Power Plug Enclosure
3 posts / 0 new
Hi All
I would like to know if anyone know a smart power plug enclosure supplier or company?
Something similar to https://www.midselec.co.uk/smart-wifi-socket-single
I would like to control the power to an external device using a relay and it would be good if it can be encompassed into such enclosure type.
I would then need to make a small holes to the enclosure for the control lines for the relay.
Regards
DJ
Regards
DJ
sparkfun: https://www.sparkfun.com/product...
Has the relay and opto-iso circuit built in, so you just feed it a LV control signal.
Adafruit: https://www.adafruit.com/product...
similar product
I've seen it on amazon as well.
The sparkfun is not working, but will check on amazon as well.
It needs to be with UK plugs
Regards
DJ
