atmega2560 clock/oscillator selection new project
5 posts / 0 new
hello,
I start a new project with an ATMega2560-16u, but i don't understand how I can select the good clock source for the device...
it should exist some selection boxes for internal (RC) or external (XTAL) oscillator but there are no boxes availables in online or installed Atmel-Studio ... (see joined files)
On the integrated programming tool, I can select the correct clock source I want to use, but only as values in fuses regiters, but how can I be sure
that is really stored in the production files generated ?
how can I be sure of the results and how can I modify easily these settings if I need ?
Thierry
Usually for production use you script the programming application to set the fuses - you normally wouldn't have them part of your project.
which script you talk about ? I never see any script while generating a project (I try many differents),
where is the information for the fuses that will be put in the ELF file ?
And so how can I select the correct oscillator for my project ?
Thanks.
Thierry
Do this to include fuse information in the ELF.
See fuse.h for details.
Sorry, I do not use AtmelSTART, so I do not know how to set it up.
FUSES =
    .low = LFUSE_DEFAULT,
    .high = (FUSE_BOOTSZ0 & FUSE_BOOTSZ1 & FUSE_EESAVE & FUSE_SPIEN & FUSE_JTAGEN),
    .extended = EFUSE_DEFAULT,
    while (1)
The script you create to drive the production flash and fuse programming, usually a DOS batch file or linux shell script.
Here is an example of one I use to program a t25 using the avrdragon in a DOS batch file.
cd "c:\program files (x86)\Atmel\AVR Tools\AvrDragon\"
avrdragon.exe -dATtiny25 -I125000 -q -y -e -s -pb -vb -mi -if"c:\Users\Jim\Desktop\LLSC-Dev\LLSC.hex" -ie"c:\Users\Jim\Desktop\LLSC-Dev\LLSC.eep" -f0xD462 -l0xFC -E0xFF -F0xD462 -L0xFC -G0xFF
pause
Using avrdude or atprogram would be similar.
