pwm problem with attiny13
9 posts / 0 new
i have problem with AVR Attiny13 that i want to run in mode 5 PWM . in pin5 -pb0 , i take only vcc but no pulses.. this is my code in assemby and i set the fuse "SUT_CKSEL" : INTRCOSC_9MHZ6_14CK_64MS... Where is my mistake ? Thank you in advance.
 .include"tn13def.inc"
 .cseg
 .org 0
 rjmp reset
reset:
ldi r16,low(ramend)
out spl,r16
 ldi r16,0xff
 out ddrb,r16
 ldi r16,0x81
 out tccr0a,r16
 ldi r16,0x0d
 out tccr0b,r16
 ldi r16,0x20
 out ocr0a,r16
e:
 rjmp e
OCR0A is used to determine the count top. Therefore, PWM is not output to OC0A.
OCR0B is used to determine the duty. The PWM waveform is output to OC0B.
So , when i set TCCR0a as phase correct PWM and set COMOA1 :1 and COM0A0: 0 in oc0a i would not have clear on compare match when up-counting, and set oc0a on compare match when down-counting?
What makes you choose that mode? It is:
The "issue" here is that "TOP" is OCR0A. The upside of that is that the frequency is variable. The downside, as kabasan says, is that if OCR0a is tied up being used to set the frequency then it is not available for setting duty - so channel A output is not available. If you want to use both A and B channels (but still phase correct) then use:
That is still "phase correct" but now the frequency (TOP) is fixed at 0xFF. As OCR0A is not "tied up" being used to set frequency then both channels A and B are available as output.
If the frequency really does need to be variable (and you must use phase correct) then you have to accept that only pin 6 (OCOB) can be used for a PWM output.
thank you very much ! but now i have a new question if i want pwm pase correct  and i use oc0a as top then i have to configure tccroa com0a1:0 too or only com0b1:0?
As we've said if you use a mode where TOP can be varied (by OCR1A) then that ties up OCR1A for that job. Therefore is cannot be used for its normal job (setting PWM duty on channel A) so channel A is completely unusable in such modes. So you can forget COM01A:0 and the OC0A pin (5) and so on as you've chosen a mode where they are not usable. You have ONE available PWm output and that is on pin 6 (OC0B). You will set the duty using OCR0B and configure the pin action using COM0B1:0
As I said above if you DO want to use output A (or maybe A and B ?) then you need to use mode 1 not mode 5 but it means the frequency will be fixed (TOP is fixed at 0xFF).
thank you !!
Many times you do not need phase correct pwm.....some folks think the word 'correct' somehow means the other modes are 'incorrect', when they work just fine for many purposes.
thank you!
