Electric motors sheet metal stack construction properties
19 posts / 0 new
I am curious as to why many electric motor stators or rotors are constructed from a "sandwich" of sheet metal stampings.
For instance: does the layer to layer electric isolation help reduce the induced currents on the components?
For what properties is it chosen that stators and rotors are constructed with this technique?
TO THE FINDER... THE ISLE OF KOHOLINT, IS BUT AN ILLUSION... HUMAN, MONSTER, SEA, SKY... A SCENE ON THE LID OF A SLEEPER'S EYE... AWAKE THE DREAMER, AND KOHOLINT WILL VANISH MUCH LIKE A BUBBLE ON A NEEDLE... CAST-AWAY, YOU SHOULD KNOW THE TRUTH!
The (varnished) sheets reduce eddy currents.   Without that the eddy currents would suck up power and generate heat.
Matt has it right.
You can see some nice motor being made--they mention the current loss
https://www.youtube.com/watch?v=CBFE-Bt7RjY
Very helpful, thank you all
This brings a question to my mind. In the case of inductors, the eddy currents are reduced by using several materials, like ferrites (which have inherent low conductivity), powdered iron and laminated iron (which are coated by some insulator). But in the case of motors it's almost always laminated iron.
Is there a reason for this? Maybe mechanical, since ferrites are brittle?
Something I've red in the last couple of days said that it's Silicon Iron used in such places. And a Wikipedia search would tend to confirm this...
https://en.wikipedia.org/wiki/El...
While reading the silicon iron wiki article, I came upon a magnetic material I didn't know, amorphous iron. Interesting.
It's used in transformers, but using it for motors is apparently cutting edge tech:
https://www.machinedesign.com/mo...
https://www.hitachi.com/rd/porta...
I love learning stuff from random dives in Wiki articles yes
Same here. But I also have this bookshelf in the smallest room in the house to keep my brain active...
Silicone impregnated steel (iron) limits your hysteresis losses, which is from the magnetic poles flipping back and forth when exposed to an ac field the laminate them to prevent eddy currents.
If you made a motor without laminated sheets, the motor would probably melt down due to the heat from eddy currents
That book in the middle "How to lie with Statistics" sounds interesting!   devil
Interesting book collection... So were you able to fossilize your hamster?
Thankfully not. He's alive and well. In fact, as I type this, he's just climbed out of his house and is heading towards the kitchen.
That's a classic! I remember professors quoting that book.
It's easily observed that more than half of the population is below average when it comes to being fooled by statistics!
Ferrite has been used in 3-phase Brushless Permanent Magnet motors for quite awhile now.  If you take apart your desktop computer's fan motor, you won't find stacked laminations.  It's hardly new and cutting edge anymore, whatever Hitachi would like to say about it.  S.
... would you like to correct that statement? (my emphasis added)
Actually it's perfectly normal, because there is a difference between average (as in arithmetic mean) and median.
This often happens when a variable has a minimum possible value, like zero, but no upper limit. Income is a good example.
We probably need a topic split a few posts back, but it's a fact that most of the people on this planet have an above average number of feet.
