Solved: blinkLED from Elliot Williams book
6 posts / 0 new
Hello Im new to this forum and stuck already on the first example of the book AVR programming by Elliot Williams.
Im using Debian with the Arduino IDE version 2:1.0.5+dfsg2-4.1 plus an genuine Arduino as well as an knockoff (so I tried it with both). On my breadboard I have an Atmega88 and everything is according to the book page 28.
I was able to turn the Arduino into an ISP and load it with any other example code. So it seems to work but when I try to upload the blinkLED sketch I got this one:
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x14
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x01
avrdude: stk500_initialize(): (a) protocol error, expect=0x14, resp=0x10
         this check.
avrdude: stk500_disable(): unknown response=0x12
I tried this also with an USBTinyISP but thats another story.
Whats the problem here?
Thank you
Atmel 328 (Atmega 88 20U) programmed by Arduino
You haven't wired up the other half of the chip's power supply for a start.
Can you show the diagram from that book or a link to it? Many people INCORRECTLY believe that AVCC and the other ground pin are optional.
It also looks like you have power for your breadboard coming from"Vin" - it should be coming from "5V"
This could have destroyed your chip if you were actually powering it from the DC Jack; if you were powering it from USB, you'd probably just get "not working."
Sorry for the delay, I was distracted && had to fix Fritzing (Debian installation).
Anyway, this is the sketch I made with Fritzing:
sketch of my breadboard
the resistor has 220Ω and the capacitor has 100nF
BR Chris
But you need to wire the power pins on the other side of the chip as well as adding another cap there. See also #2 above.
Finally had to opportunity to finish this. It was the lack of power on pin 20 as js mentioned. But also the fact that I used an Atmega88 instead of a 168. So when I tried to upload the tiny code via Arduino to the chip, the Arduino IDE complained: avrdude: Expectred signature for ATmega is 1E 94 06. After putting a "real" 168 into the board it worked.
Thank you all.
BR Christian
