Input Capture control
16 posts / 0 new
I've been struggling with this problem for a while and I'm just not getting it.
ATmega328P @ 16MHz, 5V
I'm receiving a pulse on the ICP1 line and I want to have the ability to turn the Input Capture unit on and off.
In my main method I have:
	TCCR1B  |= (1 << ICES1);
	DDRB |= (1 << PB0);
	PORTB |= (1 << PB0);
then in my Run method I have:
	// Set port to input
	DDRB &= (0 << PB0);
	// Configure no prescale
	TCCR1B  |= (1 << CS10);
	// Enable Input Capture Interrupt
	TIMSK1 |= (1 << ICIE1);
then in my Stop method I have;
	TIMSK1 &= (0 << ICIE1);
        // Stop clock
	TCCR1B  &= (0 << CS10);
        // Set port to output
	DDRB |= (1 << PB0);
Any help appreciated!
Happy Trails,
Mike
JaxCoder.com
DDRB &= (0 << PB0);
Doesn't this just clear the register? Is that what you really want to do?
Mike
DDRB &= (0 << PB0);
// Stop clock
All of the &= above will set the entire register
to zero, not just the bit you want.
The way to turn off a single bit is like this:
DDRB &= ~(1 << PB0);
Since PB0 is 0, the mask will become 11111110.
--Mike
What is with all this |= stuff?  Show a complete test program.  >>Set<< the configuration registers.
theusch wrote:
As I am fond of saying:
For some reason, many posters on this site have a love affair with |=. There must be a sale on "|" in full-reel quantities.
Thank you can't believe I've made this rookie mistake.
I used to always use _BV() but just recently switched to the (x << y) way of doing it and saw the val &= (0 << n) and just ass-u-me-d.  (blushing profusely)
But the question still remains, how to I control the ICP1 port?
Also I'm not getting response notifications and I have checked the box below.  Not working?
Happy Trails,
Mike
JaxCoder.com
What do you mean by "control the port"?  If you mean disabling the interrupt, you haven't shown the corrected code, nor a complete program.
Please explain what you are trying to do. The input
capture feature just causes whatever value is in TCNT
to be copied into ICR when an event occurs. An event
is either the analog comparator flipping state (on some
chips), or an external pin change.
--Mike
EDIT: ICR, not ICP
There seems to be a similar love affair with PB, as in PB0.
The children are really ugly.
But it's the same whichever of those us use. If I want to clear bit 5 in something I can say
SOMETHING &= ~(1 << 5);
or I can say
SOMETHING &= ~_BV(5);
but in both cases you need a 1 bit and then you also need the ~ that inverts it (a byte with everything but that bit set).
Think about what (0<<N) does. Go back to first principles ...
Into a byte which is 0b00000000, you left-shift a zero N places. So, what do you get? 0b00000000!
When you OR that with anything, as in "|=", 0 OR'd with anything changes nothing. E.g. X |= 0x00 = X
When you AND that with anything as in "&=", 0 AND'd with anything makes zero. E.g. X &= 0x00 = 0x00
To clear a bit, first you create a bit mask, as in (1<<N). For example, (1<<PB3) = 0b00001000
Then you complement it, ~(1<<N). For example ~(1<<PB3) = 0b11110111
Now, you AND this with the byte containing the bit to be cleared. For example PORTB |= ~(1<<PB3).
That zero in the complemented mask clears the PB3 bit in PORTB.
<edit> Perhaps to point out the obvious (which might not be), neither the shift (to create the mask) nor the complement take any run-time. The compiler figures it out and uses the constant equivalent. </edit>
Hope This Helps
Be careful with _BV() and even (x << y).  The macro for _BV() will fail if the supplied parameter is greater than 14. This is because with AVR-GCC, the default is an INT (signed 16 bit value).
So, if you do this:  REGISTER |= _BV(15)  it will fail because the macro tries to do (1 << 15) where 1 is a signed int.  You need to either edit the macro (in sfr_defs.h) and change the 1 to 1UL or else use (1UL << x).
First let me say that the
I used above is only used in that one area.  Every other place I do that I use
TIMSK1 &= ~(1 << ICIE1);
so I'm not sure why I did it there except pure frustration.
Second I use |= method because I feel that
TIMSK1 |= (1 << ICIE2);
is a lot more meaningful and informative than
TIMSK1 = 0x20;
that is my and appears many others opinion.
Third I don't list the entire program because it is 4K worth of code and this is the only part that is not working.  I thought I post enough to give a general idea of what I was doing.
My syntax may have been bad but my question was more in line of is my logic correct.
Forth;  what I'm trying to do is enable/disable the input capture port and associated interrupt handler.   So I will give it one more try.
My initialization code
	// Set internal pullup resistor for Timer1 ICP1
To enable
	// Configure for rising edge detect and no prescale
To disable
	TCCR1B  &= ~(1 << CS10));
Obviously the logic is not correct because it does not work.
Happy Trails,
Mike
JaxCoder.com
Bull.  Now, you still haven't given us context.  We don't know what else may be going on.  I gave you links above, and can give many more, where gratuitous use of |= has caused problems.
But let's put all that aside, and let me re-read the thread ...
Construct a complete test program that demonstrates the symptoms.  Often, that process will uncover the cause of that situation.
I re-read the thread, and am still not clear what "does not work" means.
What are "methods"?  C++/Arduino, perhaps.  Which has default setups for timers.  Which indeed makes |= important.
TIMSK1 = 0x20;
Did you mean hat using the bit names is more informative than the magic numbers?  Of course.  But then don't use the |=.
As luck would have it I went from this thread to the "rouge bit" thread https://www.avrfreaks.net/forum/...
The cause there may very well be the gratuitous |= ...
The code you're showing looks fine, so what
do you mean when you say it's not working?
I'd have to guess that you are toggling ICP1
and your interrupt is not getting called? Make
sure the interrupt name matches the name in
the datasheet. Is the compiler printing any
warnings? Set the warning level to "All" and
fix anything and everything it mentions.
--Mike
--Mike
Finally, thank you that's all I wanted to know.
Happy Trails,
Mike
JaxCoder.com
