USB "segmented" transfer
3 posts / 0 new
Hello Everybody,
If the data to be transfered to/from an USB enpoint is bigger than the endpoint size it has to be segmented and is transfered in several packets.
My question: Can more than 1 of this segmented transfers be active at the same time inside a device or do I just need to track a single transfer ?
TiA, Tommy
For a given endpoint, no, there can only be 1 transfer in progress per endpont.
But yes if it involves different endpoints (you can of course have multiple endpoints).
(It's been a long time since I worked with USB so I wouldn't take this as gospel).
It probably depends on the hardware.  With the Xmega AU, you can queue up a data buffer with a size up to 1023 bytes.  The hardware will send it in chunks equal to the low level data packet size.  That's probably 64 bytes for full speed.
