External memory
12 posts / 0 new
Hi all,
I need some tips about external memory which is conected on ATmega 128.
I was use IS63LV1024-12JL (3V) on STK501 board and everthing was fine..
Now I use IDT71024S12YG (5V)with 74HCT573 (Ti)latch on my board with same connections (only pinout is diferent)like on STK501, and I can write and read anything from it.
I was change CPU and memory, only latch was not changed (becouse I do not have it another).
Wait states and port pull-up's changed to but with no effects...
Any help is welcome.. :cry:
Thanks in advance.
G.P.
what's your clk freq?
Did you connect cs1 to GND?
You could start by posting your schematic.
Used crystal is 11059200 Hz.
CS1 is on GND throu Atmega's port PB.6
CS2 is on +5V.
does the d-ff ever clock in the data with that large a rc time?
With IS63LV1024 memory everything works fine (and with 16 Mhz crystal ), so there is no reason for IDT to not work...
Which Vcc for the Mega128, the memory and the HC473 ?
Mixed up 5V and 3.3V devices?
Maybee HCT473 could solve the Problem.
Have a look with an oscilloscope an the signals.
hws
Mcu and HCT are on +5V.I will trace signals and post what I find out.
Signals on A2,3,4,5 of IDT after HCT573 (+5V):
and signals on A7 IS after HC573 (+3V STK501):
Hi ,
Find error on LE pin HCT573 was to big cap. 100n!
Here is pic with 100 pF cap. on LE pin. Same thing is
and with A0-7 pins, if you wona reduce spikes just put
100 pF cap. on desired pin and GND!
Thanks all for help!
