gcc, libc for atmega4809 ?
13 posts / 0 new
I'm on linux, and prefer to use classic unix tools to cross compile for AVR.
My linux distro comes with avr-gcc 5.4.0, avr-libc-2.0.0, etc.
Has anyone found a way to cross-compile to the 4809?   I have tried stuffing the associated spec file from microchip "pack" into the installed gcc/libc but it's not working.
$ make
avr-gcc -DF_CPU=16000000 -mmcu=atmega4809 -Os  -o main.elf main.c
main.c:1:0: error: unknown core architecture 'avrxmega3' specified with '-mmcu='
 #include <util/delay.h>
main.c:1:0: note: supported core architectures: avr2 avr25 avr3 avr31 avr35 avr4
avr5 avr51 avr6 avrxmega2 avrxmega4 avrxmega5 avrxmega6 avrxmega7 avrtiny avr1
I can build gcc-8 and avr-libc from the sources, but I don't want to go down the trial-and-error path if someone else has the recipe already.
I don't see the -B in that you need when working with "packs"? Let me just build something in AS7 for 4809 and I'll show the build command to give you and idea.
EDIT: so...
		Invoking: AVR8/GNU C Compiler : 5.4.0
		"C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\avr8\avr8-gnu-toolchain\bin\avr-gcc.exe"  -x c -funsigned-char -funsigned-bitfields -DDEBUG -DFOO=3
                -I"C:\Program Files (x86)\Atmel\Studio\7.0\Packs\Atmel\ATmega_DFP\1.3.300\include"  -Og -ffunction-sections -fdata-sections -fpack-struct -fshort-enums
                -g2 -Wall -pedantic -mmcu=atmega4809 -B "C:\Program Files (x86)\Atmel\Studio\7.0\Packs\Atmel\ATmega_DFP\1.3.300\gcc\dev\atmega4809"
                -c -std=gnu99 -H -save-temps -MD -MP -MF "main.d" -MT"main.d" -MT"main.o"   -o "main.o" ".././main.c"
You need a similar kind of -B to say where your 4809 pack in unpacked.
... but if your version of gcc does not have the xmega3 architecture, then ... you need a version of gcc that knows about it :)
:: Morten
He said 5.4.0 - are there some 5.4.0 that do know xmega3 and some that don't? How confusing!
Assuming it does need an "Atmel special" then I guess he needs "AVR Toolchain for Linux" from this page...  https://www.microchip.com/mplab/avr-support/avr-and-arm-toolchains-c-compilers
... I don't know when xmega3 came into life...
:: Morten
A long long time ago in a place far far away.
EDIT And more specifically:  http://sourceware.org/git/gitweb.cgi?p=binutils-gdb.git;a=history;f=ld/emulparams/avrxmega3.sh;hb=9ddc1af18c31e775ae7b107779addfcde92c723f
So it looks like it's been around since 2011
Use GCC v8+, Binutils v2.29+ and avr-libc from SVN trunk.
You should be able to copy the libraries from the Atmel "Packs", using a procedure similar to the one described here:  https://www.avrfreaks.net/comment/2526416#comment-2526416
Thanks all.  I'm taking a shot at building from source, using svn-repo for avr-libc.  I'll let you know how it goes.
I have gcc-8.3.0 build running pretty far but still some issues.   Looking to build from source and add reference to files from the pack (1.3.300).  I will post when/if I get to completion.
I have something working.  I have posted instruction in a thread here
int main(void) {
  PORTF.DIR = 5;
  for (;;) {
    PORTF.OUT |= PIN5_bm;
    _delay_ms(100);
    PORTF.OUT &= ~PIN5_bm;
    _delay_ms(100);
$ avr-gcc -v -DF_CPU=16000000 -mmcu=atmega4809 -Os -B/opt/local/avr/packs/1.3.300 -B/opt/local/avr/packs/1.3.300/lib/avrxmega3 -o main.elf main.c
Using built-in specs.
Reading specs from /opt/local/avr/packs/1.3.300/device-specs/specs-atmega4809
rename spec link to old_link
COLLECT_GCC=avr-gcc
COLLECT_LTO_WRAPPER=/opt/local/libexec/gcc/avr/8.3.0/lto-wrapper
Target: avr
Configured with: ../gcc-8.3.0/configure --prefix=/opt/local --program-prefix=avr- --enable-languages=c,c++ --target=avr
Thread model: single
gcc version 8.3.0 (GCC)
COLLECT_GCC_OPTIONS='-v' '-D' 'F_CPU=16000000'  '-Os' '-B' '/opt/local/avr/packs/1.3.300' '-B' '/opt/local/avr/packs/1.3.300/lib/avrxmega3' '-o' 'main.elf' '-specs=device-specs/specs-atmega4809' '-mmcu=avrxmega3'
 /opt/local/libexec/gcc/avr/8.3.0/cc1 -quiet -v -imultilib avrxmega3 -isystem /opt/local/avr/packs/1.3.300/include -D__AVR_ATmega4809__ -D__AVR_DEVICE_NAME__=atmega4809 -D__AVR_DEV_LIB_NAME__=m4809 -D F_CPU=16000000 main.c -mn-flash=1 -mno-skip-bug -quiet -dumpbase main.c -mmcu=avrxmega3 -auxbase main -Os -version -o /tmp/cc7884tm.s
GNU C17 (GCC) version 8.3.0 (avr)
	compiled by GNU C version 7.4.0, GMP version 6.1.0, MPFR version 3.1.4, MPC version 1.0.3, isl version isl-0.18-GMP
GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072
ignoring nonexistent directory "/opt/local/lib/gcc/avr/8.3.0/../../../../avr/sys-include"
#include "..." search starts here:
#include <...> search starts here:
 /opt/local/lib/gcc/avr/8.3.0/include
 /opt/local/lib/gcc/avr/8.3.0/include-fixed
 /opt/local/lib/gcc/avr/8.3.0/../../../../avr/include
End of search list.
Compiler executable checksum: e754341fb6d4a88f2a771fea0aa442b1
 /opt/local/lib/gcc/avr/8.3.0/../../../../avr/bin/as -mmcu=avrxmega3 -mno-skip-bug -o /tmp/cch0dTbH.o /tmp/cc7884tm.s
COMPILER_PATH=/opt/local/avr/packs/1.3.300/:/opt/local/avr/packs/1.3.300/lib/avrxmega3/:/opt/local/libexec/gcc/avr/8.3.0/:/opt/local/libexec/gcc/avr/8.3.0/:/opt/local/libexec/gcc/avr/:/opt/local/lib/gcc/avr/8.3.0/:/opt/local/lib/gcc/avr/:/opt/local/lib/gcc/avr/8.3.0/../../../../avr/bin/
LIBRARY_PATH=/opt/local/lib/gcc/avr/8.3.0/avrxmega3/:/opt/local/lib/gcc/avr/8.3.0/../../../../avr/lib/avrxmega3/:/opt/local/avr/packs/1.3.300/:/opt/local/avr/packs/1.3.300/lib/avrxmega3/:/opt/local/lib/gcc/avr/8.3.0/:/opt/local/lib/gcc/avr/8.3.0/../../../../avr/lib/
 /opt/local/libexec/gcc/avr/8.3.0/collect2 -plugin /opt/local/libexec/gcc/avr/8.3.0/liblto_plugin.so -plugin-opt=/opt/local/libexec/gcc/avr/8.3.0/lto-wrapper -plugin-opt=-fresolution=/tmp/ccrCsnU1.res -plugin-opt=-pass-through=-lgcc -plugin-opt=-pass-through=-lm -plugin-opt=-pass-through=-lc -plugin-opt=-pass-through=-latmega4809 -mavrxmega3 -Tdata 0x802800 --defsym=__RODATA_PM_OFFSET__=0x4000 -o main.elf /opt/local/avr/packs/1.3.300/lib/avrxmega3/crtatmega4809.o -L/opt/local/lib/gcc/avr/8.3.0/avrxmega3 -L/opt/local/lib/gcc/avr/8.3.0/../../../../avr/lib/avrxmega3 -L/opt/local/avr/packs/1.3.300 -L/opt/local/avr/packs/1.3.300/lib/avrxmega3 -L/opt/local/lib/gcc/avr/8.3.0 -L/opt/local/lib/gcc/avr/8.3.0/../../../../avr/lib /tmp/cch0dTbH.o --start-group -lgcc -lm -lc -latmega4809 --end-group
  PORTF.DIR = 5;
That should probably be:
  PORTF.DIR = PIN5_bm;
better:
int main(void) {
  PORTF.DIRSET = PIN5_bm;
  for (;;) {
    PORTF.OUTTGL = PIN5_bm;
    _delay_ms(100);
I wonder what "PORTF.DIRSET |= PIN5_bm;" does?  Probably exactly what it says, which is probably not what anyone wants!
So many ways to do the same thing!  Whee!
Doesn't work.  Thanks for the updated code.  That is working.   I have a verified 4809 compiler working now.
