scope issue
6 posts / 0 new
Hi All,
Have not done electronics in decades.    Bought a cheap scope: Hantek DSO5072P, which came with two probes.
I was working with it today to debug UNO 3 stepper motor project.  I'm now getting a funky trace for what should be a 1 kHz sample trigger.
It turns out to be the probe.   Any idea what this is?  It the probe fried?  The label on the probe says
PP-90
80MHz/6MHz
10X-600Vpk
1x-200Vpk
CAT II
I have had it set to 10x.
Matt
Fixed.  It needed the probe compensation pot  to be adjusted.  But this blew me away.  I've never seen it that "off square".
A square wave can also look like that if you
accidentally select AC coupling instead of DC.
--Mike
--Mike
Thanks.  Good to know.
Always use DC coupling unless you NEED to use AC coupling
Yes! First you hang the probe on the "calibrate" bar and adjust the probe compensation to get a nice square wave. Then you check your signals.
