Xplained board not showing up in studio
9 posts / 0 new
Hello:
I have used a meag328pb xplained board, no problem, on windows 7.  I also have a xplained 3217 board, that doesn't show up (under tools).  Somewhat foolishly, I initially plugged it in before I ran studio 7 (not sure if that makes a difference) & it started loading drivers.  It looked like it was trying to install 4 drivers & one failed (I accidentally cleared the message, before I had a good look).  If I plug in the 328pb board,  it shows up & even shows a photo of the board in a studio tab.  The other board shows nothing in studio & not listed in tools.   However in the windows system tray, it shows I can eject it (safe to remove EDBG  CMSIS-DAP), as it shows virtual comm port10.  Thought I might "uninstall it" & try again, but not sure what needs uninstalled.  Should the 3217 board show up as a photo in studio?
Atmel Studio 7 - How do I get my Tool to be recognized by Atmel Studio?
When you say tools, do you mean View/Available Tools?
:: Morten
it appears the driver  is working, yet nothing shows in tools.
right now i just want to builod & blink an led on the xplain board (C program)
all I can pick from is a bunch of stk500's on different comm ports...ans even if i pick one of thoses, then the tiny3217 isn't listed (which makes sense, since it is not isp)
the moment I plug in an old 328pb board, it pops right up in the studio , on a new tab
should the same thing happen when I plug in the 3217 xplain board
And View/Available tools shows?
:: Morten
interesting...never used that feature, just used the dropdown in the programming section...anyhow, it shows nothing
however windows itself shows that it sees something out there
if I plug in my 328pb board,the 328pb pops right up in studio as shown:
Total votes: 2
Oh, the CMSIS-DAP should not be a 'other device'...
Find it in Device Manager, and choose to update the driver. If it doesn't find a applicable one, then the one that should be used is Microsoft/USB Input device.
Could you PM me you setupapi log? (it's in C:\Windows\INF\setupapi.dev.log)
:: Morten
You may be onto something.I'm about to check into your suggestion...when I plug in the detectable 328pb xplain  board, it shows
By the way, I just installed studio on my wife's win10 laptop...it detected the 3217 board right away, I was able to chenge the fuses from 20MHZ to 16MHz and back...so the 3217 board is functional
YES!!! YES!!!  MEOLSEN, that did the trick!   When i asked to update driver, it said it found something & went off & did its thing.   For some reason, whenever something USB-oriented installs a driver on this PC , it takes about 5 minutes  (perhaps from plugging in so many things & fdti-type chips, over the years).
  I will heartily nominate you for the Microchip hall of fame
fyi--it now shows
