Simple D20 Pin Toggle Not So Simple
7 posts / 0 new
Back again.
THis time I am just looking to blink an LED.  So I fired up Atmel Start and used all the defaults and named the first 8 pins of PORTB 'MY_PORT_x" where 'x' is the pin number from 0 - 7.
In my atmel_start_pins.h file I have this:
#ifndef ATMEL_START_PINS_H_INCLUDED
#define ATMEL_START_PINS_H_INCLUDED
#include <hal_gpio.h>
// SAMD20 has 8 pin functions
#define GPIO_PIN_FUNCTION_A 0
#define GPIO_PIN_FUNCTION_B 1
#define GPIO_PIN_FUNCTION_C 2
#define GPIO_PIN_FUNCTION_D 3
#define GPIO_PIN_FUNCTION_E 4
#define GPIO_PIN_FUNCTION_F 5
#define GPIO_PIN_FUNCTION_G 6
#define GPIO_PIN_FUNCTION_H 7
#define MY_PORT_0 GPIO(GPIO_PORTB, 0)
#define MY_PORT_1 GPIO(GPIO_PORTB, 1)
#define MY_PORT_2 GPIO(GPIO_PORTB, 2)
#define MY_PORT_3 GPIO(GPIO_PORTB, 3)
#define MY_PORT_4 GPIO(GPIO_PORTB, 4)
#define MY_PORT_5 GPIO(GPIO_PORTB, 5)
#define MY_PORT_6 GPIO(GPIO_PORTB, 6)
#define MY_PORT_7 GPIO(GPIO_PORTB, 7)
#endif // ATMEL_START_PINS_H_INCLUDED
Ok, so next I create a little program that based on wading through a lot of files I came up with this:
#include <atmel_start.h>
//#include "sam.h"
#include "hal_delay.h"
	/* Initializes MCU, drivers and middleware */
	atmel_start_init();
	uint8_t COUNT = 0;
	while (1) {
		COUNT++;
		PORT_IOBUS->Group[1].OUTTGL.reg = MY_PORT_0;		//no good!  flashed portb pin 5 instead!!
		delay_ms(250);
compiles without a problem.  I go and program the D20 and I am surprised to see PORTB PIN 5 blinking instead!  WTH!
Sooo, after some searching here I tried this:
//#include "sam.h"
	atmel_start_init();
	uint8_t COUNT = 0;
	while (1) {
		COUNT++;
	    PORT_IOBUS->Group[1].OUTTGL.reg = PORT_PB00;		//this works  flashed portb pin 0
		delay_ms(250);
and this does as expected.  Blinks PORTB, pin 0
I tried this:
//#include "sam.h"
	atmel_start_init();
	uint8_t COUNT = 0;
	while (1) {
		COUNT++;
		_gpio_toggle_level(GPIO_PORTB, PORT_PB00);		//this works  flashed portb pin 0
		delay_ms(250);
and that worked , PORTB, pin 0 blinks
But
//#include "sam.h"
	atmel_start_init();
	uint8_t COUNT = 0;
	while (1) {
		COUNT++;
		_gpio_toggle_level(GPIO_PORTB, MY_PORT_0);		//no good!  flashed portb pin 5 instead!!
		delay_ms(250);
also flashes PORTB, pin 5 as well.
It is/was my understanding that when I set up the port in START that the pin names would carry into the project through atmel_start_pins.h, but that does not seem to be the case.
Experts, any ideas?
JIm
If you are using AtmelStart.. Trying using the built in GPIO API..
gpio_set_pin_level( MY_PORT_0, TRUE );
murph
Debugging - Being a detective in a crime movie where you are also the murderer.
THat worked.  It set bit 0, and left the rest logic 0.
But if I do this:
gpio_toggle_port_level(GPIO_PORTB, MY_PORT_0);
Port b Pin 5 toggles.
If I do this:
gpio_toggle_port_level(GPIO_PORTB, (MY_PORT_0 + 1));
Pins 5 and 0 toggle.
Grrrrr...I am missing something simple here and i don't know what it is.
Step through the code looking at the assembler! The truth should be revealed!
Shouldnt your
be
gpio_toggle_pin_level
Just browsing through, if I declare some PINs in Start:
#define PORT_04 GPIO(GPIO_PORTB, 4)
#define PORT_05 GPIO(GPIO_PORTB, 5)
Then the GPIO macro is declared as
#define GPIO(port, pin) ((((port)&0x7u) << 5) + ((pin)&0x1Fu))
So, the GPIO is a number combining the PORT and the PIN into a single number.
Then, looking over the gpio_ functions:
So, gpio_toggle_pin_level unwraps this number into a port and a pin...
:: Morten
Thanks Morten!  I see the error of my ways somewhat.  But based on your explanation above, why doesn't the 'gpio_toggle_port_level()' unwrap the number?  from the description in the comments shown both do the same thing, just differently.
No, port_level takes a port and a mask of pins to toggle, while pin_level takes a GPIO and unwraps it to the port and mask for that pin.
:: Morten
