Blinking LED without delay
10 posts / 0 new
 Hello friends,
i'm trying to blink a LED using Atmel studio and Proteus. I use two "for loops", one to set "PA0" LOW; the other to set "PA0" LOW. The problem is when i set the counter of the for loop above 200 the LED does not turn off
#define F_CPU 1000000UL
    DDRA |= (1 << PA0);
    while (1)
		for (uint8_t i = 0; i <= 300; ++i)
			PORTA|= (1 << PA0);
		for (uint8_t x = 0 ; x <= 300; x++)
		PORTA&=~ (1 << PA0);
	return 0;
So much nicer looking when you use proper spacing:
#include < avr / io.h >
  int main(void) {
    DDRA |= (1 << PA0);
    while (1) {
      for (uint8_t i = 0; i <= 300; ++i) {
        PORTA |= (1 << PA0);
      for (uint8_t x = 0; x <= 300; x++) {
        PORTA &= ~(1 << PA0);
    return 0;
ki0bk wrote:
uint8_t
What is the range of values for an unsigned 8 bit variable type?
Can that possibly count to 300?
Using a timer would be simpler and frees up the AVR for other tasks too....
East Side Jim
For some reason, this thread title reminded me of this..
Yes ki0bk, you got what i miss. This solves the problem.
uint8_t  is just 1 byte = 256 bits, so it cannot count above that number
Thread title says "without delay". I'd say that sticking in a loop doing the same thing 300 times is still a "delay" !
If you really want to flash "without delay" then explore using a timer interrupt.
The problem is, what if i cannot use a delay because the external crystal (oscillator) is broken or does not work. So i just wanted to do that trick to avoid the existence of the oscillator.
If there's no clock, then your code will not work anyway.
And 255 is the highest number held in a uint8_t, not 256.
Of course there's an internal clock. And yes 255 number, but 256 counts ( 0 --> 255).
