12v A2D circut with minimal power consumption
5 posts / 0 new
What circuit and technique should I use for a lest power consuming design for 8 bit AVR measuring the charge of a 12V battery bank?
* Post your questions in the appropriate forum. The "AVR Freaks Projects" forum is for questions about existing, fully completed submissions in the "Projects" area. Moderator. *
One approach is to put a FET switch between the battery and the resistor voltage
divider that feeds the ADC input.  Switching it on to measure, then off, keeps current
consumption low.
Here is a diagram for measuring a 9V battery:
another example that's for a 4S Li-ion battery :
AVR1300: Using the AVR XMEGA ADC
(page 21)
via AN2535 AVR1300: Using the XMEGA ADC | Application Notes | Microchip Technology Inc.
Adjust the source resistance as XMEGA can have a larger source resistance than megaAVR at a given sample rate.
Edit: source R
I never posted a thank you for these circuits, Thank You! I have a related problem. I need a minimal power consumption AVR solution for 13.5-11V DC. Can I somehow beat the voltage divider method of powering this AVR? I want it to mostly sleep.
Do you mean you need a voltage regulator for your project?
One linear regulator I have used on past for a battery powered project was the TI LP2985, the quiescent current is only 95uA.
You may have even better results using a switching buck regulator, other freaks may be able to offer examples of these.
Good luck with the project.
