Debuging in AVR Studio 4
3 posts / 0 new
I want ask if i may forced some bits?. i need forced bits whitch are setup by hardware.
TWINT is one of them. Its set by HW to 1.
while(!(TWCR & (1<<TWINT)));
Is it possible to change bits as needed by my application?  Thank you
New
You should be able to click the "blobs" in that picture to set the bits you want to simulate. Alternatively AS4 has "stimuli files" which is a more complex way to achieve the same (it lets you play in complex patterns of bit setting over and over again).
If I click on the "blob" TWINT and I am in debugging mode in line when check if was TWINT set to 1 and press F11 to another step blob TWINT is set to 0, but in debug I stay on the same line.
New
