Does Anybody Recognise This Switch?
11 posts / 0 new
I've spent several hours trawling the web, both images searches and every suppliers I can think of.
It's a standard 6mm x 6mm tactile switch body with an extra actuator. The outer ring is stationary with an inner operating button.
Does anyone recognise it?
Not sure what you mean by "extra actuator". Could you elaborate? Are there really two switches?
I have a bunch of those in a drawer but without the button cap.
Based on the pins coming off the back, which look exactly like the ones i have check OMRON B3F series switches
Heres a link:
https://omronfs.omron.com/en_US/...
From there you should be able to find your animal
East Side Jim
I didn't explain that very well did I?
I can find millions of tactile switches which will take a keycap...
The one I have though has a stationary outer ring and the keycap sits inside it. So the part arrowed in green is fixed, whilst the part arrowed in red is the moving keycap.
Mechanically, having that fixed outer ring has a lot going for it in my application.
Search digikey, that looks like a round spst illuminated panel mount pushbutton
It might look quite big in my photo but in real life it is only 10mm in diameter. It is a PCB mounting tact(ile) switch just 6mm square on the back.
Thanks, some of the Honyone stuff looks hopeful.
Looks like this one (Multicomp TS0B22):
https://uk.farnell.com/multicomp...
Perfect, thankyou so much. I owe you a beer.
