Question about timer0 and relative branch out of reach error
10 posts / 0 new
.include "m2560def.inc"
.equ cf = 3 ;current floor
.equ ef = 5 ; expect floor
.equ direction = 0 ;0 down 1 up
Start:
    clr r20
    clr r21
    clr r22
    ser r16
    out DDRC, r16 // set Port A for output
    ser r16
    out DDRG, r18 //
    ldi r20,cf
    ldi r21,ef
    ldi r22,direction
Loop:
    cpi r20,ef
    rjmp Go_up  //error here !!!!!!!!!
    breq end
Go_down:
    ldi r22,0
    rjmp Condition
Go_up:
    ldi r22,1
    rjmp Condition
Condition:
    cpi r20, 1
    breq First_Floor
    cpi r20, 2
    breq Second_Floor
    cpi r20, 3
    breq Third_Floor
    cpi r20, 4
    breq Forth_Floor
    cpi r20, 5
    breq Fifth_Floor
    cpi r20, 6
    breq Sixth_Floor
    cpi r20, 7
    breq Seventh_Floor
    cpi r20, 8
    breq Eighth_Floor
    cpi r20, 9
    breq Ninth_Floor
    cpi r20, 10
    breq Tenth_Floor
First_Floor:
    ldi r16, 0x00  // write the pattern
    out PORTC, r16
    ldi r18, 0x04
    out PORTG, r18
    cpi r22,1   //error here !!!!!!!!!
    breq goup
    rjmp godown
Second_Floor:
    out PORTC, r16
    ldi r18, 0x0C
    out PORTG, r18
    cpi r22,1
    breq goup
    rjmp godown
Third_Floor:
    ldi r16, 0x01  // write the pattern
    out PORTC, r16
    ldi r18, 0x0C
    out PORTG, r18
    cpi r22,1
    breq goup
    rjmp godown
Forth_Floor:
    ldi r16, 0x03  // write the pattern
    out PORTC, r16
    ldi r18, 0x0C
    out PORTG, r18
    cpi r22,1
    breq goup
    rjmp godown
Fifth_Floor:
    ldi r16, 0x07  // write the pattern
    out PORTC, r16
    ldi r18, 0x0C
    out PORTG, r18
    cpi r22,1
    breq goup
    rjmp godown
Sixth_Floor:
    ldi r16, 0x0F  // write the pattern
    out PORTC, r16
    ldi r18, 0x0C
    out PORTG, r18
    cpi r22,1
    breq goup
    rjmp godown
Seventh_Floor:
    ldi r16, 0x1F  // write the pattern
    out PORTC, r16
    ldi r18, 0x0C
    out PORTG, r18
    cpi r22,1
    breq goup
    rjmp godown
Eighth_Floor:
    ldi r16, 0x3F  // write the pattern
    out PORTC, r16
    ldi r18, 0x0C
    out PORTG, r18
    cpi r22,1
    breq goup
    rjmp godown
Ninth_Floor:
    ldi r16, 0x7F  // write the pattern
    out PORTC, r16
    ldi r18, 0x0C
    out PORTG, r18
    cpi r22,1
    breq goup
    rjmp godown
Tenth_Floor:
    ldi r16, 0xFF  // write the pattern
    out PORTC, r16
    ldi r18, 0x0C
    out PORTG, r18
    cpi r22,1
    breq goup
    rjmp godown
goup:
    inc r22
    rjmp Loop
godown:
    dec r22
    rjmp Loop
end:
    rjmp end
Line 26 and 70 have the error about "relative branch out of reach "
How could I fix it?
Moreover, I am asked to use timer0 to count 2 seconds for each loop, could anyone tell me how to do this?
Thanks a lot!
Greetings and Welcome to AVR Freaks =
rjmp (relative jump) has a VERY limited jump range. Use one of the absolute jump instructions, instead. Though, that jump does not look particularly large.
The cpi seems OK. You reference a register in the upper 16, as required, and the constant is in the range of 0 to 255. Don't see a problem, there.
Are you certain that you are referencing the correct lines, because the cpi instruction does not involve any jumps. But the nearby branch does.
TheTrueManHere wrote:
How could I fix it?
place the goup / godwn functions after floor6 and before floor7 code, in other words, move the function down lower in the code so each call to it is a shorter distance!
As for the timer question, go read the tutorial in the tutorial forum on timers, you should find your answer there.
PS:  Welcome to AVRFreaks.
MUST you use assembler?  C would be so much easier.
But anyway, WHat is your AVR clock speed, and do you have the DIV8 fuse programmed?  From there one can figure out what timer to use to make a 'tick' every 10 milliseconds and generate an interrupt where a counter can be incremented.
Your main code looks at this counter and determine if enough 'ticks' have passed for two seconds.  Once this has happened you 'do something', clear the counter and repeat the process.
Wouldn't it be a lot clearer if you told use the content of the lines, for which you only gave line numbers?
Yes, sometimes you can re-arrange your code to avoid branches out of reach.  But you need to lean how to handle the situation if you are going to write in assembler.  The situation will arise wit all [?] micro processor/controller work, not just AVR.
There are prior threads on this.  Try searching them out.
A common method is to reverse the sense of the comparison, and introduce a branch with a longer reach.  Lessee--now I have to count your line numbers...
Loop: cpi r20,ef rjmp Go_up //error here !!!!!!!!! breq end
I don't think that is where the error is.
1) Surely the RJMP is within reach.
2)  The BREQ line will never be reached.
2a)  Learn to use the AtmelStudio simulator to see what I mean.
Reversing the sense...
   CPI R20, ef
   BRNE NEARBY
   RJMP END ; "FAR AWAY"
NEARBY:    ;  INTRODUCE THE LABEL
Oh, finally it works
The Atmel shows the wrong line
Thanks a lot
Thanks, it works.
The rearrange work is really important in assembly, haha
When I built the code Studio 7 said:
When I double-click either of those errors it takes me to:
and
So it seems to be an "out by one" error. It's the "breq" in each case.
As Lee says a common solution is:
    brne dont_goup
    jmp goup
dont_goup:
    rjmp godown
That is to change the sense of the branch from breq to brne then do a "long jump"
BTW the sequence:
Loop:
    cpi r20,ef
    breq end
The breq here is AFTER the rjmp - it can never be reached !!
In general only use BREQ etc. for things “inside” the block you are working with.
In this case invert the branch use BRNE over the a rjmp (as cliff showed).
If rjmp can’t reach I will say that your program start to be too big for ASM.(it reach +-2K instructions)
That way you don't need to rearange anything when you add things.
If you have many jumps out from one variable, (where you would use a switch in C), then it could make sense to build up to use a ijmp.
