a small Pointers through Functions question from a noob.. please help
12 posts / 0 new
Hi
so I wrote some function ( or better say copied) for USART
I want to design a function that i pass to it a string or an array via pointers and it send it by usart
first .. my code :
 * Learn.c
 * Created: 3/15/2019 7:07:23 PM
 * Author : AbDoO_
#define F_CPU 1000000UL
#include <util/delay.h>
//ADC Vars :
unsigned int sensor_value,adh,adl;
//Conversion Vars :
unsigned char txt[6];
//USART Functions :
void Usart_Init(unsigned int USART_BAUDRATE);
void Usart_Write(unsigned char Data2Write);
unsigned char Usart_Read();
void int2str(unsigned int d);
	DDRB =0xff;
	DDRC =0x00;
	Usart_Init(4800);
	char x =0;
	ADCSRA |= (0 << ADPS2) | (1 << ADPS1) | (1 << ADPS0); // SET ADC PRESCALAR TO 8 - 125KHZ SAMPLE RATE @ 1MHZ
	ADMUX |= (1 << REFS0); // SET ADC REFERENCE TO AVCC
	//ADMUX |= (1 << ADLAR); // LEFT ADJUST ADC RESULT TO ALLOW EASY 8 BIT READING
	// NO MUX VALUES NEEDED TO BE CHANGED TO USE ADC0
	ADCSRA |= (1 << ADFR);  // SET ADC TO FREE-RUNNING MODE
	ADCSRA |= (1 << ADEN);  // ENABLE ADC
	ADCSRA |= (1 << ADSC);  // START A2D CONVERSIONS
    while (1)
		_delay_ms(100);
		adl= ADCL;
		adh = ADCH;
		sensor_value= (adh<<8) | adl ;
		int2str(sensor_value);
		// the code section i want to replace with a function
                x=0;
		while(txt[x] != 0 ){
			Usart_Write(txt[x]);
			x++;
		Usart_Write(0x0d);
	txt[0] = (d/10000) + 48 ;
	d = d - (d/10000)*10000;
	txt[1] = (d/1000) + 48 ;
	d = d - (d/1000)*1000;
	txt[2] = (d/100) + 48 ;
	d = d - (d/100)*100;
	txt[3] = (d/10) + 48 ;
	d = d - (d/10)*10;
	txt[4] = (d/1) + 48 ;
	d = d - (d/1)*1;
	txt[5] = 0;
	unsigned int BAUD_PRESCALE;
	BAUD_PRESCALE = (((F_CPU / (USART_BAUDRATE * 16UL))) - 1);
	UCSRB = (1 << RXEN) | (1 << TXEN); // Turn on the transmission and reception circuitry
	UBRRH = (BAUD_PRESCALE >> 8); // Load upper 8-bits of the baud rate value into the high byte of the UBRR register
	UBRRL = BAUD_PRESCALE; // Load lower 8-bits of the baud rate value into the low byte of the UBRR register
	while ((UCSRA & (1 << UDRE)) == 0) {}; // Do nothing until UDR is ready for more data to be written to it
	UDR = Data2Write;
	while((UCSRA & (1<<RXC)) == 0){};
	return UDR ;
the int2str() is for transferring the int value of the adc to a string so i can send it by usart
Every thing works 100 percent accept(but not) for some warnings that i ignored like :
"" Warning        array subscript has type 'char' [-Wchar-subscripts] ""
but the code works perfectly
i want another function  to do this part of the code
		x=0;
		while(txt[x] != 0 ){ // considering that every string sentence ends with a NULL or a 0
			x++;
		Usart_Write(0x0d); // add a line
But instead of the array "txt" i want a pointer so i can pass any array or string i want
i tried some thing like this
void Usart_Write_Text(unsigned int* p){ // i tried unsigned char also
    char x=0;
		while(p[x] != 0 ){ // I also tried useing *p instead of p
			Usart_Write(p[x]);// I also tried using *p instead of p
			x++;
		Usart_Write(0x0d);
Please you are free to copy any thing ,
please modify my Usart_Write_Text(..) function and make it work
NOTE:
i want to use it somehow like this :
Usart_Write_Text("HI test1 test 2 ");
Usart_Write_Text(txt); // or &txt you tell me
(SIDE QUESTION): is this considered a bad or a good question?( i mean forum) (so i can improve how i ask in the futuer )
THANKS ALOT
A Beam of Light out of the War
void Usart_Write(unsigned char c) {
  UDR0 = c;
void Usart_Write_Text(unsigned char *text) {
  unsigned char c;
  while ((c = *text++) != 0) {
    Usart_Write(c);
Thanks for replying
when using it should i write it
with the '&' sign or with out it ?
Usart_Write_Text(&txt); //the & sign ??
and what about that warning message i was getting
thanks for helping
Total votes: 2
void Usart_Write_Text(char *text) {
  while (*text) {
    Usart_Write(*text++);
Even simpler.
For an array, the array name is the pointer, so no & required.
Don't use `&'.   When the C compiler sees an array as function argument, it passes the pointer to the first element.   So foo(txt) is the same as foo(&txt[0]), but foo(&txt) can get you into trouble (if you mix arrays and pointers).
Exactly what it says -
you had char x = 0
then used x as an array subscript
p[x]
so the compiler was warning you. If you had int x = 0; then the compiler would not have issued a warning.
This is just because the C language standard does not specify if char is signed or not. This might cause unexpected errors when used as an array index, so the compiler is warning you to use a type which has a well defined sign, for example, unsigned char.
  while (*text) {
Even simpler.
Yup.  But this form can get you into trouble in cases where Usart_Write turns out to be a macro.
Macros can get you into a lot of trouble anyways. Just say 'no'!
        adl= ADCL;
		adh = ADCH;
		can be simplified to :
		int2str(ADC);   //let the compiler manage ADCH/L
and another stylistic issue:
	d = d - (d/10)*10;
	d = d - (d/1)*1;
	txt[5] = 0;
don't use magic numbers:
	txt[0] = (d/10000) + '0' ;
	txt[1] = (d/1000) + '0' ;
	txt[2] = (d/100) + '0' ;
	txt[3] = (d/10) + '0';
	d = d - (d/10)*10;
	txt[4] = (d/1) + '0' ;
	d = d - (d/1);
	txt[5] = 0;
avoid using globals:
void int2str(unsigned int d, char *str)
	str[0] = (d/10000) + '0' ;
	str[1] = (d/1000) + '0' ;
	str[2] = (d/100) + '0' ;
	str[3] = (d/10) + '0' ;
	d = d - (d/10)*10;
	str[4] = (d/1) + '0' ;
	d = d - (d/1)*1;
	str[5] = 0;
or simply use the itoa() function
ahh.. after typing unsigned char instead of char  the warning disappeared .. thanks you very much
dude this is pure gold.. thank you ..
but i googled about ( integer to string functions in c) alot but couldn't find any thing .. so i wrote that function
I would be very greatfull if you can provide a source for available functions or some kind of  a list
THANKS FOR ALL
I find cplusplus.com to be a good resource. The name C++ maybe suggests it only covers C++ but C is just a subset of C++ anyway so it is implicitly covered. In the C++ world the C version of the "standard" headers like stdio.h, stlib.h and so on are actually known as cstdio (no .h), cstdlib, etc. So you find things like:
http://www.cplusplus.com/reference/cstdlib/
http://www.cplusplus.com/reference/cstring/
etc.
For GCC there is also a manual for the C library that comes with it (generally known as "AVR-LibC") that you will find here:
https://www.nongnu.org/avr-libc/user-manual/modules.html
that has pages very similar (though not as much detail and few/any examples compared to cplusplus.com) such as:
https://www.nongnu.org/avr-libc/user-manual/group__avr__stdlib.html
https://www.nongnu.org/avr-libc/user-manual/group__avr__string.html
etc.
You will spot some things there that are not in the "standard" headers (as found at cplusplus) such as the fact that AVR-LibC has itoa():
https://www.nongnu.org/avr-libc/user-manual/group__avr__stdlib.html#gaa571de9e773dde59b0550a5ca4bd2f00
when this is not standard.
Bottom line - for anything in "standard C" I'd look at cplusplus.com, for anything very specific to avr-gcc I'd look at the AVR-LibC manual.
EDIT: actually it turns out that cplusplus also knows of the non-standard itoa():
http://www.cplusplus.com/reference/cstdlib/itoa/?kw=itoa
That surprises me because itoa() is not standard and there can be multiple interpretations for how it behaves. AVR-LibC and cplusplus both talk about an itoa() with 3 parameters where the 3rd is "radix" so by setting to 2, 10 or 16 (for example) you can have the result in binary, decimal or hex. But a compiler such as Codevision for AVR also has an itoa() but that one fixes the radix at 10 to make a simpler to call 2 parameter version with a fixed to decimal result.
