How to make multi channel ADC work simultaneously?
7 posts / 0 new
I am working with SAME54 development board. I am using ASF4 framework.
I am able to successfully implement single channel ADC. But when I try to do multi channel ADC, only one channel is working but not remaining.
Please provide sample code with multi channel ADC working.
Warm Regards,
Nilesh.
Nilesh
That will get you nowhere.
Are you trying to perform a differential reading?
Post the minimal code you have written that shows the issue you are having.
JIm
Also note that you probably posted in the wrong place. Atmel/Microchip put the "ASF" forum under "AVR" not "ARM" so there may not be many ARM users reading this forum. You are probably better off posting in one of the "Cortex" forums.
But I have posted under ASF all architecture. And my earlier experience we hardly get response on ARM forums
Nilesh
If you think ARM is bad just wait. Your chances of getting response in AVR+ASF are somewhere between slim and nil.
I still think you'd be better off posting in the Cortex forum but perhaps post the multi-channel attempt you have and perhaps someone here could spot something? Are the E54 ADC like those in AVR where there's just one ADC and a multiplexer so you first switch the multiplexer to the input you want to measure then trigger a reading or are you actually using more than one ADC ?
EDIT: OK so it looks like you do select input with the MUXPOS/MUXNEG bits in the INPUTCTRL register. So I guess your multi-channel code just differs from the single channel in that it is changing these MUX bits then starting a new reading? Are you manually triggering with START in SWTRIG or are you setting up some kind of auto triggering?
I am able to read multiple channels but one at a time.
To switch over to next channel I have to adc_async_deinit and set new channel adc_async_set_inputs and again reinit adc. Read new channel.
But I would like to do without disabling/reenabling adc.
Warm Regards,
Nilesh.
Nilesh
Look at the Atmel Start ADC DMA sequencing example.
/Lars
