Cheap AVR based audio player help
16 posts / 0 new
Hello everyone. This is my first post so hopefully I put this in the right spot.
I am trying to design an AVR audio player that plays around 4-8 short recordings. about 4 seconds max.
I just need to know if I need to upgrade from what I have or if I'm doing something wrong in my code. I haven't been able to find much in regards to the Attiny412 and sample projects so I've been kinda winging it.
Design requirements:
1. The quality doesn't have to be great, just enough to be able to understand speech. (8000Hz 8-bit audio) Sample rate can be lower if necessary
2. the data has to be stored either internally or on SPI flash. I guess i could go the sd card route but this thing has to be mass produced so I kinda wanna keep it cheap without a sd card slot and all.
3. The AVR has to be fast enough for either PCM audio playing or DAC output.
4. The entire thing has to be around 5 dollars max, maybe 8 if i cant get anything that cheap.
If anyone has any experience with anything like this please let me know an alternative I can go with or help me with what I have already.
I was initially trying to use an attiny412 and a 4Mbit SPI flash chip to play sounds but for some reason the audio that I get out of it is all garbled. I programmed the flash chip with my RPi and every page in memory has values that correspond to a sine wave. The most ive ever gotten was the shape of a sine wave on my oscilloscope when playing it from the AVR but the signal has these spikes where the signal is higher than it should be in that spot (its also quite a long time, not just a really quick blip.) If anyone has ever used a really old storage oscilloscope with a bad ADC it looks similar. Like some of the bits are stuck. Only I know that's not the case because I've tried multiple chips. I have uploaded the source code for this project that I have for the 412. Please ignore any weird things in the code because I have been troubleshooting this for weeks and haven't found a solution and cleaned it up.
Basically, It runs a counter that triggers an interrupt every time a sample should be taken (~8000hz normally but i slowed it down for my scope). When the interrupt occurs, the SPI transfer is initiated and it sends a read opcode followed by 3 address bytes and then I write to the data buffer again to receive data from the chip. I know that you're supposed to disable the DAC before writing data to it but I have tried that as well and no luck.
Thanks for your time.
AVRs, Electronics, ESK8 boards, CNC, 3D Printing, LASERs, and Tesla Coils.
tiny817 and an 8Mb SPI flash (1 minute)
AVR Parrot
Why go through all teh nonsense and headache?
Use one of these:
https://www.ebay.com/itm/MP3-pla...
You save MP3's to an SD card, pop that in and you are good to go.
If you do a search of MP3 player boards you will find a lot of options on Ebay, Aliexpress etc.  Its a far simpler solution than the path you are going down.
JIm
I have the same recommendation but a different MP3 IC.  This https://www.ebay.com/itm/TF-Card... YT5300 module board allows you to use Arduino's Software Serial library and the DF_Player library to select one (of thousands) of the MP3 files on the SD card to play.  Plus it outputs a stereo signal at headphone-driving levels without needing an external amp.   It's my primary stereo now, with a music collection of several thousand songs/pieces on a 32Gigabyte SD card.   If used without a microprocessor, it will increment/decrement song/volume according to the long or short presses on a pair of buttons (not unlike the Chinese documentation indicates on the device referred to in the above post).
I have not heard of a TF card in years.  Surprised some still call them out.
JIm
ISR(TCA0_OVF_vect){ //TCA0_OVF_vect
	slaveSelect();
	SPI0_Write_Opcode(0x03); // read opcode
	SPI0_Write_Opcode(0x00); // MSB address
	SPI0_Write_Opcode(0x00); // LSB address
	uint8_t data = SPI0_exchangeData(0x00);
	slaveDeselect();
	DAC_Write(data);
	//if (address < 0xffff){
		//address++;
	//else {
		//address = 0x0000;
	TCA0.SINGLE.INTFLAGS = TCA_SINGLE_OVF_bm;
        reti();
That is very bad news indeed! I'm totally astonished that this software actually does anything when you have a reti() in an ISR() ?!?
I'm guessing you didn't read the user manual?:
Returns from an interrupt routine, enabling global interrupts. This should be the last command executed before leaving an ISR defined with the ISR_NAKED attribute.
perhaps that does not make the point strongly enough but what it means is "ONLY with ISR_NAKED - it you use it elsewhere it will be totally fatal".
The whole point is that when you write:
ISR(vect) {
    // stuff
then the '}' already implies "RETI" but it will only do that RETI once all the stack is rebalanced. If you use:
ISR(vect) {
    // stuff
    reti();
then on entry the prologue will push various things to the stack but before this code gets the chance to reach the epilogue where those things on the stack are then removed to rebalance things the reti() means "return early whatever might still be on the stack". So each time the ISR is called it will leave some stuff on the stack. After a few interrupts the stack will work its way back through memory until it crashes into the end of .bss or .data and then things will go seriously wrong!
What gave you the idea that ISR()s should have reti() in them??
PS forgot to say that reti() is, of course, OK in an ISR_NAKED because the "naked" means "no prologue, no epilogue". However, because ISR_NAKED does not save the registers used or protect SREG then if you use ISR_NAKED and reti() then YOU have to be sure to save SREG (if touched) and save any registers that must be preserved - that can be very difficult to achieve as you can't easily know which opcodes or registers the compiler may use so you don't know if it might touch SREG or which registers. The manual does say this:
But in this example they have cleverly picked a C statement that is known to use "SBI" which is an opcode that does not affect SREG. However even this example fails if that code is built with -O0 optimization!
(your TCA_OVF interrupt is so complex it must touch SREG and it almost certainly corrupts a number of registers that must be preserved too)
Thanks for all of the feedback! A lot of the things mentioned here I have seen before but i decided against them because I need something that will play a random section (or in sequence) when a button is held. There is absolutely no human intervention to the device. It's more of a gag gift. hold a button, play a track, wait for release, repeat.
about the reti();
I did read that in the manual but that whole section was really confusing. This is my first time ever using interrupts so I was learning from basically nothing. Without the reti(); it appeared to do nothing, but there could have been something else timing wise that was the problem. For my application, is there a benefit to using either the ISR or the ISR_naked? I would like to make my code as efficient as possible. Preferably I would read the data sequentially and not have to write the start address every time but im afraid it might leave little pops from when the addresses have to be resent. The time period in that space is greater than 125us or 8000Hz like im looking for. May just have to settle with ever so slightly less. The chip does run at 20Mhz but not on 3.3 volts and I need to interface the 3.3v flash. Maybe a dumb question but will the avr still output 3.3v if its running on 5?
The output, high, state of the I/O pins will be about the Vcc level.
If you run your chip on Vcc= 5V, then the I/O pins will output 5 V.
If you have nice audio data then you shouldn't have clicks and pops in the output.
You should run the output through a Low Pass Filter, then to your audio amplifier and speaker.
Typically, you might run a Timer/Counter in CTC mode, so that it generates an interrupt at the desired sample playback rate.
Within the ISR you simply load the new (next) value into your DAC hardware.
With a clean audio input the signal level won't change that much from sample to sample, and hence no clicks and pops.
Then, either within the ISR before returning you can get the next, upcoming, DAC data value, and have it ready, or you can set a flag and within your Main Loop you get the next data value ready, and clear the flag.
If the micro isn't doing much else then doing the lookup within the ISR isn't a bad approach, (although the majority of Freaks will tell you keep the ISR as short as possible).
In this case, if you aren't running a User Interface, a display, and a bunch of sensors or incoming data, it doesn't matter if your micro spends 5 % of its time within the ISR and 95 % in the Main Loop, or 15 % in the ISR, and 85 % in the Main Loop.
Some of those eBay modules are incredibly cheap!, but I get it, if you want a commercial product you need a reliable supply chain over which you have control.
Building your own is then a reasonable decision.
Do your high level design before you get tied up in ISR's and code.
Which micro?
What Vcc?
Internal RC Osc or external resonator, (or external Xtal), at what clock frequency?
External memory options?
At what operating voltages?
Amount of memory needed?
DAC?  (On chip, PWM on I/O Pin, External DAC, etc.)?
DAC LPF, (Simple RC, Active filter and Amp rolled into one?...)?
Audio output device, (Speaker, earphone, piezo, etc., and hence its driver options)?
Audio Amp, single transistor vs Class D chip?
Power Supply, Battery types, battery connectors, etc?
Reverse polarity protection, Y/N?
How is the audio data initially to be provided to the device?
So many questions, and none of them have to do with code!
Sort out the high level design, then tackle the code!
Edit: Typo
As another example, Search for Atmel Butterfly.
The Butterfly was a credit card sized Mega169 demo board, (The M169 has a glass GLCD driver module, NOT what you need).
The point of the research, however, is that it was a small PCB with a coin cell that played any of several songs on a small speaker, (albeit low quality audio).
There are also many other projects for micros playing audio which you can study to see how their designers tackled various aspects of the project.
Edit:
BTW, Welcome to the Forum.
After about 10 years of experience and when you really have an extraordinarily strong reason to do it then one day it's just vaguely possible you might need to use ISR_NAKED. Until that day forget you ever saw it (and reti()).
The tutorial forum here is full of examples showing how the ISR()s in avr-gcc can be used (ADC, UART, timers etc). Suggest you read a few of those - the none use of ISR_NAKED will be fairly obvious by its total absence!
Well one thing that hit me immediately was that
happening at the top of the ISR. Normally you would set up a memory chip in such a way that it was in some kind of auto-increment/continuous read mode so the ISR would do nothing more than one SPI operation to "read next byte". You wouldn't be sending addressing stuff in every interrupt. Also it does not make much sense to me anyway. It seems that in every interrupt you are using that addressing stuff to go back to location 0x0000 so isn't the ISR going to send the exact same byte every time??  If it does that no wonder you don't hear anything! Sound works by variations in the sound pressure - constant sound pressure is effectively "silent".
Clawson, the reason its all zeros there is because that was an older version of the code where I was testing to see if i could at least get a value to the DAC. I didn't upload the new code because it was more of a test and not aimed toward the final goal. I did at one time have a 16bit variable that I incremented every time but I wasn't sure if my bit manipulation was doing what it should. (Im sending the most significant bit first, but I didn't know whether the compiler would look at the first 8 bits or the last 8).  Then I had two variables. One incremented every ISR() and the other incremented when the other reached max and was set to zero.
That's when I saw I was getting a waveform but it looked a little like this:
Distorted Sine wave
I was using the first address byte as "partitions" if you will to select which part of the chip I wanted to play audio from. As I mentioned above, I have changed the code so much because, to be honest, I have very little experience.
I know that the SPI chip has a sequential read function (the 03h opcode).
The reason I'm worried about pops is because the sequential read only goes to the end of the page and loops back around. only 256 bytes. The problem is that it takes more than one standard 8000Hz sample rate time period to send all of the address data. Basically It would be a 8khz sample rate until it had to switch to the next page, Which would take about 1.4 times the period. (it's set to be really slow in my code for now but I plan to speed it up).
I do have the basic functional design finished but it may have to change based on my coding ability here.
2 questions.
If I increment a byte to 0xff and increment it one more time, what happens? does it go back to zero?
and is it necessary to disable the DAC before writing data. I would like to skip this time wasting step if it's not necessary.
Yes.
You can clamp the result to the maximum using a
function such as this:
uint8_t add_clamped (uint8_t x, uint8_t y)
    uint8_t sum = x + y;
    if (sum >= x) {
        return sum;
    // the addition overflowed so
    // return the maximum value
    return 0xFF;
--Mike
8ksps 8 bits audio, is pretty easy.  It means your software needs to be able to deliver a byte to the DAC every 125 microseconds, that is sure plenty of time for an AVR core running at 16MHz, bare numbers could show that the AVR could run around 2 thousand instructions in between each byte delivered to the DAC... that is even ridiculous idle time.
The more easy and cheap way for the DAC is a simple 8 bits port of the AVR with 16 resistors connected to the port, in the R-2R fashion poor man DAC, it works pretty well for audio, since the small errors caused by the resistors values become irrelevant, you can not really ear such tinny differences.  If you don't know what R-2R is, Google for it, there are plenty of information at the Internet.  Of course, anyway, you will need a small audio amplifier chip to produce an audible sound in some kind of speaker.
So, everything your code must do is just read from the Flash and OUT to that DAC port, nothing else.
Of course, you can this "timing" to generate the 8ksps audio by interrupts or by time delay, doesn't matter, what is easier for you.
Reading your texts, it becomes clear that you have not so much experience with programming, no problem at all (we all were born knowing profusely about AVR programming... right?) so I would recommend leaving the interrupt for later.  First make your flash reading works nicely, do a time delay of 120 microseconds (more or less, doesn't really matter), OUT the byte to the port and be happy.
Even running the AVR at 8MHz (internal clock) is pretty neat, plenty of time.
For example, the following (assembly) generates a delay of 120us when running at 8MHz
Delay120us:   ldi  r18, 2
              ldi  r19, 60
A1:           dec  r19
              brne A1
              dec  r18
              brne A1
              ret
So, just read a byte from flash, OUT to the DAC port and call the (Delay120us) above routine to waste 120us... repeat.
Note that R18 and R19 will be used in such delay, if you need them somewhere else, push and pop them into the delay routine.
Delay120us:   push r18
              push r19
              ldi  r18, 2
              ldi  r19, 60
A1:           dec  r19
              brne A1
              dec  r18
              brne A1
              pop  r19
              pop  r18
              ret
Later, after everything is working nice, then worry about the interruption every 125us.
This kind of programming is quite simple, you just need to learn about it, step by step.
Don't be ashamed to ask for help. You will be surprise how many people want to help.
As a last recommendation, go for assembly language, it is much quick and simpler to do what you need.
And yes, flash page reading is quite simple, you can do sequential, just read one 256 bytes page, send the address to select the next page, sequential reading, read it all, next page... easy.
Many years ago, before AVR, when 8051 microcontroller was king, I packed more than 40 seconds of very good spoken words and numbers into the 64kBytes (27C512) Eprom, including more than 9k of assembly code.  It was a very delicate and fine tuning software.  The sound to be produced by the "S" of "seven" for example, was the same of the "six", the "f" of four the same of five, the "ee" for three was also used in "six", and so on.  Lots of work to find all this little pieces of audio, addresses, quantity of bytes, etc.  I even used variable output sample rate for high frequency sounds and very low for low frequency, saving bytes and increasing quality wherever it was possible. The original audio recording was my wife's. The result was very good indeed, and that thing was even generating DTMF frequencies for phone call...  old times.
Wagner Lipnharski
Orlando Florida USA
I now have audio playing through the DAC! Thanks everyone for all of your help. I ran into another snag regarding the sleep function and limited pins but I think it would be better to post another question since its not related to this one. (unless its been posted before)
To get it running I just got rid of the interrupt all together and put a small delay in the code. (Thanks for the "no reti(); tip! that was really helpful) It works well enough for me and the sample rate is 16khz. The sound quality is well above what I was expecting.
Just a guess, but I think there was also another bit of code that was setting the ouptut of my DAC pin high and since I used the reti(); it was randomly restarting my code and that would explain the weird blips in the output.
Thanks again everyone.
Bears0, keep posting your results, it is very interesting and rewarding to see the learning progress in action.
Wagner Lipnharski
Orlando Florida USA
It may be pertinent to post the old mantra, or a variation of it:
Cheap, good, fast ... you get two out of three if you are lucky.
