worse, he runs to sales manager and writes you that bullshit which one manager told him(her). Now, ask yourself what can say useful a moonlighting student or a sales manager in this particular case?
That's the modern system of support. You are no at communication with true experts. It's almost not possible due to their busy schedule or so.
We bought for this new project a couple of masters and slaves. Since it's just a test project, nobody was going to purchase a few dozen of this devices.
if the 20 feet cable could make 100-200us delay at least theoretically, we would use it. smiley
sparrow2 wrote:
my small input:
I've tried to add second stop byte, just out of curiosity. it was really seen that idle state became longer exactly per 104us by 9600 bdr. The point is that I've noticed no difference, the same collission.
Concerning 30kHz timer ISR, could you shed light on that in more details (shematics, description?). It may consider that so-called stupid-working stuff for slave's programming mode only. An operation mode must be without any delayings, naturally.
An Update: see true diff. bus traces.
So, if you can set stop bits, configure the master for 1 stop bit and the slave for 2 stop bits.
This will make the slave think the delay from master is a 2nd stop bit and everything should be fine, right?
Agreed!  Post links to these devices you are using!  MAybe someone here will know something about them and can provide a solution.   THis is more like waving a carrot in front of the horses nose.
JIm
Um. Did anybody suggest, "Look both ways before crossing the street"?
Does the receiver cares about one or two stop bits ?
I didn't make this suggestion, but the concept is simple.  Get any micro with 1 input and 1 output.  Read the serial input on the logic-level side of the slave driver chip, delay it, and pass it along to the slave micro.
For timing I would want a sampling rate of something like 10x the bit timing, so for 9600 baud (104us) I'd want around 10us sample time.  But then you need to delay the bit for perhaps 1 bit time, so you have to store at least 10 input samples before outputting them.  A 16-bit software shift register would do the trick, and you could delay up to 160us for a bit of extra margin.  You don't need a timer to set the timing (simple cycle counting would work), but a timer may make things a bit easier.
Assuming you have set a timer for a 10us tick, the pseudo-code could look something like this:
forever
    wait_for_timer_tick
    output_delayed_bit_from_shift_register
    input_new_bit_to_shift_register
If you were running an 8 MHz clock, you have 80 cycles to perform this loop.
It should care, if you say 2 stop bits, then the receiver should at least wait that time before continuing.
edit:
Regarding the delay line theme, I recall this thread: https://www.avrfreaks.net/forum/...
It contains some useful ideas and  (quite elegant and optimized) sample code about implementing a delay line with an AVR micro.
perhaps the driver of the slave need to have the same delay line.
Just short have you remembered to give them the same ground ?
See #24....
Well, ideally you don't need to & doing so can cause severe ground loops*.  However, the actual chips have a limited common mode range, so you aren't completely off the hook--transformer interfaces are much better in this regard.
https://www.planetanalog.com/author.asp?section_id=483&doc_id=562062
*Say transmitting to the steel mill next door whose gnd is 2V above your house ground (due to the 1000''s of amps of large equipment running)....If you tie your house gnd  to the steel mill gnd via the rs485 cable, there will be a tug of war between your house & the steel mill & lots of amps will be involved!!!   Probably your cable or pcb or house will simply burn up.
There are a few scientific opinions in this respect. We've tried at least two.
Yes, both variants behave same way. It doesn't matter, whether they have common ground or not.
what you call 'shutdown' is the bus being released ie- not actively driven by anyone. The bias resistors determine the level. For a commercial solution, two serial<-> ethernet boxes would probably solve the issue. The likes of Perle methinks. Be sitting down when you see the price, but then again, your current commercial boxes probably aren't cheap either  There maybe cheaper serial to ethernet modules available.
You might want to tell us what the equipment is so we can be aware of it in the future.
The shutdown mode is a certain mode of a few MAXIM drivers. You can find a description in Maxim's manuals.
They are OEM highly specialized devices (PCB), so most of you will never deal with them.
P.S. Still nobody evaluated my masterpiece at #30. Probably there are not any issues at all. It just may be so! smiley Both are applicable for serial production.
Rouskas
Can you provide links to the devices you are working with?  You might be surprised that maybe some of us might know what they are.
The datasheet tells me shutdown affects power consumption as both the receive and transmitter are disabled. What your picture (#30 )shows is the bus not being driven unless the trace is showing the transceiver current.
How do you know someone here didn't design them? I've got plenty of devices out in the field which are rather niche market. Even the company that sells them would have trouble understanding any specific engineering query about them because the designer left the company. And yes, the respond rather fast - the actual response depends on where in the actual processing cycle the request occurs, so you get a bit of jitter. I expect other devices exhibit similar behaviour.
