Start without debugging doesn't work on sam4s xplained pro
3 posts / 0 new
hi,
i'm using atmel studio 6.2, i have to program hex file in flash of sam4s directly in sam4s xplained pro board ,but start without debugging doesn't program properly,so i have to do only debugging(which is working fine).
any idea what's the problem?
thanks in advance!
Same problem on AT32UC3C2256C. Any solution?
See the SAM4S data sheet, section 8.1.4 Boot Strategies. Make sure your GPNVM bits are set correctly. Specifically, ensure GPNVM1 is *set* to boot from Flash. It is clear by default, which causes the SAM-BA boot ROM to execute out of reset.
Edit: Didn't notice the date on the first post. Other SoCs will probably have similar fuses. RTFM!
Steve
Maverick Embedded Technologies Ltd. Home of wAVR and Maven.
wAVR: WiFi AVR ISP/PDI/uPDI Programmer.
Maven: WiFi ARM Cortex-M Debugger/Programmer
https://www.maverick-embedded.co...
