Split from: AVR vs. TI MSP430
37 posts / 0 new
Hi All,
I was just about to create a new post when I came across this OLD post from 2003.
Basically, I have a suite of products that use the MSP430F1611IPM and MSP430FG4618. I am running out of code space (10 bytes left) and looking at swapping out the micro's for new bigger devices.
Personal preference is AVR Mega series or XMega series.
How do these compare to the MSP430 series?
Just to through another micro into the mix, one of the projects has a PIC18F480. I would love to swap this out for a Mega or something as well.
Thoughts???
Neil.
Kind Regards,
Neil Wrightson.
I have a suite of products that use ... MSP430FG4618
You're running out of code space on an MSP430 with 116kbytes of flash?
IMO: time to upgrade your thinking to one of the 32bit chips (SAMD, MSP432, etc.)
I mean, academically, I'd rate both MSP430 and AVR as "hurting" once you get above their native 16bit address space.
There aren't many plain "mega" parts with more than 128k of memory (and going to "only 128k" when you're running out at 116k seems foolish), unless code density REALLY improves, which I would doubt.  MSP430 is a reasonable 8bit CISC instruction set, AVR is reasonable 8bit RISC...
  • Some AVR have an EBI (MSP430TM doesn't)
  • MSP430 may be a bit more compute efficient than AVR
dsPIC33C arrived mid'18 with Curiosity boards for it; the single core dsPIC33C has an EBI (16b address, 8b or 16b data, mux'd)
MPLAB XC8 for PIC made a major change from v1 to v2 (clang, C99)
CPU Benchmark – MCU Benchmark – CoreMark – EEMBC Embedded Microprocessor Benchmark Consortium
via yesterday's e-mail :
Microchip Technology - Development Tools - 16-bit Curiosity Boards
MPLAB- XC Compilers | Microchip Technology
Clang C Language Family Frontend for LLVM
Just Add
A MSP430 is a 16bit chip not 8.
So if the MSP430 is to small I also would go for an ARM, which I don't know that will really depend.
add:
One thing both MSP430 and AVR are good compared to ARM is low power, and sleep power, but newer ARM's are getting better.
westfw wrote:
... (SAMD, MSP432, etc.)
Renesas SynergyTM
MSP430TM has a 20-bit address space; FSF MSP430 GCC has a 20b pointer type.
IAR EWAVR has the 24b pointer type in a few memory models; AVR GCC has 24b types (XMEGA) but would take some effort to make a pointer by it.
westfw wrote:
There aren't many plain "mega" parts with more than 128k of memory ...
XMEGA384 models have 384KB program space and 32KB of local RAM (that's usually enough RAM for most applications)
http://www.ganssle.com/tem/tem365.html#article6
[Renesas SSP]
Need development tools? IAR's suite is provided along with their runtime analysis tools.
So, how free is free? The website indicates these are all totally free, with no licensing or royalty fees
[e-mail]
After getting that email I ordered a $35 Synergy dev board and will give it a whirl.
'16 MCU ranking by revenue : 1. NXP, 2. Renesas, 3. Microchip
Am not certain the ones at Microchip can top Renesas SSP.
https://gcc.gnu.org/onlinedocs/gcc-8.2.0/gcc/MSP430-Options.html#MSP430-Options
-mlarge
-mlarge
Use large-model addressing (20-bit pointers, 32-bit size_t).
https://www.iar.com/iar-embedded-workbench/#!?architecture=AVR
https://gcc.gnu.org/wiki/avr-gcc#Types
https://www.microchip.com/sitesearch/search/Product%20and%20Development%20Tools/ATxmega384
One might prefer to first select the OS, RTOS, framework, scheduler, etc then select the MCU second.
Zephyr's CPU are all 32-bit :
Supported Boards — Zephyr Project Documentation
The "unusual" CPU in that list is RISC-V; Microchip is well placed in RISC-V by the acquisition of Microsemi.
RISC-V Foundation | Instruction Set Architecture (ISA)
The MSP430F1611 as used in the current products has the following spec:
- 48KB+256B Flash Memory
- 10KB RAM
This is why I was looking at say the AVR Mega128 or XMega128.
Kind Regards,
Neil Wrightson.
Have you tried the MCU selector: https://www.microchip.com/maps/M...
Only you know exactly what kind of specs you need.
edit: yeah, I'd go for 32 bit for these specs. They are faster and cheaper, this means the manufacturer wants people to use them. Here are a couple from our sponsors:
https://www.microchip.com/wwwpro... (PIC32, i.e. MIPS32 architecture, I never used them but the specs seem nice)
https://www.microchip.com/wwwpro... (and this one is a Cortex-M0+. From my limited experience, the SAMD are nice chips, a bit complicated to configure, but that is kind of inevitable with 32 bit chips)
So you are still working you poor thing..... wink
PIC32 and some SAM can reach 125C though dsPIC can reach 150C except for the new dsPIC33C at 125C (radiation tolerance is proportional to maximum ambient temperature)
16b is a typical sweet spot for code and data density as 16b integers are usually enough precision for most applications; an MCU manufacturer may have a fixed-point math library.
dsPIC33EP512GM310 - 16-Bit - Microcontrollers and Digital Signal Controllers
New Digital Signal Controller (DSC) Accelerates DSP Performance for Time-Critical Control Applications | Microchip Technology
dsPIC33CK is Microchip’s highest performance single-core DSC in an ultra-small package
Fixed Point Math Library for PIC24 and dsPIC
via Software Libraries
El Tangas wrote:
... and this one is a Cortex-M0+. From my limited experience, the SAMD are nice chips, a bit complicated to configure, but that is kind of inevitable with 32 bit chips
This is exactly the reason I never will change to these 32 Bit chips: Complicated to configure! Unnecessarily difficult to configure!
It's so pleasant to work with 8Bit controllers that are simple in design but still completely sufficient for me and many purposes.
nwrightson wrote:
The MSP430F1611 as used in the current products has the following spec: - 48KB+256B Flash Memory - 10KB RAM   This is why I was looking at say the AVR Mega128 or XMega128.
You want to REDUCE the RAM??
The fact is that the flash to RAM ratio in AVR is not as high as ARM or (apparently) MSP. There is only one AVR that has more than 8K RAM and that is the Mega1284P which has a whopping 16KB. So if RAM is going to be an issue then AVR may not be the right choice.
GermanFranz wrote:
...: Complicated to configure! Unnecessarily difficult to configure!
Hopefully, Jack Ganssle will write a review of Renesas SynergyTM SSP.
wrt Microchip PIC32, I have zero experience with MPLAB Harmony.
Concur
Amazing that 8b MCU have DMA, other somewhat complex peripherals, and are being improved (there's persistent demand for 8b MCU)
IAR Embedded Workbench® for Renesas Synergy™
MHC | Microchip Technology
... and several XMEGA256 at 16KB plus the two XMEGA384 at 32KB.
nwrightson wrote:
... Mega128 ...
and AT90USB1286 or AT90USB1287 though, as Cliff stated, you'll have more internal RAM with most 32b MCU.
AT90USB128 series external memory (XMEM) : one latch to demux the LSB of address and data
Teensy Technical Specifications (Teensy++ 2.0)
@OP - have you looked at why you are running out of code space?  Can you just optimize current codebase and get more free space?  That way you don't end up with orphaned hardware with old CPU ?
An example of such is AVR32 after it was legacy'd by Atmel.
AVR and MSP430TM are very low risk of legacy by the respective manufacturers or by foundations (FSF, LLVM)
PIC24 and dsPIC weren't selected by foundations.
PIC32 has a MIPS core so it should have a long life.
PIC - it's interesting that the ones at Microchip selected Clang for MPLAB XC8 PIC v2.
http://clang.llvm.org/docs/UsersManual.html#other-platforms
https://github.com/llvm/llvm-project/blob/master/clang/lib/CodeGen/TargetInfo.cpp
https://github.com/llvm/llvm-project/tree/master/llvm/lib/Target
I was actually responding to OP saying
If he changes CPU then his suite of products now has a lot of "version 2" that is incompatible with version one.  I don't know how many products he has out there or if he has to support past customers.  If he does have to support old customers then maybe code space optimizing is a better idea.
Build Larger, More Robust Applications with Microchip’s Expanded Dual- and Single-core dsPIC Digital Signal Controller (DSC) Family | Microchip Technology
New dsPIC33C devices meet market demand for more memory and functional safety features in automotive and wireless charging applications
Chandler, Arizona
March 13, 2019
Microchip’s new dsPIC33CH512MP508 dual-core DSC enables support for applications with larger program memory requirements. The dsPIC33CK64MP105 single-core DSC adds a cost-optimized version for applications that require smaller memory and footprint.
A robust set of CAN-FD peripherals, along with the new support for 150°C operation, make these devices ideally suited for use in extreme operating conditions such as under-the-hood automotive applications.
The dsPIC33CH Curiosity development board is available now for $39.99 each.
The dsPIC33C PIM development boards mentioned above are available now for $25.00 each.
Wasn't aware that CoreMark is synthetic.
EmBench is a new benchmark that's not synthetic :
Embedded Benchmark Calls for Support | EE Times
EmBench aims for free metric based on real-world apps
by Rick Merritt
06.11.19
[David A.] Patterson’s textbook on microprocessor design, co-written with John Hennessey, preached against use of synthetic benchmarks such as Dhrystone.
EmBench also aims to be an alternative to the widely cited CoreMark, one of more than a dozen embedded benchmarks developed by the EEMBC trade group.
[page 2]
On the technical side, it expects to run a small program written in assembly language of the target platform to measure its latency in context switching.
Computer Architecture - 6th Edition
edit :
Embench™: A Modern Embedded Benchmark Suite
GPLv3
If you are learning a new uC, ARM cortex M0 is the best choice. M0 has alot of reach and available from multiple suppliers each having slightly different offerings. M0 is about $1, so you are not paying a premium over an 8/16 bit uC.
KEIL for ARM is free for upto 32KB of code and it supports the entire range of M0/M3/M4/M7 devices, so if you wanted to stick to the same IDE for each project then KEIL is a good choice.
In the future you can easily transition to M3/M4 and arguably M7 if you need more horsepower while keeping the same IDE.
Prior to ARM cortex, there was alot of complex configuration you had to do for ARM7, but nowadays with cortex the configuration is much less complex though still more complex than say AVR. IMHO the complexity of ARM Cortex is just about perfect, any less complex and it would gimp the available options for experienced developers, any more complex and it would put up too many roadblocks for new developers.
It is not all about the uC core, the cortex peripheral set is also much more powerful WRT 8/16 uCs. For instance, I think AVR ADC is ~50ksps max, at the max sample rate the AVR would be almost 100% occupied just moving data from the ADC registers to RAM, if the ADC sample rate was any higher it could not be taken advantage of by AVR. ARM cortex M0 ADC is in the 250ksps range, the M0 core can keep up with shuffling data from the ADC resister to RAM at the max sample rate though the M0 would have nothing left over to do any processing of the ADC results.
GPIO reading and writing on ARM cortex is often very slow compared to other uCs, that is the only legit beef I have with ARM Cortex.
If you are looking for a good M0 platform that is least complicated and dirt cheap I would recommend the Nuvoton line of M0 uCs, it looks to me like Nuvoton just got a default template from ARM and made their M0 chips with little to no modifications which to me is a good thing when starting out with M0.
megaAVR 0-series is at 115Ksps with an accumulator to reduce the data flow impact.
XMEGA AU AVR have pipelined ADC with DMA at up to 2Msps.
ATmega4809 sell sheet via ATMEGA4809 - 8-bit Microcontrollers
AN_8378 AVR1324: XMEGA ADC Selection Guide via ATxmega128A1U - 8-bit AVR Microcontrollers
I did not know there were new AVRs with upgraded ADC peripherals. The accumulator I think is only useful if you want to oversample, otherwise you are using pure CPU power to shuffle ADC data around.
I have never looked at XMEGA, it does not surprise me that it has DMA. DMA on M0 is quite common.
My general observation is that more powerful the cores tend to bring in more powerful and more complex peripherals, that was what I was trying to get at. My ADC example might not be the best example of that if you throw DMA into the mix.
with further improvements in the forthcoming AVR DA-series.
AVR DA ADC :
  • 10b or 12b
  • up to 128 samples in the 16b accumulator
  • window comparator
Don't know its ADC maximum clock frequency.
What are the AVR28DA128 AVR32DA128 AVR48DA128 AVR64DA128 ?? | AVR Freaks
Embedded World: Embench 0.5 benchmark platform launches
By Alex McCarthy 27th February 2020
Speaking exclusively with Electronics Weekly, Embench announced its 0.5 launch today at Embedded World. The benchmark suite is an open-source collaboration between academia and industry, aiming to provide accurate and relevant performance figures for embedded processors.
Embench 0.5 is being developed by a committee of the free and open source silicon foundation. The committee aims to iteratively improve the benchmark with revisions every few months until it can release version 1.0, aiming for Q4 2020.
It plans to revisit the suite biannually to keep up to date, refreshing the programs to reflect requirements and preempt any workarounds.
edit : Releases · embench/embench-iot · GitHub
embench-iot/config/avr at master · embench/embench-iot · GitHub
due to an e-mail on 10-Mar'20 from David Patterson (UC Berkeley)
Please try to have your input by Friday March 13.
Embench Hot Chips Abstract - Google Docs
AVR is in an Embench action item.
[Embench] Embench meeting/call 19 July 2020
I'm skeptical of being able to use a unified means of determining processor performance. These days the 'system' affects the overall performance more than the processor core itself.
A simple example might be the imxrt1062 cpu I'm using at the moment - 600MHz Cortex M7. This thing is freaking fast. That is assuming you make it so. Have it execute from external flash, then the performance is about the same as a 80MHz Cortex M7.
For the IoT market that is used as the reference - that spans from miniature very low power and low data rate devices up to, say, video cameras with image recognition and 'Alexa' type devices with voice recognition, spacial audio processing where the power consumption is irrelevant and high data rate wireless interfaces are used. With the high end devices it is the co-processors that do most of the work leaving the microcontroller to 'pull the levers'.
I think that's a topic for a whole discussion of its own!
Indeed.
And how do we define "performance", anyhow ?
In many cases - particularly for (small) microcontrollers - sheer processing power is not the key concern.
Things like power consumption & cost are often more important.
And peripherals and things like DMA.
Microchip have ADCs which will do accumulation, and even a complete PID block in some 8-bit chips. Things like that render raw processor speed irrelevant.
It sort of smells a bit like a marketing ploy.
Out here we have a company called Canstar. My guess is you wave some dollars at them and they create an 'award' so you can use that in your marketing.  XXX got the canstar award for 'outstanding achievement in the field of excellence' five years in a row is a common catchcry - note I did use a bit of artistic license there, but only a small amount, honest.
Not only am I skeptical, but I'm cynical as well :)
Indeed.
Like all those spurious "World'd First xxx!!"  announcements - which often boil down to little more than just "World's First Product Called XYZ from xxx"
frown
awneil wrote:
Things like power consumption ...
CPU Energy Benchmark – MCU Energy Benchmark – ULPMark – EEMBC Embedded Microprocessor Benchmark Consortium
MSP430 has a greater ULPMark score than XMEGA.
yeah - but, as noted, this all has far more to do with the System than just the chip itself - it's how you use it that makes the big difference.
