i2c GPIO expansion IC advice
25 posts / 0 new
Hi All
I got a little issue.
I need to control 5 latching relays, via a H-Bridge IC. This would mean, i would need about 7 GPIO, which are the 5 enables and 2 H-bridge control lines for the DRV8837C. My AVR does not have any spare.
My main PCB has a spare port, which has only VCC(5V),GND, and UART TX and UART RX.
I am thinking of using the tca9534a and controlling it using a software i2c libary. If i am correct there are i2s software based libaries for AVR?
The other option is using a UART to GPIO IC, if there is any?
Would there be any issue with this, as i would like to avoid using another AVR just to control extra GPIO for my relays.
Please advice
Regards
DJ
not an answer as the following was for a mega32U4 with an I2C port expander in the Arduino IDE.
ControLeo/ControLeo at master · engineertype/ControLeo · GitHub
MCP23008 - Interface - Interface- Serial Peripherals - 8-Bit I2C I/O Expander with Serial Interface
via Whizoo.com (reflow oven controller)
Google Peter Fleury. He has what i consider the finest I2C library on the net
What AVR are you using?   You may be able to use the USART in master spi mode if supported.
Thanks I will
Regards
DJ
I am using Atxmega256a3bu, pins PC2 and 3.
Regards
DJ
Scratch Peter Fleury if you are using an XMEGA
JIm
Keep in mind that small MCUs these days can cost less than an i2c expander  (yes, that's nuts but is shows what volumes can do...)
Digikey has search engine that lets you scan
Interface - I/O Expanders  with choice of  IO count
and
Embedded - Microcontrollers with choice of  IO count
Thanks i will use Peter Fleury's library.
I could use another AVR, but want to avoid programming multiple devices especially for simple operations.
Regards
DJ
I have downloaded the  Peter Fleury's library from  http://homepage.hispeed.ch/peterfleury/avr-software.html
Is this meant to be a software(bit-bash) library?  As it seems that it is trying to read certain AVR registers such as TWCR.
Regards
DJ
The Fleury software has two libs, one is bit bang to any two i/o pins, the other uses the TWI, but will not work on xmega!
An alternative to I2C, the USARTs on the xmega support master spi operation, so use a shift register or spi i/0 expander ic for your i/o expansion, very easy to do and fast too.
I am using the atxmega256a3bu and my i2c device is connected to port c pin 2 and 3. SDA connects to the TX pin and SCL connects to SCL pin.
Is there any example of how to make this port SPI? I have never used an UART as a SPI
Regards
DJ
That device does not have an SPI engine? I thought all Xmegas have one.
When you mention it will not work in XMEGA , is that for both libraries or just TWI?
Regards
DJ
SO i guess bitbashing i2c is the only option.
Regards
DJ
If you read the datasheet for the xmega you called out you will see that the device has tqo spi engines built in
Yes, but the only pin i have access to the uart pins and the PCB already made. We need to control that device , or at least setting the output pins
Regards
DJ
Read the DS USART section on master spi mode.
For that to work, you will need one pin for SS, perhaps the RXD pin can be used for that.
Well that certainly sucks for you doesn't it? Ouch
Are the two sets of spi pins being used already?
I wpuld think it easier to implement bit bashed spi. Over i2c. A freak did it for me years ago in assembler i think. I would think it also easy to do in c as well.
No sweat, here it is!
So is my only option the bitbash of i2c?
Regards
DJ
I found the following example of getting it to work with XMEGA, by using virtual ports.
http://nickdademo.blogspot.com/2011/03/how-to-peter-fleury-i2c-driver-and-avr.html
Has anyone tried this?
Regards
DJ
Just use a tiny102  or tiny 104 as an expander...it has a uart built in to rcv your commands  & transmit any responses....just hook rx to tx, & tx to rx  & away you go with io, and even other measurements.
I'm confused, do you want i2c (2 wires open drain) or SPI (3-4 wires, MISO/MOSI/SCK/CS)
i2c in software should be fairly portable, if you can configure the pins to open-drain.
If the MCU cannot manage open-drain, but has data-direction,  you can modulate the data direction to emulate open drain.
Hi. Thanks
i have manged to get a quick solution, instead of bit bashing with the the gpio pins.
I simply made , the GPIO input and shorted them to i2c pin on the same board.
I think the next revision of the PCB, will now have a extra i2c header connector.
I wanted the PCB to look neat with not wire modes, but i guess this was required.
Regards
DJ
