how to verify CPU is going to sleep?
17 posts / 0 new
I have a demo to use a timer interrupt to wake up the CPU and toggle a pin to blink the LED on my Arduino Uno 3.
Is there a way to verify the processor is sleeping?   The led does flash as expected, and my (home coded) simulator says it's sleeping.
/* demo to delay using timer interupt */
#include <avr/interrupt.h>
#include <avr/sleep.h>
/* Tune CLKSEL, OCRTOP, CTRDIV to give 1 msec delay. */
#if F_CPU == 20000000
#define DELAY_CLKSEL 5
#define DELAY_OCRTOP 39
#define DELAY_CNTDIV 2
#elif F_CPU == 16000000
#define DELAY_CLKSEL 4
#define DELAY_OCRTOP 125
#define DELAY_CTRDIV 2
#elif F_CPU == 8000000
#define DELAY_CTRDIV 4
#elif F_CPU == 1000000
#define DELAY_CLKSEL 3
#define DELAY_OCRTOP 8
#else
#error "unhandled DELAY for F_CPU"
#endif
volatile uint8_t wait_ctr;
volatile uint8_t wait_flg;
/* Wake up main on wait_val transition from one to zero. */
ISR(TIMER0_COMPA_vect) {
  if (wait_ctr != 0) {
    wait_ctr -= 1;
    if (wait_ctr == 0) {
      wait_flg = 0;
void my_delay_ms(uint16_t ms) {
  wait_flg = 1;
  wait_ctr = ms/DELAY_CTRDIV;
  while (wait_flg) {
    sleep_cpu();
void my_timer0_setup(void) {
  wait_ctr = 0;
  TCCR0A = 0x02;		    	/* CTC mode */
  TCCR0B = DELAY_CLKSEL;		/* set up  */
  OCR0A = DELAY_OCRTOP;			/*   for 1 msec delay */
  TIMSK0 |= _BV(OCIE0A);		/* enable timer0/A interrupt */
int main(void) {
  my_timer0_setup();
  sleep_enable();
  sei();
  DDRB |= _BV(DDB5);
  PORTB |= PORTB5;
  for (;;) {
    PINB = _BV(PINB5);
    my_delay_ms(100);
/* --- last line --- */
EDIT: wait_ctr should be declared uint16_t
Yes (ammeter)
The AVR's current will be proportional to CPU current plus the peripheral current (megaAVR - power reduction register, XMEGA AVR - one general power reduction register plus one power reduction register per port) plus current through the pins.
Arduino Uno Rev3
    You can use a delay function to toggle a pin. When CPU sleeps, the delay is longer.
That sounds promising.  Thanks.
I was going to say "measure the current" but with a low sleep mode and 1ms delay, might be hard to measure.
Give some power budget numbers -- what do you expect to save in a low sleep mode with peripherals running and awakening every millisecond?
You can put a small resistor in the Vcc or GND line, which has a voltage drop of around 100mV during normal operation.
Then you can measure the ripple over that resistor with an oscilloscope.
The advantage of having such a shunt permanent in place is that it's small enough to never have to take it out of your development board, and 100mV is low enough to not cause any trobles for the uC, unless it's normally operating very near to it's minimum (brownout!).
Make sure to put the decoupling capacitor on the uC side of the shunt.
Back in the '70s & '80's  this was used by some engineers to detect latchup in cmos logic, or even balanced in such a way that if latchup occured, the chip did not get hot enough to destroy itself.
For better measurement it also helps to reduce current consumption to I/O of the uC. For example do not switch a LED from the uC pin directly, but put a transistor between the uC and the LED, so the LED current won't show up over your shunt resistor.
More specifically, you put the pin-toggle right next to the sleep command, polling loop.
If the part is not sleeping, the loop is running at full speed and pin toggle will be in low microseconds region.
If the part sleeps and wake on a slow interrupt, that shows in a much lower pin toggle rate.
You can comment/uncomment the sleep to confirm that change.
Here is what I did.   Recoded so that the interrupt is around 4 ms.   Then in the spin-loop I toggle a PORTD pin, wait 1 ms, toggle, wait 1ms.  Now, if the sleep works, then the port should stay unchanged for 2 more ms, giving a 25% or 75% duty cycle.  If the sleep is not working, then the spin loop will go again making the duty cycle 50%.     Below is (1) updated code (w/ sleep enabled), (2) scope trace for sleeping case, (3) scope trace for non-sleeping case.   (For the non-sleeping run I commented out the sleep_enable(); line of code.)
#include <util/delay.h>
#if F_CPU == 16000000
#define DELAY_OCRTOP 250
#else
#endif
volatile uint16_t wait_ctr;
    wait_ctr -= 1;
      wait_flg = 0;
  wait_flg = 1;
  /* if sleep working for 16 MHz this will wake up every 4 ms */
  while (wait_flg) {
    PIND |= _BV(PIND5);
    _delay_ms(1);
    PIND |= _BV(PIND5);
    _delay_ms(1);
    sleep_cpu();
  wait_ctr = 0;
int main(void) {
  my_timer0_setup();
  sleep_enable();
  sei();
  DDRB |= _BV(DDB5);
  DDRD |= _BV(DDD5);
  for (;;) {
    PINB = _BV(PINB5);
    my_delay_ms(100);
using an oscilloscope is a good idea. However, recently I got the chance to get a digital multimeter Keysight 34465A:
I can tell you, this thing is absolutly incredible. sometimes you never know if your program is really in power-down or "sleep mode" and with a digital multimeter this shows you whats behind...
Sorry I dont have a comment on your code but i thought this might help..
Do you sleep with that thing, Moe?
Nah not really ;), but it show me if my thing is really sleeping or not ;). Its a bit expensive actually (1078 EUR)...you can go down to nA....
Dang. I would! It's worth more than my car. Hmm. My toy train is worth more than my car.
I was just thinking I miss those 9 digit fluke meters of the early 80's. Bet they were pricey.
"We trained hard... but it seemed that every time we were beginning to form up into a team, we would be reorganized. I was to learn later in life that we tend to meet any new situation by reorganizing. And a wonderful method it can be of creating the illusion of progress while producing confusion, inefficiency and demoralization." Petronius Arbiter, approx. 2000 years ago.
Like any shunt resistor, ammeters have a higher shunt resistance when in lower current mode. You can see if the micro is sleeping with a regular shunt resistor. However, if you want to actually measure the current consumption in mA range while running and with the same scale while in power down mode with currents under 1µA, than it is a challenge.
So you want to compare a regular shunt resistor with the 34465A ?!
LOL@Torby
Btw, How is it with the storm ??
Moe123 wrote:
LOL@Torby
Torby wrote:
Moe123 wrote:
LOL@Torby
