ATSAME53 RTC, Calendar problem
8 posts / 0 new
Hello, i've been developing a time and date display in atsame53 mcu, i've a problem on this topic. System has counting with 1hz but as example 30. seconds; it has delaying a second and then continue. where is may be problem? can you help me?
Welcome to AVRFreaks!
You will need to provide more info about your program and setup in order for any one to help you with your situation.
hello, i can more explain.
I have been using ATSAME53 MCU in my project. I want to add a time and date display with using Calendar driver. My time is count with 1Hz frequency but for example 10 seconds or 30 seconds; it waits a second then continue. Where is may be problem? I have used 1024 Hz output with external oscillator and divided by 1024.
This would be a WAG, but my guess is you have something else triggered at 10/30 second intervals that is taking too long to service, and causing the delay.....
I would suggest you write a small complete program that demos the problem and post it here using the "<>" code tag in the edit bar above.
Hello, I am using FreeRTOS on my system. I think, there is shifting on frequency. How can i solve this problem that my think. That number was just example that my saying. System has not delayed same time intervals, its always changing.
Also I've using "calendar_get_date_time()" function. Although delays it has to always concurrency feedback to me.
Have you asked your question in their support forum?  https://freertos.org/FreeRTOS_Su...
No. i think, my problem is not relevant FreeRTOS. Is that right?
With a RTOS, you can have many timing issues, priority issues, ect...
Are there any RTC Calendar examples?  If so, do they work on your hardware?
Too many issues to solve here, you will need guidance from RTOS folks.
