ATtiny3217 programming and development
27 posts / 0 new
I have been  doing a fair amount of research before starting a new project and have decided that the ATtiny3217 seems to be the most powerful AVR device for it's size and price-point. I have developed and programmed for AVRs based on the ISP programming standard using AVRDUDE on the raspberry Pi. The ATtiny3217 however seems to use an interface called UPDI. I have looked into the protocol and the Atmel-ICE programmer seems to be able to do the trick but runs for about $200CAD which is a lot more than I would like to spend on this project. There isn't a lot of information available online about the chip yet as it has only officially been on the market since last November. Do any of you know of alternative programmers that could save me the financial burden of Atmel's programmer?
You local friendly BITTWIDDLER,
-Slams
Slams256 wrote:
... The ATtiny3217 however seems to use an interface called UPDI. I have looked into the protocol and the Atmel-ICE programmer seems to be able to do the trick but runs for about $200CAD which is a lot more than I would like to spend on this project. There isn't a lot of information available online about the chip yet as it has only officially been on the market since last November. Do any of you know of alternative programmers that could save me the financial burden of Atmel's programmer?
Did you look at the Eval boards ?
I can see a ATTINY3217 XPLAINED PRO EVAL BRD, which should bring out the UPDI to allow external pgm ? - Check the SCH
There are Xplained boards that likely support UPDI too (but not for the 3217, and IIRC the smallest xplained PCBs did not make it easy to connect external MCUs )
You may want to look into the cheap Microchip SNAP programmer, unfortunately it seems that it doesn't play too well for a few users here.
Maybe the ATmega4809 Curiosity Nano would be a good option? It's not expensive.
The problem is, this MCU is from the AVR-0 series, so it's missing some peripherals, most notably the timer type D and the DAC. Other than this, it's similar to the tiny3217.
After a little more research it seems that the PICKIT 4 is also supported for programming/debugging of the ATtiny3217, at $70 on digikey. Seems like the most economical option, however doesn't appear to be tested 100%. It's frustrating that the tools aren't guaranteed to work for their own products. I read somewhere that someone had written a UPDI programmer in python on the RPi but am working in Atmel Studio and would ideally like to have a debugging interface as it seems to an integrated feature.
-Slams
Yep, I have one of those and didn't go too far, others have though.
I will consider looking into EVAL boards. I don't really like the idea, but may borrow portions of the schematic.
-Slams
The ATmega4809 does seem like a great option! I am designing an LED controller, so the more PWM outputs supported the better! The one thing I liked about the Tiny3217 was the cap-sense IO pins that I was looking to use as UI inputs. I could definitely look into a cap-sense IC however. I will need to sleep on this one.
-Slams
Then why not get the low cost MPLAB SNAP DEBUGGER/programmer, mentioned above, and try that ?
Or, if you just want to program with minimal hw: https://github.com/mraardvark/pyupdi
:: Morten
I just bought one a few weeks ago & was amazed the prices was so high...like $45!!!  ....I have a similar board for the mega328pb & those were more like $9.50...they both have programmers & debuggers...not sure why the $$$ difference.
The ATmega328PB Xplained Mini evaluation kit is a hardware platform for evaluating the ATmega328PB microcontroller (MCU). The evaluation kit comes with a fully integrated debugger that provides seamless integration with Atmel Studio.
AIl I need is the capability of the $10 board to dump some code into the chip & be able to connect to the pins.  I don't intend to do any debugging.
Yes, there is a jump for not much gain, but I think the debug on the more expensive one, is a little bit better.
The SNAP mentioned should be even better still, as it uses a HS-USB connection, and a 300MHz ARM as the local debug firmware host.
Agree with Morten's suggestion to use pyupdi ( https://github.com/mraardvark/pyupdi/ ) I have used this successfully on the raspberry pi as well.
Also think the mega4809 curiosity nano is a nice board, which can be used as an off-board UPDI programmer by cutting some straps, or wire up the CDC as a pyupdi adapter for external targets.
77CAD
Atmel-ICE-C Kit for debugging and programming Atmel SAM and AVR microcontroller 614961953789 | eBay
Atmel-ICE - Waveshare Wiki
https://github.com/ElTangas?tab=repositories
by El Tangas
El Tangas wrote:
[mega4809] ... and the DAC.
internal only, 8-bits, search for DACREF :
megaAVR 0-series FDS
in DIP for breadboard, protoboard, 1-layer PCB :
https://www.avrfreaks.net/forum/megaavr-0-series?page=3#comment-2682876
ATMEGA4809 - 8-bit AVR Microcontrollers - Microcontrollers and Processors
Slams256 wrote:
...  at $70 on digikey.
Likewise 70USD on eBay though with an added PIC capability.
MPLAB PICkit 4 adds Vpp (12V reset for UPDI on tinyAVR 0-series and 1-series, UPDI/RESET/IO)
IIRC, a PICkit 4 configured for EDBG will be visible in Atmel Studio 7.
Significant effort to verify for each AVR (will be awhile for MPLAB X v5)
https://www.avrfreaks.net/forum/come-join-us-mplab-now-supports-avrs?page=5#comment-2681761
I expect PICKit4 and SNAP to adequately support TINY-0, TINY-1, and MEGA-0 (will there be a MEGA-1?) *eventually*.  It's just that AVR support for Microchip programmers, the tiny-1, the SNAP and PK4 are all relatively new things, so it's not quite working yet.
assuming yes as USB megaAVR are "old"
USB PIC versus USB megaAVR :
  • no crystal vs crystal for USB full-speed
  • 32 endpoints vs 6
  • 1KB dual-port RAM vs 832B
USB PIC USART adds FBRG and auto-baud.
PIC18F45K50 - Microcontrollers and Processors
Hey,
I really appreciate all the help and discussion that this generated.
I want to get this project rolling asap so I picked up the SNAP programmer as it seems it will do what I require and I will be powering the board externally already.
I am quite interested in testing out morten & mraardvark's suggestion and will try this first but wanted to fall back onto something if I had any issues.
Once again, thanks for all the feedback and I will let you know how it goes.
-Slams
38USD minus 7.6USD
Dev Tool Deals | Microchip Technology
May Development Tool Deals
ATtiny3217 Xplained Pro (ATTINY3217-XPRO)
Use Coupon Code: TP1961
20% Off
https://octopart.com/search?q=ATTINY3217-XPRO
20% Off
Wish I had seen that! ...maybe I'll by another, just to feel good about saving 20%
Hi folks. In regards to the discussion above, I just wanted to share a few links that I think will be helpful to me:
Hey Guys,
I know its a really old thread.
Any updates on the RPi to Tiny programming with UPDI.
I tried the pyupdi option but ran into issues like initialization. No idea what it is. I can share my terminal output here but want to see if there is any tutorial or alternative available.
LOL... that's funny, because I just bought a snap... it doesn't work,  but at least I saved 30% ! smiley
Plexd wrote:
it doesn't work
did you remember to do the AVR mods to the Snap??
The probably best solution would be the ATTINY3217 Curiosity Nano. The price is the same as for all other Curiosity Nano boards for AVR.
For the final board, I agree with the suggestions for pyupdi, it's very easy to use.
