I am trying to run AT05567: TC Capture on External Interrupt with the Event System on SAM D20
on SAM C21, and have made some changes to make it work with the C21, but I am unable to make it work. Can someone please guide me on what I am doing wrong
#include <asf.h> /* TC module struct */ struct tc_module tc0_module; /* TC config struct */ struct tc_config tc0_config; struct events_resource extint_event; void tc_configuration(void); void extint_configuration(void); void evsys_configuration(void); void tc_compare_callback_function(struct tc_module *const module_inst); void tc_capture_callback_function(struct tc_module *const module_inst); void configure_extint_channel(void); void configure_extint_channel(void){ struct extint_chan_conf config_extint_chan; extint_chan_get_config_defaults(&config_extint_chan); config_extint_chan.gpio_pin = BUTTON_0_EIC_PIN; config_extint_chan.gpio_pin_mux = BUTTON_0_EIC_MUX; config_extint_chan.gpio_pin_pull = EXTINT_PULL_UP; config_extint_chan.detection_criteria = EXTINT_DETECT_BOTH; extint_chan_set_config(BUTTON_0_EIC_LINE, &config_extint_chan); } /* Configure 16-bit TC0 module for capture */ void tc_configuration(void) { tc_reset(&tc0_module); tc_get_config_defaults(&tc0_config); tc0_config.clock_source = GCLK_GENERATOR_1; tc0_config.clock_prescaler = TC_CLOCK_PRESCALER_DIV1024; tc0_config.enable_capture_on_channel[0] = true; tc_init(&tc0_module, TC0, &tc0_config); struct tc_events tc_event = { .generate_event_on_compare_channel[0] = true, .generate_event_on_compare_channel[1] = true, .on_event_perform_action = true, .invert_event_input = true, .event_action = TC_EVENT_ACTION_PPW }; tc_enable_events(&tc0_module, &tc_event); events_attach_user(&extint_event, EVSYS_ID_USER_TC0_EVU); /* Callback function for capture */ tc_register_callback(&tc0_module, tc_capture_callback_function, TC_CALLBACK_CC_CHANNEL0); tc_enable_callback(&tc0_module, TC_CALLBACK_CC_CHANNEL0); } /* Configure external interrupt controller */ void extint_configuration(void) { struct extint_chan_conf extint_chan_config; extint_chan_get_config_defaults(&extint_chan_config); extint_chan_config.gpio_pin = BUTTON_0_EIC_PIN; extint_chan_config.gpio_pin_mux = BUTTON_0_EIC_MUX; extint_chan_config.gpio_pin_pull = EXTINT_PULL_UP; extint_chan_config.detection_criteria = EXTINT_DETECT_LOW; extint_chan_set_config(BUTTON_0_EIC_PIN, &extint_chan_config); /* Configure external interrupt module to be event generator */ struct extint_events extint_event_conf; extint_event_conf.generate_event_on_detect[BUTTON_0_EIC_PIN] = true; extint_enable_events(&extint_event_conf); } /* Configure event system: */ void evsys_configuration(void) { struct events_config config; events_get_config_defaults(&config); config.generator = EVSYS_ID_GEN_EIC_EXTINT_8; config.edge_detect = EVENTS_EDGE_DETECT_BOTH; config.path = EVENTS_PATH_ASYNCHRONOUS; config.clock_source = GCLK_GENERATOR_1; events_allocate(&extint_event, &config); } /* Capture callback function */ void tc_capture_callback_function(struct tc_module *const module_inst) { uint32_t button_time = tc_get_capture_value(&tc0_module, TC_COMPARE_CAPTURE_CHANNEL_0); /* Configure timer to wait for compare match */ tc_disable(&tc0_module); //Disable TC0 module to be able to configure it tc0_config.enable_capture_on_channel[0] = false; tc_init(&tc0_module, TC0, &tc0_config); /*Set the value of CC0 as it has been reset*/ tc_set_compare_value(&tc0_module, TC_COMPARE_CAPTURE_CHANNEL_0, button_time); /* Change callback function to tc_led_callback_function */ tc_register_callback(&tc0_module, tc_compare_callback_function, TC_CALLBACK_CC_CHANNEL0); tc_enable_callback(&tc0_module, TC_CALLBACK_CC_CHANNEL0); tc_enable(&tc0_module); //Enable TC0 module again /* LED0 turned on for as long as the button was pushed (button_time) */ port_pin_set_output_level(LED_0_PIN, LED_0_ACTIVE); } /* Compare callback function */ void tc_compare_callback_function(struct tc_module *const module_inst) { /* LED0 turned off */ port_pin_set_output_level(LED_0_PIN, LED_0_INACTIVE); /* Configure timer back to pulse-width capture operation by setting the timer to wait for compare match*/ tc_disable(&tc0_module); tc0_config.enable_capture_on_channel[0] = true; tc_init(&tc0_module, TC0, &tc0_config); /*Change callback function back to tc_button_callback_function*/ tc_register_callback(&tc0_module, tc_capture_callback_function, TC_CALLBACK_CC_CHANNEL0); tc_enable_callback(&tc0_module, TC_CALLBACK_CC_CHANNEL0); struct tc_events tc_event = { .generate_event_on_compare_channel[0] = true, .generate_event_on_compare_channel[1] = true, .on_event_perform_action = true }; tc_enable_events(&tc0_module, &tc_event); tc_enable(&tc0_module); //Enable TC0 module again } int main (void) { /*Initialization and configuration*/ system_init(); evsys_configuration(); tc_configuration(); extint_configuration(); /* Enable TC0 module */ tc_enable(&tc0_module); /*Enable interrupts*/ system_interrupt_enable(TC0_IRQn); system_interrupt_enable_global(); while (1) { //port_pin_set_output_level(LED_0_PIN, LED_0_ACTIVE); /*Wait for button to get pushed*/ } }
