Buzzer toning problem
18 posts / 0 new
I want to make a buzzer toning with timer as pwm on PD4
it doesn't make any sound at all
but when i connect it to PD5 it makes sound with different levels as OCR1A values change
i think it doesn't work as pwm with those configuration
i'm using 8MHz F_CPU and prescaling of 64
or any ideas about sample code as interrupt to use PD5 for a buzzer and a Led if possible
This my code , What seems to be the problem
#define F_CPU 8000000UL /* Define CPU Frequency e.g. here its 8MHz */
#include <avr/io.h> /* Include AVR std. library file */
#include <stdio.h> /* Include std. library file */
#include <util/delay.h> /* Include Delay header file */
int main(void) {
    DDRD |= (1<<PD4);
    TCNT1 = 0; /* Set timer1 count zero */
    ICR1 = 2499; /* Set TOP count for timer1 in ICR1 register */
    /* Set Fast PWM, TOP in ICR1, Clear OC1A on compare match, clk/64 */
    TCCR1A = (1<<WGM11)|(1<<COM1A1);
    TCCR1B = (1<<WGM12)|(1<<WGM13)|(1<<CS10)|(1<<CS11)|(1<<COM1B1);
    while(1) { OCR1B = 200;
        _delay_ms(500);
        OCR1B = 100;
        _delay_ms(500);
Which AVR are you using?
Which AVR are you using?  A Mega32 by chance?
We have another freak here using the same IP you are using....you two related by chance?
Heres his code for trying to control a servo:
int main(void) {
DDRD |= (1<<PD5); /* Make OC1A pin as output */
TCCR1B = (1<<WGM12)|(1<<WGM13)|(1<<CS10)|(1<<CS11);
while(1) { OCR1A = 65; /* Set servo shaft at -90° position */
_delay_ms(1500);
OCR1A = 175; /* Set servo shaft at 0° position */
_delay_ms(1500);
OCR1A = 300; /* Set servo at +90° position */
_delay_ms(1500);
That is a REALLY odd use of a timer. I really suggest that you use EITHER (just one) of
1) A timer in PWM mode
2) A chain of delays: set port pin high, delay, set port pin low, delay, set port pin high ....
i have both atmega 16 and 32
No , but it seems he is using some of the websites i'm surfing
it's exactly the same but i still can't run the buzzer toning throughout PD4
How can i make a timer in PWM mode on PD4
can you show me code initialization for it ?
The COM1B1 bit goes in TCCR1A.
--Mike
i want to initialize the value of OCR1B that makes the buzzer so quite ( no volume at all )
i set it up to OCR1B = 0;
but it still has a volume i can hear like ticking one , i want to make it stop till later on i use it in my code
You can't. You have to turn off the output.
Set your three CS bits to zero - NO CLOCK, or as Brian mentions simply turn off the output Pin
JIm
Turn it off like PORTD &=~(1<<PD4);
OR Clear CS Like this
    TCCR1B &=~ (1<<CS10);
    TCCR1B &=~ (1<<CS11);
    TCCR1B &=~ (1<<CS12);
Try it and see which works best for you.
what is toning?  volume level?
In any case, certain PWM modes can't go down to 000000000 (absolute zero), you still get a runt pulse.
A way around that is to set the IO pin PWM control bits to give an inverted value.  You then simply adjust your pwm setting, ex:  use 255-former value (for an  8 bit example).
With those changes, you can get to zero, but then not 100% (call it 99.99)
avrcandies wrote:
what is toning
I read it as the OP is trying to have the buzzer make a simple tone.
JIm
There are two approaches to this problem.  One is to research, test, and debug the use of a timer to specifically output a PWM-based tone to a (often pre-determined) pin.  This takes a long time and entails lots of data sheet reading, timer configuration (never easy on the peripheral configuration register level), and repeated hardware experimentation.   But you can use your code on any of the 100+ AVR variants.
Or you can get an Arduino Nano/UNO module board (based on the ATmega 328P) from eBay for about $3-4 USD and download the Arduino IDE.
Now add the line below to your Arduino program/sketch:
tone(pin, frequency, duration)tone(pin, frequency, duration)     tone(D8, 500, 0.5);   // produces a 500Hz half-second beep on piezo-speaker connected to Arduino pin/via marked D8.
There are lively discussions here about which is the better approach.   Personally I'd go with the tone() function Arduino-expanded-keyword-set approach.  Because any code that you write directly transfers to any CPU that implements to Arduino-expanded-keyword-set.   So you don't have to re-read over-and-over the cryptic data sheets for insight on how make a processor-specific  implementation of same embedded-systems peripheral with every different processor that you use.  Learn one set of expressions for accessing I2C and use the same code on the Tiny85, the mid-range ATmega328P,  the fat-boy ATmega2560, and the high-end CPUs like ESP8266 WiFi, HM10 BlueTooth, and STM32F103 ARM-based Arduino module boards.
True, you won't become an expert on any individual CPU.  But the time that you would have spent doing this is now better spent on developing the specific applications that the customer is paying for.  And not dinking around with a thousand individual CPU programming details.
Arduino's are designed for kids & tinkerers playing around, professionals use real development tools and custom circuits
Home computers are made for kids & tinkerers playing around, professionals use Mainframes and flowchart templates
History repeats itself!
Yes, that is of course an easy option, but the part of the world the OP comes from they seem to like using the MEga32, and its variants, so the Arduino IDE is not a good option in this case.
And whats wrong with a little research and reading?  Setting up the Timer(s) in the AVR is not really all that hard(says someone who has failed at this once or twice).  It's a matter of understanding how the peripheral works.
If the OP elects to switch to an Arduino then we can work with that when the time comes.  FOr now we can concentrate on what the Thread is based on....a Mega 32 or Mega 16
JIm
