USART Forever loop with interrupts
46 posts / 0 new
I typed my a code to use USART 9Bits addressable communication to toggle 2 LEDs between 2 Mega16. Here is my code:
Transmitter:
/*Defining Statments*/
#define F_CPU 8000000UL
#define generalCallAddress 0x01
#define ACK 0x02
//#define NACK 0x03
#define myAddress 0x04
#define slaveAddress 0x05
#define delay 2000
/*Include Statements*/
#include "USARTModule.h"
#include #include
/*Global Variables Statements*/
char dataRecieved;
char dataTransmitted = 0x07;
char addressTransmitted = slaveAddress;
char dataExpected = 0x05;
/*Global Function Declare*/
/*Main*/
sei();
USARTinitil(8000000UL, 19200, 'n', 'a', 'e', 2, 9);
{ if(dataExpected == addressTransmitted)
USARTTransmitAddress(addressTransmitted);
} else if(dataExpected == dataTransmitted)
USARTTransmitData(dataTransmitted);
} else if(dataExpected == NACK)
} else if(dataExpected == ACK)
ISR(USART_RXC_vect)
dataRecieved = USARTReceive();
switch(dataRecieved)
case ACK:
if(dataTransmitted == 0x06)
dataExpected = dataTransmitted;
_delay_ms(delay);
}else
dataTransmitted = 0x06;
_delay_ms(delay);
case NACK:
dataExpected = NACK;
_delay_ms(delay);
case myAddress:
dataExpected = ACK;
_delay_ms(delay);
Receiver:
#define ACK 0x02
#define NACK 0x03
#define myAddress 0x05
#define masterAddress 0x04
#define turnON 0x06
#define turnOFF 0x07
#define LED1 PB0
#define LED2 PB1
#define LED_DDR DDRB
#define LED_PORT PORTB
#define delay 2000
#include #include
char dataRecieved;
char dataExpected;
/*Main*/
sei();
setBit(LED_DDR, LED1);
setBit(LED_DDR, LED2);
MPCMModeSet();
USARTTransmitData(ACK);
} else
USARTTransmitData(NACK);
ISR(USART_RXC_vect)
case myAddress:
MPCMModeClear();
dataExpected = ACK;
_delay_ms(delay);
case turnON:
MPCMModeClear();
setBit(LED_PORT, LED1);
setBit(LED_PORT, LED2);
_delay_ms(delay);
case turnOFF:
MPCMModeClear();
clearBit(LED_PORT, LED1);
clearBit(LED_PORT, LED2);
_delay_ms(delay);
case NACK:
MPCMModeSet();
_delay_ms(delay);
Why does I only get 4 loops for toggling my LEDS and then it stops?!
Why is my logic deniable?!
Humility, O humans. We are just a worm's meal in the grave!
Welcome to AVRFreaks!
Please tell us what AVR you are using.
Also when posting code, use the code tag "<>" in the edit menu, as it will preserve your spacing and more, makes looking at the code much easier!
There are few if any comments in the code, so please tell us a general overview of what your code intended to do, what it is doing, how it differs from expected.
One thing I noticed is the use of delay_ms() in ISR(), as a general rule, ISR()'s should be fast, do what is needed and get out.
My guess is your missing some of your serial data coming in due to data overruns, because of the delays in your ISR()'s cause the main() to miss data as it is not servicing the incoming data fast enough.
Edit: OP said M16's
Thank you for your complimentblush
My code intended to simulate a USART 9 bits format while MPCM is set.
Pseudocode:
1- usart initialization for both master and receiver
2- transmitter send slave address
3- slave check if the received address is his address
4- slave clear MPCM if the received address is his address
5- slave transmit ACK back to master if it addressed
6- slave stay at MPCM mode if not addressed
7- slave transmit NACK if there is FE, DOR or PE
8- master check received data from slave and decide what to do
9- if it ACK then master transmit turn-on or turn-off command
10- if it is NACK then master transmit address again
That thing should run forever but otherwise my LEDS toggle 4 times which is 8 transmission by master to slave then it stop toggling. And that is it
About the delay
When I am not using it my LEDS keep toggling very very fast which unseen  by normal eyes. So may be I implement the delay in my main function better?😂
Take the delay's out of the receive side and see if that helps, you are transmitting only once every 2 seconds, so no need for the delay on the receive side.
OK I try that and I will take out the delay from the interrupt routine 👌
In Post#1 you have for the Receiver:
char dataRecieved;
char dataExpected;
Since your program assigns values to both these variables in the ISR,
these two variables should be marked as volatile.
volatile char dataRecieved;
volatile char dataExpected;
Why use 9bit for simple avr to avr over usart?
I tried both notes of ki0bk and Chuck99 and still the same thing happen
My LEDS toggle on and off only 3 times then nothing happen
To enable multi-processors mode so I can use the address feature of the act over USART
But why would you want to do that for point to point unledlss its for learning experience?
Yes I am learning
If you are using the internal RC clock that might be part of your problem. They drift and if they both drift differently you can lose comms.
Second you have that call to a function in your receive interrupt routine with a switch. You can lose a charachter coming in while servicing all of that. Better to make your ISR lean and have main handle the "processing". Have you been able to get solid comms without 9 bit by just passing bytes? If not then i suggest you start there first and once you have that going add on the 9 bit.
Your switch statement does not have any break
commands at the end of each case.  Also, you
may want to add an else clause at the end of
your if - else if - else if statement in case the
value in dataExpected does not match any of
the possibilities.  Also add a default label to
the switch for the same reason.
--Mike
1- Yes I am using the internal oscillator 8mhz. (Wait I will try external now and get back to you).
2- Yes I found the 8bits USART is easy to implement and I succeeded to do it.
3- I modified the ISR as ki0bk said and as you mentioned. Fast get in and out ISR and let the main() do the processing
But the point is that this only starts to make any sense when you have THREE micros in the system. One "master" and two addressable "slaves". When you have just one master and one slave you over-complicate things by trying to use MPCM. Are you saying this is just an initial experiment that will be the basis of a multiple CPU system? But if that's the case then to really test it (verify that only the addressed slave is active) you really do need to add another one!
And to add to Cliffs post, you will also need to use a physical communications scheme that will support tieing multiple processors to one host.
Look up RS485 for example.
For a point to point test, once you have comms established, change the address in the transmitter only and see if the comms fail.
Edit: damned iPad autocorrect
jgmdesign wrote:
ee if the commas fail.
Don't you just love autocorrect!
Actually that is aimed to be as you are asking me to do but i just want to do it point to point for once with ever ending loop.
Current structure of the code is my first code ever using avr except for leds and buttons.
And i think that the problem is the internal Oscillator . Because it have a margin error +10% which is more than 2% for allowed USART error.
After i get 2 x 7.3728mhz i try it again
If it is "point to point" why are you using a mode that is intended for one-to-many addressing usage? If you just want to get two micros to "talk" between the UARTs why do you think MPCM needs to be involved?
As for clocks. The whole point of the A in UART is that it means "Asynchronous". This means that each station runs its own clock. Two (or more) stations can only communicate because they run their clocks very close to some known value. There is a little bit of room for error. Overall you can have about 4% of error and it all still works. That is generally take to mean that any one device can be +/-2% so that in the worst case when one is -2% and the other is +2% (or +2% to -2%) then there's still no more than 4% of error.
But then you look at the "internal RC" oscillator of an AVR. It can be +/-10% so if you were really unlucky and one AVR happened to be -10% and the other was +10% their clocks would be out of sync by a massive 20%. Well beyond the 4% you can get away with. That's why it's usually suggested to use crystals on each station as they are generally only 50..100 parts per million inaccurate. That means that worst case, if it is actually 100ppm out then it is only a 100/1,000,000 = 0.01% wrong.
Of course that +/-10% quoted for AVRs is worst case and the devices likely follow a standard bell distribution. So the majority are nowhere near as far out as -10% or +10%. So usually you'll be lucky with intRC. What's more Atmel test them in the factory and write calibration bytes into the chip. With the right temperature and Vcc that value (which is loaded at power on) might be enough to make the chips accurate.
note however that you said "mega16". Unlike modern AVR that have just one intRC those chips had four different intRC and four different factory calibrations. At power on, however the fuses may be set, they load the value for the 1MHz oscillator. So if you are using the 8MHz oscillator you need to load its calibration value manually. At the right Vcc and temperature it will reduce +/-10% to +/-1%
I asked the same question:
And the response was:
AhmedHamdy wrote:
Yes I am learning
So this may simply just be that.  A base for a future project.  But as noted there are some issues with the OP's setup physically, and the code as well.
I am using JTAGICE clone for burning fuses.
And thank you for your explanation.
And of course thanks Jim I wish I had a tag for your name.  🤗🤗🤗🤗😎
I am sorry I am using mobile
And yes it is part of more bigger idea that is why I am trying to issue all the things I need for the bigger idea
So you DO need MPCM because there ARE going to be more than 2 micros in the eventual solution?
What I really wanna do after the initialization counting on a logic for translation I will take it for full duplex tests using max488 or Max 489 I don't remember the part number
Yeah that is how I should learn experiment
The Max488/489 are not full duplex parts. They are half duplex. And with multiple micros you cannot have full duplex very easily either.
Hint. With many 485 comms systems 9bit is not used. Packet/CRC is used amd the address is embedded in the packet. 9bit is a pain in the a$$ to use.
East Coast Jim
Man I am still learning let me get it run forever loop first. That is a dream the thoughts you are talking about.
If you had basic comms without the 9th bit/mpcm then you should be fine.
And the packet/crc is not that difficult to learn.
Did you miss my post in #14?  Your code
has some serious problems that you need
to fix.
--Mike
Sorry I am trying to use mobile more less than PC because it hard.
Volatile. Comments. Breaks
Datasheets details. The error detection can be more further with bootloader. And binary format SD CRC.
Why is it hard for me sometimes to understand the bootloader section. Hard road right? All about learning
Thank you all for your kindness
Dont know why you tagged my post as a solution, but hey ho whatever.
The thing is that can't find much options for ics and ordering  it isn't that easy
But I thought max488 is full duplex?
Yes the 488 is but its for point to point communications only. Not multiple devices.
Lets take a step back. Tell us what your end goal is and in return we can provide suggestions on what you should look at to make the goal a reality.
I know that is my target now "full duplex chip to chip and my goal is already reality but counting on Arduino as a platform.
And private sources. If you really can help me.... I need something about signal circuit in radio transceiver area.
Radio tranceivers are totally different than copper communications.
You seem to be all over the place with this.
Mainly due to a lack of a well thought out plan for this...
What you need is a data transfer protocol that will work regardless of the transport layer, something like S.N.A.P : http://www.hth.com/snap/
Have fun.
Actually that a thing I haven't heard about before but Thank you I am done with internet of things and yeah it will be a very good library for communication if I need but I am willing to migrate to ARM after 8bit arch or may be XMega if I can get it. Or as they say in S.N.A.P's library. """All these often uses resource limited MCU's""". Which if I want I can use all this modules with Arduino platform. I wanna dig more.
And may be this is my first appearance here with a question but I am here from more than 2 years old reading and learning all what I can get or missed in my formal education age
Best resources and best teachers
Thank you again. Hope I can be a good partner here as a student
Again
Make a detail outline if what you want to accomplish and post it. We will help but changng things around the way you have does not help.
Don't worry outline is there but I only miss the details so I am breaking it down to section like logic problems. And I will be here from now on because that is my only team work I have. And what makes you unique in your way is your SIGNATURE. big step for me believe me for me to be here. I would not dear to be here from 1 year ago.
And is there anyway to private message here?
I have no idea what my signature has to do with anything
