symbol 'true' cannot be resolved?
28 posts / 0 new
Why do I get the symbol 'true' cannot be resolved?
I've included <stdbool.h>
EDITED: This is in Eclipse.
it is capitalized (since it is a macro): TRUE and FALSE.
stdbool.h defines the macro true.
If the message is that true is undefined,
my guess is that stdbool.h is not really #included.
More likely it was listed as a project file,
but not #included anywhere.
What is in the .i file?
I use -save-temps routinely.
Unrelated to the question....  An easy
improvement to the speed of your code
would be to only call strlen(name) once,
store it in a variable and then pass this
value to memcmp.
--Mike
 An easy improvement to the speed of your code would be to only call strlen(name) once,
store it in a variable and then pass this value to memcmp.
Wouldn't the compiler do this for you??...it can see that the function is re-used immediately, so it should still maintain the result for re-use.
Of course wondering what the compiler will do is sometimes like looking into a crystal ball (even though there really will be no question if you are willing to barf your way through all of the compiler documentation).
Nah Jim, that did not work.
What OP seems to want is strcmp.
Even if he uses strcmp, OP will have the same problem with false.
Again: what is in the .i file?
If it contains a true, that is the problem.
stdbool.h #defines true.
If true is in the .i file, stdbool.h was not #included.
Why not try adding:
#define true 1
#define false 0
to the beginning of your program and see if it works?
If you google "  Symbol 'true' can not be resolved " and " Eclipse", what do you get?
This can't be the first time that this idiot worthless C error message has shown its stupid self.  How did every other Eclipse user deal with it?
OP should look at the .i file .
Almost certainly OP did not really #include <stdbool.h>
Possibly OP #included "stdbool.h" and the compiler found a non-standard file.
Possibly eclipse defaults to C89 and omits the directory containing stdbool.h.
In that case, there should at least have bee a warning about not finding stdbool.h .
Disclaimer: I've never used Eclipse so all that follows may be nonsense.
This looks like an IDE symbol indexing error, not a compilation error. From this stack overflow post it looks like you need to tell Eclipse where to find standard header files.
github.com/apcountryman/build-avr-gcc: a script for building avr-gcc
github.com/apcountryman/toolchain-avr-gcc: a CMake toolchain for cross compiling for the Atmel AVR family of microcontrollers
the include file resolves when I right click on it.
This almost makes it look like you have defined __cplusplus somewere along the compile line.
for some reason it then seems to think you the bool/true&false are defined already somewere else.
Are you also using the boolean variables in other files?
what happens if at the top of the file you actually add the defines of true and false.
Had the same problem a couple of day's ago while trying to compile Dean's light weight ring buffer code.  Try adding #include <stdbool.h> above your main() function.
He said he had in #1. That's the mystery here. The whole point of stdbool is that it's supposed to make bool/true/false "standard" !
EDIT: oh wait a minute. Are we saying this code would not compile or simply that it has "red squiggles"? Red squiggle generators like Naggy, VassistX, etc are notorious for being over-zealous as often they can't process conditional headers. So these may simply be false positives.
I took "cannot be resolved" to imply "did not compile".
OP can tell us for sure.
My guess is that OP is wrong about #include-ing <stdbool.h>.
The symbol true would no longer be there.
Oh you are right - I think those icons in the left margin are Eclipse's standard way of annotating the source after a failed build to show where the compilation errors actually occurred. So the red squiggles really are red squiggles.
avr-gcc has a -H option that will list all header includes. This is it working in AS7:
The same could be applied to this compilation (assuming some form of GCC) to see exactly what headers it is finding. Maybe it is finding something called stdbool.h - just the wrong something?
Sorry I was not more specific.
I have an existing Project in Eclipse which contains a file with the main() function.  To become familiar with Dean's Light Weight Ring Buffer, I included that file (LightweightRingBuffer.h) in the existing Project's workspace and attempted a compile.  I received error message(s) that "true" (and Atomic_RestoreState) could not be found even though both #include <stdbool.h> (and #include <avr/atomic.h>) were included in Dean's  LightweightRightBuffer.h file.
On a whim (to give both #includes better visibility), I included both in the main() function's file and those error messages disappeared.
Alan
P.S. I'm using Eclipse in a Windows environment.  I suspect Fianawarrior is using Eclipse in a Linux environment so I'm not sure my solution will fix his problem.
         And yes, the bug symbol in the left margin marks the location of compilation errors.
         If an #include FILE cannot be found, the Eclipse editor will place a '?' in the left margin.
         Grayed out regions in preprocessor conditional branches indicate that they will not be included in a compile.
Hi allano, I have included stdbool.h in my main file.
It's not a problem, just wish I did not have files marked that are okay.
Sorry if I'm don't understand.  You still have a  problem?
When you say "wish I did not have files marked that are okay", do you have files in the Project Explorer (left pane) which are marked even though the project compiles?  Check the Console view after your build, it might tell you of something is wrong (which might be something like the project's code exceeded the .text region of the controller.)
Alan
Edit: grammar
Wish I knew how it compiled without resolving true.
If he still has bugs in the left margin of the editor as shown in post 1, it did not successfully compile.
But it does compile and run correctly.
So this was just a "red squiggles" thing then?
What usually happens with the "red squiggles" is that after correcting the problem (i.e. including <stdbool.h>), the "squiggles" will still be visible until you re-build the project.  Upon a successful compile, they go away.
FYI.  During code entry, if there is a syntax error, a question mark appears in the left margin. Putting focus on the question mark will provide the reason for the error. The question mark disappears when the syntax error is corrected.
Maybe try clean, then build?
true dat.
So that would be "rebuild" then?
I generally always use rebuild anyway - both for AVR/AS7 and for big_stuff/VS2017 to be sure there's no lurking unknowns from previous build history. Back when computers were slow you couldn't do this as a build god take 30..60 minutes but even for the big stuff I work on it's all done in about 5 minutes which gives me an opportunity to read Freaks ;-)
Fianawarrior,
I ran across your problem today.  When you have a residual error indication after a build and successful compile, select the project with that problem in the Project Explorer view  with your right mouse and select Index -> Rebuild
If that does not work, check your Windows Preferences as described in https://mcuoneclipse.com/2012/03/20/fixing-the-eclipse-index/ to see if those settings will fix your problem.
Alan
Edit: added words in orange for clarity
