LDI variable,' '
11 posts / 0 new
Encontré esta instrucción LDI rmp,'  ' , en la linea de comentario dice "overwrite with blank", esta instrucción esta dentro de una subrutina que detecta un cero(0).
 he ejecutado el código y lo que hace es cargar el valor de 0x20 a la variable " rmp =0x20"
, deseo saber porque se hace esta instrucción, esta instrucción se encuentra antes de enviarlo como ASCII a un LCD.
Anexo el código:
Bin2ToAsc5:
    rcall Bin2ToBcd5 ; convert binary to BCD
    ;ldi rmp,4 ; Counter is 4 leading digits
    ;mov rBin2L,rmp
Bin2ToAsc5a:
    ldi r16,0
    mov r0,r16
    ld rmp,z ; read a BCD digit
    tst rmp ; check if leading zero
    brne Bin2ToAsc5b ; No, found digit >0
    ldi rmp,' ' ; overwrite with blank
    st z+,rmp ; store and set to next position
    dec rBin2L ; decrement counter
    brne Bin2ToAsc5a ; further leading blanks
    ld rmp,z ; Read the last BCD
Bin2ToAsc5b:
    rcall Bin2ToBcd5 ; Subrutina convertir de binario a BCD
    ;ldi rmp,5 ; Contador
    ldi contador,5; Contador
    ldi r25,0x30
Please do not cross post or post duplicates!
Also, English is the board language.
I found this LDI instruction rmp, '', in the comment line it says "overwrite with blank", this instruction is inside a subroutine that detects a zero (0).
  I have executed the code and what it does is load the value of 0x20 to the variable "rmp = 0x20"
, I want to know why this instruction is done, this instruction is found before sending it as ASCII to an LCD.
Attach the code:
Bin2ToAsc5:
    ;mov rBin2L,rmp
Bin2ToAsc5a:
    ldi r16,0
    mov r0,r16
Bin2ToAsc5b:
    ldi r25,0x30
rmp is a 'name' given to 'something....in this case it's most likely a register
The hex value 0x20 in ASCII is the SPACE character, so by putting a SPACE between to apostrophe's its the same as writing
ldi rmp,0x20 ; overwrite with blank
Why they elected to call it a 'blank' is something I cannot explain
Est coast Jim
ldi instruction loads a constant (value) into the specified register (only register numbers r0 to r15 allowed).   "blank" character is often used as a poor wording choice for "space" character, which is 0x20, or $20.
somewhere rmp has been defined as the name of some register (r0 to r15)
like:
.def rmp=r12    ;rmp is now same as typing r12
You sure?
I have been using R16 as my 'working' register and perform the LDI instruction to it, and any other register.
JIm
When writing to an LCD, it's pretty common to write the full width of the display, and you want to pad the part that doesn't contain your values with spaces.
Otherwise, if you write "Booting up now", followed by "ADC reads 12", you might see "ADC reads 12ow"
first it's r16 to r31 you can use LDI on.
I have only looked shortly at it but it looks like it's so they get "   345" instead of "00345"
Correct.  I looked it up after I hit post and realised my answer was rather vague.
JIm
thank you very much, now I find it was obvious to send a space to the HMI
You sure?
Oops I was hanging upside down when I wrote that...it is indeed the 16 higher registers!!
