atsam4s xplained pro
2 posts / 0 new
Hello, I am having an issue with writing into into the register SPI_CR(for that matter any register). I cannot write into the register.  I am new to Atmel and i dont how it works in this controller. Here is my code
#include "sam.h"
//ptr = (unsigned int *)(0x40008000);
unsigned int *ptr;
unsigned int data;
    /* Initialize the SAM system */
    SystemInit();
	ptr = (unsigned int *) REG_SPI_CR;
	*ptr = 0x0000FFFF;
	data =*ptr;
Any help will be apreciated. Thanks
If you really need a pointer to the register it would be
ptr = &REG_SPI_CR;
(hint: don't cast, make the ptr a type that makes you program compile without warnings).
But normally you just write
REG_SPI_CR = value;
or
SPI->SPI_CR = value;
BTW the value 0xFFFF does not make any sense for this register and it is a write only register.
/Lars
