Weird signals on SDA/SCL pins for I2C
12 posts / 0 new
Hello I am trying to communicate with a device via SMBus.  So when I try to send a data which was 0x0D and address of the device was 0x16. I see something like that on the data line:
And this is how my clock (SCL) pin looks like:
So my questions are :
  1. Is this data and clock signals look normal? I know data is not normal because I cannot transmit the message but what about clock signal?
  2. So Data looks like 1 1 1 1 1 1 .... 1 1, is it because I cannot ack ACK/NACK from slave, it keep sending the data over and over again? Or maybe something else behind this strange data signal.
  3. I used 20 K pull up resistors for SDA and SCL for 5 V Vdd. (For SMBus I think I should have used 15 k ohm.) Can it be the reason? Or any other ideas that causes this? Thanks beforehand
20k is way too high.  4.7k or 10k is the norm.
EDIT:  The resistors must also be at the last device on your bus.  Not at the microcontroller.
Actually in the datasheet of the device that I try to communicate it says this: (but I couldn't get what does it mean so I just used 20 k ohm )
You asked about I2C, not SMBus. For I2C we generally use pull up,resistors in the range of 2.2k to 10k.
What are you trying to interface to?
My bad, I am trying to communicate with a smart battery by using PIC, I want to get the state of charge information from it. SMBus v1.1 the battery uses
GunkutA wrote:
by using PIC,
Wrong web site, suggest you ask in the PIC Microchip forums!
GunkutA wrote:
by using PIC,
On an AVR website? Surely the PIC website knows more about the PIC I2C interface??
Yes, I just wanted to ask about the pull up resistors tho
The DS says 15k, so use 15k's, what does it say about bus speed?
With 15k pullups your bus speed will be sloooowwww,  so don't try to go fast, ie. 400kHz, start with 10kHz to 50kHz.
Worth reading this...
https://www.totalphase.com/suppo...
Observation -
The OP has not been here since #8. Perhaps he or she has gone to the PIC site, where the question really belonged. There have been several direct questions about  schematic and such with no response.
ka7ehk wrote:
Observation -
ANd here I was getting ready to split the thread as we have taken it over somewhat as well.
Other Jim
