Atmel Studio 7 cannot browse to find Arduino source.
28 posts / 0 new
I have recently downloaded Atmel Studio 7 and have been trying to use it to improve on an Arduino sketch I have been toying with. As per the tutorials out there, I clicked New Project > Create project from Arduino sketch>OK, and a form appears to set the source file and Arduino paths. The Arduino path browse button (...) works fine, but the Sketch file browse button, when pressed, returns a message box showing 'The system cannot find the drive specified'. If I close this and try again, Studio 7 shuts down, and then restarts. Any ideas why I cannot browse to a file on this m/c. Interestingly, I have tried it on another PC, running the same OS (W10) and the problem is not there - all works OK. Admin mode doesn't help. Could this be an Explorer problem/setting ?
Are you able to build that sketch in Arduino IDE?
Charles
Hi Charles
Yes I am able to build it, but at this stage, AS7 doesn't know what 'that sketch' is. I have only got as far as saying I want to create a project from an Arduino sketch, and it is at the stage, where I should be browsing for the sketch, that it fails.
Which version of Arduino IDE and Atmel Studio do you have installed in the machine?
Could you check whether %localappdata%\Arduino15\preferences.txt is available in your machine ?
I would recommend you to use the latest Atmel Studio version 7.0.1931.
1) Start with a Blink.ino file in Arduino verify it from Arduino IDE
2) Start Atmel Studio and see whether it populates automatically with the latest sketch used in Arduino IDE
Charles
Hi Charla
Arduino IDE is version 1.8.5, Atmel Studio is 7.0.1931
Blink.ino verifies OK and also uploads and runs fine.
When I start Atmel Studio, and choose New Project > Create project from Arduino sketch > OK, the sketch file field is blank and the browse button shows the message I described above.
Thank you for your interest
Graham
Oh, and I can see preferences.txt
Could you share the file %localappdata%\Arduino15\preferences.txt  ?
Charles
As a workaround could you paste the sketch file path in  C:\Program Files (x86)\Arduino\examples\01.Basics\Blink\Blink.ino instead of browsing.
Hi Charles
If I paste the file location it works fine, but I cannot browse to it. Preferences file attached.
Graham
I am having this same problem as Monitair.
I just loaded Atmel Studio 7.0.1931 and have Arduino IDE 1.8.5 and when going to load the sketch file (find it with the browser button)  I get the error "The system cannot find the drive specified". I then cancel the dialog and Atmel Studio crashes.  My arduino ID is located at: C:\Program Files (x86)\Arduino.  I did install Atmel Studio as Administrator. As Monitair suggested if you cut and paste path into sketch location box all works, but this is not an acceptable work around.
Does anyone know why this is occurring? Is the error message bad syntax and that it is a permissions thing etc.
I'm guessing it's not the Arduino IDE location throwing the error but the default choice for "Sketch file".
@Clawson,
 ...but the default choice for "Sketch file".
What you need to understand is that when this happens to me, I don't even get the choice; i.e. when I click on the "..." browse button, it throws this error. Unless you are saying that my default installation is defaulting the sketch location to a bad location?  Is there a way to create an error log when this happens to see in more detail what the issue is?
AS7.0 has let me Browse for the sketch ok.
It started with the previous directory I had used in a different AS7 project.
I suggest that you "Open" any file on your C drive.   Then it will probably start Browsing from that directory.
It found the correct directory for my v1.8.8 installation.
It found that my current project was for a MEGA2560
It did not assume ATmega2560.   I had to choose 1280 or 2560.
AS7.0 is ok for importing very simple sketches for Uno, Mega.
It is crap for Zero, Due, ...
It is crap for multi-file sketches.
It is crap for functions with pointer arguments.
though not zero price :
Developing code for ARM-based Arduino boards with Visual Studio – VisualGDB Tutorials
In this tutorial we will create a basic “Blinking LED” project for the Arduino Due board and will show how to FLASH it using the built-in bootloader and debug it using Segger J-Link.
One thing you could try is ProcMon from sysinternals. Set a filter on atmelstudio.exe and CreateFile and you will be able to see what directory/files it's trying to access. When I do that on my machine here and open the Create C++ project from Arduino sketch dialog I see this activity...
I'm guessing you may see something "odd" here.
Some years ago Visual Studio Micro created an add-on to AS5 or AS6.    It worked well.
If you installed it you were subjected to Spam for evermore.    I don't think it was possible to Uninstall it.
I have no problem with purchasing software,  buying licences,   ...
If there is a VS VisualMicro User that can make a personal recommendation,   I would be happy to try VS VM.
Without such assurance I will not touch it with a bargepole.
Meanwhile,   I will continue to build in the Arduino IDE.   Debug the "Externally Built Executable" in Rowley Crossworks.     Which works fine with STM32, Zero, Due, ...
Edit.   I had mistakenly assumed Visual Studio was the same as Visual Micro.    It is a different product.
Hi David,
I have already tried what you suggested and it does not work or help my issue. - i.e. I entered a direct path - something like C:\temp\blink-test\Blink-test.ino and Studio will accept this sketch and build it, but if I try to click the browse button to the right of this input Box for the sketch, even after I enter the direct path I still get the error dialog and the crash of Studio.
Mark
Thank you Clawson,
I will try this tonight when I get home.  Gotta go earn a living right now... :-)d
What happens with regular AS7 "Open Project" or "Open C file" ?
Does this Browse correctly.
I suspect that you have been using an imaginary Drive somewhere.    Browse "starts" at the imaginary location and crashes when it does not exist (instead of flagging an error).
Some years ago Visual Studio created an add-on to AS5 or AS6.
Visual Micro?
Arduino IDE for Visual Studio
alternate path : Arduino IDE for Visual Studio - Visual Studio Marketplace
The ones at Microsoft, along with other ones, created an Arduino extension for Microsoft Visual Studio Code :
https://www.avrfreaks.net/forum/avr-studio-mac-linux#comment-2440271
Oops.   Yes,  I meant Visual Micro.
So Visual Studio is a different product.
My apologies.   I will edit my previous message.
"imaginary drive" can often mean a network share that is later disconnected.
Here is a snipet from a file that was written by microsoft  and put in my app-data/local directory when the crash occurred:
LoadedModule[202]=C:\WINDOWS\SYSTEM32\MPR.dll
LoadedModule[203]=C:\WINDOWS\System32\drprov.dll
LoadedModule[204]=C:\WINDOWS\System32\ntlanman.dll
LoadedModule[205]=C:\WINDOWS\System32\davclnt.dll
LoadedModule[206]=C:\WINDOWS\System32\DAVHLPR.dll
LoadedModule[207]=C:\WINDOWS\System32\wkscli.dll
LoadedModule[208]=C:\WINDOWS\SYSTEM32\cscapi.dll
LoadedModule[209]=C:\WINDOWS\System32\netutils.dll
State[0].Key=Transport.DoneStage1
State[0].Value=1
File[0].CabName=WERInternalMetadata.xml
File[0].Path=WER5686.tmp.WERInternalMetadata.xml
File[0].Flags=851971
File[0].Type=5
File[0].Original.Path=C:\Users\mbiasotti\AppData\Local\Temp\WER5686.tmp.WERInternalMetadata.xml
File[1].CabName=triagedump.dmp
File[1].Path=WER62AE.tmp.dmp
File[1].Flags=539820035
File[1].Type=6
File[1].Original.Path=C:\Users\mbiasotti\AppData\Local\Temp\WER62AE.tmp.dmp
File[2].CabName=WERDataCollectionFailure.txt
File[2].Path=WER6791.tmp.WERDataCollectionFailure.txt
File[2].Flags=851971
File[2].Type=5
File[2].Original.Path=C:\Users\mbiasotti\AppData\Local\Temp\WER6791.tmp.WERDataCollectionFailure.txt
File[3].CabName=Report.cab
File[3].Path=Report.cab
File[3].Flags=196608
File[3].Type=10
File[3].Original.Path=Report.cab
FriendlyEventName=Stopped working
ConsentKey=APPCRASH
AppName=Atmel Studio 7.0
AppPath=C:\Program Files (x86)\Atmel\Studio\7.0\AtmelStudio.exe
NsPartner=windows
NsGroup=windows8
ApplicationIdentity=C8011494DCE04A8A99E6BE2B1AC19541
I finally solved this - or rather Bob Martin solved this for me (who's class I attended this last Saturday at Microchip - Arduino Celebration day: it was excellent) Here's what he wrote back to me:
This is a known and very strange issue with a simple fix
The problem exists within the preferences.txt configuration file used by the Arduino IDE
In the Arduino IDE ,under File à Preferences towards the bottom of the dialog window will be the explicit path to this file which you can click on to open up the specific location in File Explorer.  Open this file in any text editor and you will see references to
last.sketch0 à last.sketch4
last.sketch.default.path  and
recent.sketches=
with possibly a long list of explicit paths to all the sketches that have been opened
Somewhere in these lines, is a path, usually to a network drive, that isn’t valid at the time you are trying to import via Atmel Studio.
This is why Atmel Studio is blowing up since it’s trying to parse an invalid path specified in that file.  Technically you can wipe the recent.sketches paths and just leave
recent.sketches=
Save a copy of the preferences.txt as backup and then start looking for paths that are not currently valid, again network drives that are not actively mounted or external USB drives that are not available. That’s where the problem is.
cheers
bob m
Thank you Bob for the quick response and fix. I have verified that it is, in fact, the problem and now Studio 7 - loading Arduino Sketch location works.
Thanks Bob for your response and also mbiasotti. This solved my problem.
Thanks & Regards,
Avinash
I did not have this problem until I upgraded to version:7.0.2397.
editing the preferences.txt worked for me also.
hi,I use version:7.0.2397 but not work button.I am getting an error. I tried edit preferences.txt but not worked.Can you help me pls?
This thread saved so much of my time. I restarted my PC more than 4 times and uninstalled and reinstalled the AS7 2 times thinking my PC has a virus or something. The very first time I tried to search the path for the Blink LED program, it worked fine but the errors started surfacing when I tried to make a second attempt. Editing the preferences file worked for me too. Thank You so much.
J27
