Is Cap on AREF really needed?
17 posts / 0 new
I am using a ATMEGA328 on a portable device and am reading the Battery level agains the internal 1.1V reference.
I have AREF connected directly to VCC (a 3V battery) and are getting good readings.  I know that the data sheet says you should connect AREF to a cap.
Is Cap on AREF really needed in my case?
-alx
alxgarza wrote:
I know that the data sheet says you should connect AREF to a cap. Is Cap on AREF really needed in my case?
Not quite true. It says that you can use a cap to improve the pins immunity to noise, not that you have to.
The datasheet says, "The internal voltage reference
must be decoupled by an external capacitor at the
AREF pin to improve noise immunity."  Emphasis
added.
--Mike
EDIT: I have seen different language saying it's an
optional thing, but the above quote is from the 2018
datasheet with file name DS40001984A
If you are using the ADC to measure an analog signal, and small, (e.g. mV range), signal variation is important, then YES, use the Cap, or better yet put an LC filter on AVcc and use the cap on ARef.
As +/- a few counts (mV) likely doesn't matter when reading the battery voltage, you can likely get away without using it.
Now the real question: Why would you not use it?
If you are selling 100K units of kids toys, then skip it.
If you are doing anything else then include the cap if you are using the analog circuitry.
A cap is dirt cheap, and it improves the analog module's performance.
Note, BTW, that the cap on ARef is different from the By-Pass caps on the Vcc/Ground and AVcc/Ground pins.
Those ARE required for proper performance of the micro.
The ARef cap is in a separate category, as noted above, and is pseudo-required when using the analog circuitry, not required otherwise.
Currently I'm reading the battery level (3v battery) and displaying it in 5 steps.  So I don't need accurate readings.
And I have AREF connected to VCC.
So what would be a good design?  Leave it as it is (AREF connected to VCC) or have de decoupling cap in AREF?
Thanks for your comments.
-alx
No, AREF should just have a capacitor to
ground.  Its voltage may be different than
Vcc so connecting them could damage the
chip.  You can connect AVcc directly to Vcc.
--Mike
added.
He is not using the internal voltage reference.
This would be my cheap solution:
You anyway have a cap on VCC / AVCC, so it would be OK. If you want better results, then have a separate cap for AVCC (with a series resistor / inductor).
--Mike
It is OK as long as he never sets REFS1:FES0 to b11. If it would be a problem, then no external voltage reference higher than 1.1V would be allowed, which is not the case.
EDIT: added "higher than 1.1V"
The battery is the big cap.
+1
But with that mux and FET between Vcc and ARef, there is resistance present. That means that the resistance at that point is NOT the battery resistance (which, especially as it gets discharged, might not be THAT low).
The simple answer is: there is no one answer that fits all. If you want good ADC performance, add the cap. If your thing is just a "piece of cheap sh*t", then don't bother.
Have you missed the point that the discussion is about tying AREF to AVCC and VCC ? It saves one capacitor, which is naturally replaced by the battery.
And I already have a .1µf cap at VCC.
-alx
This cap is less than 1/2 cent at Digikey , in thousands. (200 for a dollar) ..just put it in & spend your time looking for Bigfoot.
CAP CER 10000PF 50V X7R 0402
1276-1028-1-ND
Well... If you're not doing any analog work, or if the analog performance is good enough for you, you can skip the cap. As for me, an SMD cap is so small and so cheap, put it on anything where I want to use the analog features, and most things where I don't.
"We trained hard... but it seemed that every time we were beginning to form up into a team, we would be reorganized. I was to learn later in life that we tend to meet any new situation by reorganizing. And a wonderful method it can be of creating the illusion of progress while producing confusion, inefficiency and demoralization." Petronius Arbiter, approx. 2000 years ago.
I worry about things like this.  If REFS gets set
wrong, somehow, in software, the hardware can
get damaged.  Adding one capacitor protects it.
--Mike
