Avr atmega 2560 hvpp problem
9 posts / 0 new
Hello!
I have problem with avr atmega2560.
With stk500 compatible programmator in HVPP mode, i change fuses
For
Extended: 0xFF
High: 0x99
Low:0x42
And now i can't read signature, or erase, or change fuses.
Readed signature:0xffffff
Why use HVPP?
What do you get when you use ISP?
Note: I can not see any bypass caps in your test setup, all VCC/GND and AVCC/GND pairs should have power and bypass caps (100nf typical) for proper operation!
Your changes of the fuses use the default values for the extended and high fuses.  The low fuse change is only for start-up time.  Why are you doing this?
The Russian-language-only manual to the programmer in your photograph references Studio version 4.13.  Are you using this software?
When you connect your $8 logic analyzer (from eBay here: https://www.ebay.com/itm/USB-Log... ) to the parallel logic pins, what signals do you see?   Do they match the documentation for the AVR High-Voltage programming format?
Why are you messing around with difficult AVR equipment?   Can't you just spend the 700 rubles on a Chinese Arduino Mega (eBay here:https://www.ebay.com/itm/NEW-MEG... ) and get a stable, flexible, standardized AVR Mega2560 development platform?
I tryed use ISP. all work!
I want use this chip standalone, without external quartz. Can you tell me low fuse value?
The way it is set now is for internal oscillator at 1MHz (default), if you uncheck the CKDIV8 fuse and program the fuses then the chip will run at 8MHz.
I am set lfuse to 0x62.
All work
Thanks for all!
I'm intrigued. How do you even do HVPP for a 2560? It's very unlikely you can do it in circuit because of the 12V and 20 signal wires involved (surely one or more are used for other purposes in the circuit?). So are you somehow programming it in a chip carrier?
See photos in #4
atmega2560 datasheet
page 329
 pin mapping for HVPP
my stk500 compatible programmator have this pinout:
on TRST pin temporarily appears +12 V
