This example shows how to use the NVM controller to write single bytes to the EEPROM (from the CPU, the UPDI interface can also access the NVM controller). It's also possible to do block writes, but that's a tale for another day...
The program writes the classic "Hello World!" string to the first byte positions of the EEPROM. Syntax is AVR assembler.
I hope the comments are clear enough to make sense of what's going on.
; replace by the correct include file for the MCU you are using ; or trust the IDE auto-include and delete this line #include <m4809def.inc> .CSEG rjmp start ; Skip interrupt vectors .org INT_VECTORS_SIZE message: .db "Hello World!" message_end: .equ message_len = 2 * (message_end - message) ; Translate program memory word address to memory mapped byte address .equ message_addr = MAPPED_PROGMEM_START + (2 * message) start: ; Load address of the "hello World!" string in X ldi xl, low(message_addr) ldi xh, high(message_addr) ; Load EEPROM relative address 0 in r17:r16 ldi r16, 0 ldi r17, 0 ; Load string lenght in r19 ldi r19, message_len ; Copy string to EEPROM loop: ld r18, X+ rcall EEPROM_write subi r16, low(-1) sbci r17, high(-1) dec r19 brne loop halt: rjmp halt ; EEPROM_write function ; On entry: ; r17:r16 - relative address of data inside the EEPROM area ; r18 - byte to be written to EEPROM ; Clobbers: ; zl (r30), zh (r31) ; All other registers preserved EEPROM_write: ; Wait for completion of previous write lds zl, NVMCTRL_STATUS sbrc zl, NVMCTRL_EEBUSY_bp rjmp EEPROM_write ; see edit #1 note ; Translate relative EEPROM address from r17:r16 to mapped address in Z movw Z, r17:r16 subi zl, low(-EEPROM_START) sbci zh, high(-EEPROM_START) ; Store EEPROM data (r18) to write buffer st Z, r18 ; Execute NWM erase/write command in zh, CPU_SREG ; preserve interrupt flag cli ; make sure interrupts are disabled for critical section ldi zl, CPU_CCP_SPM_gc ; unlock NVM command register out CPU_CCP, zl ldi zl, NVMCTRL_CMD_PAGEERASEWRITE_gc ; execute NVM erase/write sts NVMCTRL_CTRLA, zl out CPU_SREG, zh ; restore interrupt flag ret
edit #1: according to suggestion from post #11
