find dead code in code compiled in amtel studio
13 posts / 0 new
trying to clean up my code a bit.
anyone know if there is any easy way in atmel studio to find "dead code"?
what I mean with dead code is for example dead function declarations :
void something used();
void somethingnotused();
or other other simular things. that is unnecessary code that makes the code harder to read and adds pointless complexity.
any one know if there is any easy way to find these or other simular things in atmel studio?
Atmel studio don't give a warning for such things I have noticed.
Go to your main routine...check which functions are called...dig a bit in your code...you will find the unnecessary functions.
its a bit manual work...
Just switch on -ffunction-sections and -gc-sections (which are on by default in AS7 projects) and all dead code will be garbage collected during the link anyway (and the map file will list what was discarded)
I didnt know such thing existed in AS7, Thanks
yes, it just seems like something that a program can do faster and better than a person
ok, great. I will check it out. thanks!
The way function sections / gc sections works is that every function is built into separated named flash sections. The linker then only includes in the link any section with a reference counter of 1 or more. Any with 0 reference are garbage collected.
Some dead code is dead because it can never be logically executed & can be tough to spot
somewhere in the program:   if Motor A is running faster then 500 RPM, call calibrate valveb
valveb cal:  If motor is running faster then 300 rpm skip cal
 This may not be such a solid example, but gives the flavor.
Some static analyzers can detect that by data flow analysis akin to detection of inadvertent infinite loops (control flow analysis)
I wonder how advanced it gets...needs to be like a good chess program to analyze all of the paths & probably include advanced logic minimization.
I gave students a non-trivial circuit full of gates to build...later showed them the equivalent circuit was two pieces of wire.
Some years back I was a place that used Klocwork and it can really analyze your code.
Cheers!, Thanks for this Appnote.
