Weird error on bootloader code
7 posts / 0 new
I'm currently building a bootloader for my atmega4809 uC. When i use the standard bootloader as described in the manual, everything works fine when compiling the code.
But when i try to add some extra code, the bootloader doesn't compile.
I try to add a simple crc8 to the data that is send to the microcontroller. To make sure the right code is flashing on the uC.
 * Main boot function
 * Put in the constructors section (.ctors) to save Flash.
 * Naked attribute used since function prologue and epilogue is unused
__attribute__((naked)) __attribute__((section(".ctors"))) void boot(void)
	/* Initialize system for AVR GCC support, expects r1 = 0 */
	asm volatile("clr r1");
	/* Check if entering application or continuing to bootloader */
	if(!is_bootloader_requested()) {
		/* Enable Boot Section Lock */
		NVMCTRL.CTRLB = NVMCTRL_BOOTLOCK_bm;
		/* Go to application, located immediately after boot section */
		app_t app = (app_t)(BOOT_SIZE / sizeof(app_t));
		app();
	/* Initialize communication interface */
	init_uart();
	init_status_led();
	 * Start programming at start for application section
	 * Subtract MAPPED_PROGMEM_START in condition to handle overflow on large flash sizes
#ifdef _PROGRAM
	uint8_t *app_ptr = (uint8_t *)MAPPED_APPLICATION_START;
	uint8_t Check_data[8];
	uint8_t count = 0;
	uint8_t crc_received, crc;
	while(app_ptr - MAPPED_PROGMEM_START <= (uint8_t *)PROGMEM_END) {
		/* Receive and echo data before loading to memory */
		uint8_t rx_data = uart_receive();
		uint8_t *temp_ptr;
		uart_send(rx_data);
		/*combine the data received for later crc*/
		if(count == 0){
			temp_ptr = app_ptr;
		Check_data[count] = rx_data;
		count++;
		/* Incremental load to page buffer before writing to Flash */
		*app_ptr = rx_data;
		app_ptr++;
		if(count>=8){
			count = 0;
			crc = 0;
			crc_received = uart_receive();
			for (uint8_t i=0; i<8 ;i++){
				crc =  Check_data[i];
			if(!(crc == crc_received)){
				app_ptr = temp_ptr;
		if(!((uint16_t)app_ptr % MAPPED_PROGMEM_PAGE_SIZE)) {
			/* Page boundary reached, Commit page to Flash */
			_PROTECTED_WRITE_SPM(NVMCTRL.CTRLA, NVMCTRL_CMD_PAGEERASEWRITE_gc);
			while(NVMCTRL.STATUS & NVMCTRL_FBUSY_bm);
			toggle_status_led();
#endif // _PROGRAM
#ifdef _DEBUG
	__builtin_avr_delay_cycles(10000000);
#endif // _DEBUG
	/* Issue system reset */
	_PROTECTED_WRITE(RSTCTRL.SWRR, RSTCTRL_SWRE_bm);
The code itself ain't pretty, but i spread out the code to see on what part the compiler is hanging.
The error i get is:
Error        in expand_assignment, at expr.c:4874    BootLoader
The line i pointing to the line :
When i comment that part of the program out, i get to next error:
Error        in emit_move_insn, at expr.c:3601    BootLoader
The line here is:
I don't know what next to look for. Also, what problem is there in the program?
The bootloader program itself is not to big for the memory assigned.
The error messages you quote are useless - they don't actually show the text of the error message. Please show the build output.
Sorry, my bad.
Here are the build outputs:
------ Build started: Project: BootLoader, Configuration: Debug AVR ------
Build started.
Project "BootLoader.cproj" (default targets):
Target "PreBuildEvent" skipped, due to false condition; ('$(PreBuildEvent)'!='') was evaluated as (''!='').
Target "CoreBuild" in file "C:\Program Files (x86)\Atmel\Studio\7.0\Vs\Compiler.targets" from project ".........\BootLoader\BootLoader.cproj" (target "Build" depends on it):
    Task "RunCompilerTask"
        Shell Utils Path C:\Program Files (x86)\Atmel\Studio\7.0\shellUtils
        C:\Program Files (x86)\Atmel\Studio\7.0\shellUtils\make.exe all --jobs 12 --output-sync
        .././boot.c: In function 'boot':
        .........\BootLoader\boot.c(89,21): error: in expand_assignment, at expr.c:4874
        Please submit a full bug report,
        with preprocessed source if appropriate.
        See <http://www.atmel.com> for instructions.
        make: *** [boot.o] Error 1
        Building file: .././boot.c
        Invoking: AVR/GNU C Compiler : 5.4.0
        "C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\avr8\avr8-gnu-toolchain\bin\avr-gcc.exe"  -x c -funsigned-char -funsigned-bitfields -DDEBUG  -I"C:\Program Files (x86)\Atmel\Studio\7.0\Packs\Atmel\ATmega_DFP\1.3.300\include"  -Os -ffunction-sections -fdata-sections -fpack-struct -fshort-enums -g2 -Wall -mmcu=atmega4809 -B "C:\Program Files (x86)\Atmel\Studio\7.0\Packs\Atmel\ATmega_DFP\1.3.300\gcc\dev\atmega4809" -c -std=gnu99 -MD -MP -MF "boot.d" -MT"boot.d" -MT"boot.o"   -o "boot.o" ".././boot.c"
   .........\BootLoader\Debug\Makefile(76,1): error: recipe for target 'boot.o' failed
    Done executing task "RunCompilerTask" -- FAILED.
Done building target "CoreBuild" in project "BootLoader.cproj" -- FAILED.
Done building project "BootLoader.cproj" -- FAILED.
Build FAILED.
......... is the rest of my folder structure
OK well that does not actually help very much - I think you'll have to raise a bug report with the compiler developers. they will want a complete buildable project to investigate.
As a workaround, OP might try compiling as C++.
extern "C" can prevent name-mangling where necessary.
It might even work.
i have send a ticket to Microchip with this problem and got a response.
It seems like compiler bug. Thank you for bringing this issue and we will report this to our concern team.
As a work around, please define app_str as 16-bit pointer (uint16_t *app_ptr).
It appears that this fixes the problem for now. Hope this will be fixed in the next update
I think the error message refers to an identified error in the gcc compiler, in file expr.c, at line 4874.
There is an assert at that line.
          if (!MEM_P (to_rtx))
              /* We can get constant negative offsets into arrays with broken
                 user code.  Translate this to a trap instead of ICEing.  */
              gcc_assert (TREE_CODE (offset) == INTEGER_CST);
              expand_builtin_trap ();
              to_rtx = gen_rtx_MEM (BLKmode, const0_rtx);
