Who wants to write a Bootloader for ATMEGA32M1 and SPI EEPROM (job offer)
12 posts / 0 new
i’m looking for someone to program a bootloader for AVR ATMEGA32M1 in C language, which gets  new  firware from a SPI EEPROM and updates it to the flash of the AVR.
Datasheets:
ATMEGA32M1:
http://ww1.microchip.com/downloads/en/DeviceDoc/Atmel-7647-Automotive-Microcontrollers-ATmega16M1-32M1-64M1-32C1-64C1_datasheet.pdf
EEPROM 25AA640-I/P (SPI, 64k)
https://www.mouser.ch/datasheet/2/268/21223G-70499.pdf
Background
I want to expand a device with the possibility of a software update by a change of a EEPROM by the end user. Bootloaders are all pretty new to me, and currently, i have no time available to do the r&d to do it by myself. That’s why i’m looking for someone with AVR and bootloader experience who is willing to do it.
The following material will be supplied by me:
  • Fully assembled test pcb + power supply
  • Eeproms
  • Framework of applications software
  • Schematics and layout of test pcb
The following material should be avaiable by the programmer who takes the job:
  • AVR programmer (i use ATMEL ICE, 6pin ISP header on PCB)
  • Eeprom programmer
Costs / salery
Of course you should get appropriate paid. Please send me a offer by pm (complete project price or hourly with an estimate of needed hours)
Let me know if you want to know more !
If someone is interested in taking this small project, hit me up 😊
Thanks! Best greetings,
markus
markus652 wrote:
in C language
Which C? If you mean the avr-gcc that comes with AS7 then in its library code is this:  https://www.nongnu.org/avr-libc/user-manual/group__avr__boot.html  The "API Usage Example" they give there is pretty much 90% of a bootloader. The only missing bit then is the loop that feeds the data to this to be programmed.
for mega32M1, CAN and AES bootloaders via search for 'boot' in ATmega32M1 - 8-bit AVR Microcontrollers (edit : Documents tab)
External storage attached to an AVR is in AN_8390 AVR2054: SerialBootloader User Guide
awesome, super helpful community here :D
thanks for the information and documents!
thing is, this is all very new to me, and i'm currently very busy, so not that much time to learn everything about it by myself.
would be awesome if someone with experience is interested in taking the job :)
cheers guys :)
I would suggest you look at community member alank2 programmer instead. It essentially does what you want to do withour the bootloader.
His programmer is a self managed ISP programmer. What you are looking to do sounds like putting a socket on a pc board then ship an IC with the firmware update.
Alank2 device does all this for you and saves you board space and the cost of an eeprom socket. I use alank2's programmers just for this purpose. Super easy. Power down the product, plug programmer on to ISP pins, power up product and wait for green light on programmer. Remove programmer and walk away.
hi jim,
that's exactly what i intend to do. ship IC with the new firmware to the customers so they can update the firmware by them self (changing the eeprom).
so alank's auto programmer is not really a convinient way to do it, as every customer would have to get such a device, which is way more costly? or am i missing something?
thanks!
I see a lot of bent pins and chips inserted backwards!
What Is an iButton Device? - Application Note - Maxim
DS1977
iButton 32KB EEPROM
Microchip CryptoMemory could be packaged as an alternative; one is 32KB in a "module" though don't know its fit and form.
CryptoMemory | Microchip Technology
I don't understand the need of a eeprom chip as a device for transporting the binary content.
I have such a thing on one of my products, a sd card bootloader. But the product has a sd card in the first place, the bootloader is using it because it's just there, and convenient.
Your product probably has some communication interfaces. Use one of these.
As people presumably choose 32M1 principally because it's got CAN then I guess the main comms interface is CAN? But I suppose that then raises the question of "if you are going to inject new firmware over CAN then how do you get that data onto the CAN bus in the first place?"
Yes, you are missing a lot.
I do not know how your board is laid out, but I would hope there are 6 ISP pins on it to accommodate programming.  What I would suggest you do is buy a couple of alank2's programmers and load the updates in them, and send them to your customers that need the update.  THey load the update into their product and then mail the programmer back to you.  Simple as that.  Sending out a DIP eeprom is a pain in the A$$.  If the customer puts the EEPROM  in backwards, or breaks a leg off the part what happens?  Also, Can a bootloader change fuse settings if you need to?  The programmer can.
Customer has to purchase nothing, you buy a few of them and if the customer does not return them in good working order then you bill them for it, or no more service/updates till the bill is paid.  THis is my policy, and thankfully I have never had to enforce it.
Who pays for the eeprom you are sending out?  Can you guarantee that you will always be able to source them?
JIm
And...
What usually happens when you try to remove a dip package with your fingers?
There will be blood
Tom Pappano
Tulsa, Oklahoma
