hi everybody
i wrote the code below to scan TWI bus for available devices with no success.
any suggestions???
/* * GccApplication2.c * * Created: 04/01/2019 12:19:55 ق.ظ * Author : delta2delta@gmail.com */ #include <avr/io.h> #define F_CPU 2000000UL #include <util/delay.h> #include <stdint.h> #include <stdio.h> #include <avr/interrupt.h> #include "uart_ATX.h" #include "twi_master_driver.h" #define uart_sel uartC1 #define uc1 &USARTC1 TWI_Master_t twie; #define F_TWI 100000 int main(void) { _delay_ms(2000); uart_init(uc1,uart_sel,baud_9600,conf_8_no_1); TWI_MasterInit(&twie,&TWIE,TWI_MASTER_INTLVL_LO_gc,TWI_BAUD(F_CPU,F_TWI)); PMIC.CTRL |= PMIC_LOLVLEN_bm; sei(); uint8_t data=0; char buffer[100]; volatile uint8_t address=0; volatile uint8_t res=0; uart_put_string("scanning I2C bus...",uc1,1); // start scan------------------------------------- for (address=0;address<127;address++) { sprintf(buffer,"scanning address %d \r\n",address); uart_put_string(buffer,uc1,0); res=TWI_MasterWriteRead(&twie,address,&data,1,0); if (res==1) { uart_put_string("succeess!!!!",uc1,1); sprintf(buffer,"device address is %d \r\n",address); uart_put_string(buffer,uc1,1); } sprintf(buffer,"result for address %d is %d \r\n",address,res); uart_put_string(buffer,uc1,1); } uart_put_string("scan finished!!!",uc1,1); while (1) { } } ISR(TWIC_TWIM_vect){ TWI_MasterInterruptHandler(&twie); }
result is like :
scanning I2C bus... scanning address 0 scanning I2C bus... scanning address 0 scanning I2C bus... scanning address 0 succeess!!!! device address is 0 result for address 0 is 1 scanning address 1 result for address 1 is 0 scanning address 2 result for address 2 is 0 scanning address 3 result for address 3 is 0 scanning address 4 result for address 4 is 0 scanning address 5 result for address 5 is 0 scanning address 6 result for address 6 is 0 scanning address 7 result for address 7 is 0 scanning address 8 result for address 8 is 0 scanning address 9 result for address 9 is 0 scanning address 10 result for address 10 is 0 scanning address 11 result for address 11 is 0 scanning address 12 result for address 12 is 0 scanning address 13 result for address 13 is 0 scanning address 14 result for address 14 is 0 scanning address 15 result for address 15 is 0 scanning address 16 result for address 16 is 0 scanning address 17 result for address 17 is 0 scanning address 18 result for address 18 is 0 scanning address 19 result for address 19 is 0 scanning address 20 result for address 20 is 0 scanning address 21 result for address 21 is 0 scanning address 22 result for address 22 is 0 scanning address 23 result for address 23 is 0 scanning address 24 result for address 24 is 0 scanning address 25 result for address 25 is 0 scanning address 26 result for address 26 is 0 scanning address 27 result for address 27 is 0 scanning address 28 result for address 28 is 0 scanning address 29 result for address 29 is 0 scanning address 30 result for address 30 is 0 scanning address 31 result for address 31 is 0 scanning address 32 result for address 32 is 0 scanning address 33 result for address 33 is 0 scanning address 34 result for address 34 is 0 scanning address 35 result for address 35 is 0 scanning address 36 result for address 36 is 0 scanning address 37 result for address 37 is 0 scanning address 38 result for address 38 is 0 scanning address 39 result for address 39 is 0 scanning address 40 result for address 40 is 0 scanning address 41 result for address 41 is 0 scanning address 42 result for address 42 is 0 scanning address 43 result for address 43 is 0 scanning address 44 result for address 44 is 0 scanning address 45 result for address 45 is 0 scanning address 46 result for address 46 is 0 scanning address 47 result for address 47 is 0 scanning address 48 result for address 48 is 0 scanning address 49 result for address 49 is 0 scanning address 50 result for address 50 is 0 scanning address 51 result for address 51 is 0 scanning address 52 result for address 52 is 0 scanning address 53 result for address 53 is 0 scanning address 54 result for address 54 is 0 scanning address 55 result for address 55 is 0 scanning address 56 result for address 56 is 0 scanning address 57 result for address 57 is 0 scanning address 58 result for address 58 is 0 scanning address 59 result for address 59 is 0 scanning address 60 result for address 60 is 0 scanning address 61 result for address 61 is 0 scanning address 62 result for address 62 is 0 scanning address 63 result for address 63 is 0 scanning address 64 result for address 64 is 0 scanning address 65 result for address 65 is 0 scanning address 66 result for address 66 is 0 scanning address 67 result for address 67 is 0 scanning address 68 result for address 68 is 0 scanning address 69 result for address 69 is 0 scanning address 70 result for address 70 is 0 scanning address 71 result for address 71 is 0 scanning address 72 result for address 72 is 0 scanning address 73 result for address 73 is 0 scanning address 74 result for address 74 is 0 scanning address 75 result for address 75 is 0 scanning address 76 result for address 76 is 0 scanning address 77 result for address 77 is 0 scanning address 78 result for address 78 is 0 scanning address 79 result for address 79 is 0 scanning address 80 result for address 80 is 0 scanning address 81 result for address 81 is 0 scanning address 82 result for address 82 is 0 scanning address 83 result for address 83 is 0 scanning address 84 result for address 84 is 0 scanning address 85 result for address 85 is 0 scanning address 86 result for address 86 is 0 scanning address 87 result for address 87 is 0 scanning address 88 result for address 88 is 0 scanning address 89 result for address 89 is 0 scanning address 90 result for address 90 is 0 scanning address 91 result for address 91 is 0 scanning address 92 result for address 92 is 0 scanning address 93 result for address 93 is 0 scanning address 94 result for address 94 is 0 scanning address 95 result for address 95 is 0 scanning address 96 result for address 96 is 0 scanning address 97 result for address 97 is 0 scanning address 98 result for address 98 is 0 scanning address 99 result for address 99 is 0 scanning address 100 result for address 100 is 0 scanning address 101 result for address 101 is 0 scanning address 102 result for address 102 is 0 scanning address 103 result for address 103 is 0 scanning address 104 result for address 104 is 0 scanning address 105 result for address 105 is 0 scanning address 106 result for address 106 is 0 scanning address 107 result for address 107 is 0 scanning address 108 result for address 108 is 0 scanning address 109 result for address 109 is 0 scanning address 110 result for address 110 is 0 scanning address 111 result for address 111 is 0 scanning address 112 result for address 112 is 0 scanning address 113 result for address 113 is 0 scanning address 114 result for address 114 is 0 scanning address 115 result for address 115 is 0 scanning address 116 result for address 116 is 0 scanning address 117 result for address 117 is 0 scanning address 118 result for address 118 is 0 scanning address 119 result for address 119 is 0 scanning address 120 result for address 120 is 0 scanning address 121 result for address 121 is 0 scanning address 122 result for address 122 is 0 scanning address 123 result for address 123 is 0 scanning address 124 result for address 124 is 0 scanning address 125 result for address 125 is 0 scanning address 126 result for address 126 is 0 scan finished!!!
