Programming ATtiny412
13 posts / 0 new
Hi everyone,
I want to program ATtiny 412 with i2c communication protocol. Can anybody please help me how to start with for i2c programming?
Thank you
Kishore.G
Hi gkishor,
Welcome to AVRfreaks,
have you tried to look for examples in ATMEL start ?. The attiny412 MUX table in the datasheet is somehow wrong and contains wrong information..this is the right table:
for a simple application you can start looking in this forum for some codes, you can find it easily by a simple search.
Hi sir,
Thanks for your response. I am trying to understand some example i2c codes. After some study, I have following doubts
1) Which register & bits [SCTRLA, SCTRLB, SDATA], I have to configure to Enable TWI, Enable ack generation
2) Which register & bits are to be checked for,  whether the master is requesting data or sending data to slave
3) How to use SDATA register to transmit multiple bytes of data to i2c master
4) How to configure PA3/PA6/PA7 to use them as GPIO pins
figure: TWI registers
I have read the datasheet, regarding configuration of the above registers for i2c slave operation. But I'm not getting proper information from datasheet.
Please help me.
Thank you sir,
Kishore.G
have you checked the forum for examples ?
First Wecome to AVRFreaks!
Can you start by telling us what your experience writing micro controller code is?
If this is your first project, you are starting with a fairly complex project.   Tell us what your I2C slave will do other then communicating with an I2C master (and tell us what your I2C master is as well).
Try to start from here:
these application notes descibes most of the functions to get through in ATtiny 1 & 0 series (compatible with your attiny412)
Couldn't find any app notes on unified memory AVR TWI; hopefully AVR libc's TWI will work.
avr-libc: Example using the two-wire interface (TWI)
That would be QUITE a stretch. The tiny412 IO header has:
/* Two-Wire Interface */
typedef struct TWI_struct
    register8_t CTRLA;  /* Control A */
    register8_t reserved_0x01;
    register8_t DBGCTRL;  /* Debug Control Register */
    register8_t MCTRLA;  /* Master Control A */
    register8_t MCTRLB;  /* Master Control B */
    register8_t MSTATUS;  /* Master Status */
    register8_t MBAUD;  /* Master Baurd Rate Control */
    register8_t MADDR;  /* Master Address */
    register8_t MDATA;  /* Master Data */
    register8_t SCTRLA;  /* Slave Control A */
    register8_t SCTRLB;  /* Slave Control B */
    register8_t SSTATUS;  /* Slave Status */
    register8_t SADDR;  /* Slave Address */
    register8_t SDATA;  /* Slave Data */
    register8_t SADDRMASK;  /* Slave Address Mask */
    register8_t reserved_0x0F;
} TWI_t;
The avr-libc example code has:
C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\avr8\avr8-gnu-toolchain\doc\avr-libc\examples\twitest>grep "TW.. " twitest.c
 * register to have valid contents while the TWINT bit in TWCR is set.
  /* initialize TWI clock: 100 kHz clock, TWPS = 0 => prescaler = 1 */
  TWSR = 0;
  TWBR = 10;                    /* smallest TWBR value, see note [5] */
  TWBR = (F_CPU / 100000UL - 16) / 2;
  TWCR = _BV(TWINT) | _BV(TWSTA) | _BV(TWEN); /* send start condition */
  while ((TWCR & _BV(TWINT)) == 0) ; /* wait for transmission */
  TWDR = sla | TW_WRITE;
  TWCR = _BV(TWINT) | _BV(TWEN); /* clear interrupt to start transmission */
  TWDR = (eeaddr >> 8);         /* 16-bit word address device, send high 8 bits of addr */
  TWDR = eeaddr;                /* low 8 bits of addr */
  TWCR = _BV(TWINT) | _BV(TWSTA) | _BV(TWEN); /* send (rep.) start condition */
  TWDR = sla | TW_READ;
      TWCR = twcr;              /* clear int to start transmission */
  TWCR = _BV(TWINT) | _BV(TWSTO) | _BV(TWEN); /* send stop condition */
  TWDR = (eeaddr>>8);           /* 16 bit word address device, send high 8 bits of addr */
      TWDR = *buf++;
      TWCR = _BV(TWINT) | _BV(TWEN); /* start transmission */
To quote Sesame Street "one of these things is not like the other one" ;-)
EDIT working on the assumption that in an AVR-0/AVR-1 there's got to be a strong chance that TWIn.MCTRLA is going to be accessed at some stage then a google for:
avr twi "MCTRLA"
seems quite fruitful (mainly back here at Freaks in fact)
I have checked some threads in the forum. Still I didn't get specific information
Kishore.G
Hi Sir,
I am new to microcontroller programming.
Functions of ATtiny I2C slave
  • To transmit some bytes of information to I2C master and processing the information sent by I2C master and acting according to it
  • Driving some data to some other I2C slave through GPIOs available with it
Kishore.G
This thread has useful information regarding bit checks for slave read/write
https://www.avrfreaks.net/forum/attiny416-acting-twii2c-slave-device-failure-second-read
But how to configure registers to use ATtiny pins as GPIOs?
Kishore.G
What is your experience in programming ? maybe you should start with arduino better
ASF4?
ASF4 API Reference Manual - I2C Drivers
via START (Help tab)
No TWI in ASF3 for tinyAVR.
