EDBG MSD firmware bypass
4 posts / 0 new
Currently trying to pull a .hex file off of my SAMD21J18A xplained pro board, however when I go to device programming it prompts me to update the firmware. The problem is I don't know how this firmware is going to affect the program on the board (I don't have the original project anymore). Is there anyway to bypass this update and just use the firmware that is on the board already?
Any help is much appreciated.
Maybe you can use the command line tool that comes with AS, atprogram.exe, to get the binary dump from the chip.
It has a "force" option:
-f  --force                Force command even if firmware is not up to date.
atprogram will generally not force an upgrade (it has a lower-bound check only)
In studio, under Tools/Options/Tools there's a switch to turn off the fw check.
Also, a fw upgrade does not touch the target...
:: Morten
Thank you very much! This is exactly what I needed!
