Re-formatting an unrecognised SD card
16 posts / 0 new
I have several microSD cards that have been corrupted.   (probably by me)
They are not recognised as disks.
I don't care about losing the data.   I would just like to recover them for continued use.
I have Windows7 and Windows10.
I guess that everything would be easy with Linux but I can't be bothered to install Linux just for this job.
I have had the same problem and the only solution I have is to use my Mac Mini's Disk utilities.  Works like a champ every time.
SD Association has a formatter :
https://www.avrfreaks.net/forum/fatfs-and-disk-removal#comment-2645466
Using this can sometimes recover bricked SD cards.
Hopefully the PC's SD controller will recognize the SD card's controller.
edit : quote
david.prentice wrote:
...  but I can't be bothered to install Linux just for this job.
Likely is the "Live" instance of your preferred Linux distribution (on DVD or USB drive)
edit : https://www.osdisc.com/products/linux/usb/64bit/live/systemutilities
David,
Were you able to recover the SD cards?  If so, what worked?
Alan
No.   When I saw that a new message had been posted,   I hoped that this was going to be a solution.
There must be lots of Windows Users with damaged SD cards.
I am sure that there is a simple procedure.
Can you see it in Windows Disk Management?
Are they recognized by SD Formatter?
One of the options is to completely over-write before formatting. I presume this includes the FAT. If so, then it has to recreate all that from scratch. Question is: can it do that on a card that it does not recognize as a valid "disk" at the start.
Are you attempting to re-format using one of those USB universal memory card contraptions ? I've found they can be quite iffy when formatting cards, whereas the built-in SD Card slot on my Dell laptop works perfectly.
The question is, is he using Disk Management?   If the thing is corrupted it probably won't show up in File Explorer.  File Explorer only shows partitions that have drive letters.
N.Winterbottom wrote:
... whereas the built-in SD Card slot on my Dell laptop works perfectly.
Realtek Memory Card Reader Driver | Driver Details | Dell US
Card Reader Controllers - REALTEK
edit : an alternate way is via the SoC's SD controller (Raspberry Pi)
BCM2835 ARM Peripherals
(page 65)
5 External Mass Media Controller
edit2 : A20-OLinuXino-LIME2-UM.pdf (page 26, 6.2 MicroSD card connector) via A20-OLinuXino-LIME2 - Open Source Hardware Board
I had some USB memory sticks that were showing similar signs of death. It was actually some utility from hp.com that resurrected them. Long time ago though, cant remember other details.
Are all you guys using alien software telling me that Disk Management wouldn't fix the problem, or maybe you think it's too easy?
I don't use windows but when I googled I came up with "DISKPART" command.
yeah we're talking about memory devices that have got into such a confused state that a normal format won't fix them. They need a special kind of "internal" format that the standard tools in Windows and Linux know nothing about.
Bill Greiman has written an example sketch that he provides with his Arduino SdFat.h library.
This displays the configuration details of the Card controller
As well as the Filesystem that might be installed on Partitions in the Master Boot Record.
This gives clues as to why the O.S. does not recognise the SD card as an "external device"
Having wasted a bit of time attempting to write my own "Sdinfo" utility I feel at little foolish.   The sketch was already on my PC !!
I have one microSD that will not even talk to the disk controller.   I regard this as beyond repair.
Other SDs have some "unlikely" configurations.   These might be recoverable.
I have not attempted anything yet.   I will leave that to another day.
There is also a SdFormatter sketch.
