Atmel Studio 7 debugging application with a non-default start address
7 posts / 0 new
I have two programs that are stored in flash on an Atmel AT32UCB0256 part (bootloader at 0x80000000 and application at 0x80010000). On AVR Studio 32 I could set the start address of the program in the Debug Configuration to debug the application that is located at the non-default location (0x80010000). I need to be able to start debugging at that address instead of the start of flash memory (bypassing the bootloader).
I asked this question way back in Oct 28, 2011 but never received a useful reply and was forced to continue using AVR Studio 32 because of this one problem. (reference: https://www.avrfreaks.net/forum/...)
How do I do this in Atmel Studio 7? I can't find any of these controls in the debugging settings.
Thank you for any help you can provide.
Maybe not the answer you want but I would put a breakpoint where the program usually start and then "Set next statement" wherever you want and continue from there.
Thank you for the reply. The problem is it starts running the boot loader and I don't appear to be able to make it stop at a breakpoint there. I can set the breakpoint at address 0x80000000 but when I start debugging it doesn't actually stop. Perhaps it is because that address is not within the addresses defined for the app I am debugging (it starts at 0x80010000)?
The breakpoint needs to be at 0x0000 the REAL real start/reset address.
John, are you sure that's true for AVR32 ?
Thank you for your comment.
Trying to set a breakpoint at address 0 give the error "The breakpoint will not currently be hit. Unable to set requested breakpoint on target."
ooops I didn't see the UC3 bit blush senility kicking in fast.
Edit so I found some UC3 info
After reset has been released, the AVR32 UC CPU starts fetching instructions from the reset address, which is 0x8000_0000. This address points to the first address in the internal Flash
the principle should be the same, try to put a breakpoint at 0x8000_0000, does it work there? Then you should be able to set next statement to wherever you need to.
But I have never used a UC3 beast and don't even have a simple led flash program that I could try out.
