What value is the PIN toggle?
40 posts / 0 new
So I was thinking that the PIN toggle was a temporary toggle, but apparently that was incorrect.  Given that it toggles the PORT pin permanently, what purpose does it have:
        PINF|=_BV(PORTF_WR_PIN_AL); //toggle WR
 202:    7c 9a           sbi    0x0f, 4    ; 15
 204:    7c 9a           sbi    0x0f, 4    ; 15
-or-
        PORTF&=~_BV(PORTF_WR_PIN_AL); //take wr low
 206:    8c 98           cbi    0x11, 4    ; 17
        PORTF|=_BV(PORTF_WR_PIN_AL);  //take rd back high
 208:    8c 9a           sbi    0x11, 4    ; 17
Toggle in 1 cycle instead of a RMW?
:: Morten
How about to toggle the output pin?  You know, like, when you want toggle it, maybe flash an led
If it toggling not available & you had to code it yourself (as on some other micros), would you be happier?
Well, given that I can set or clear a bit already using cbi/sbi on the port, the only thing pin toggle gets me is that I don't need to know the initial state.  I know, I know, I shouldn't complain about a feature.  I was hoping it would do a pulse on the pin and return to its original state.
Think of Pin Toggle like a toggle switch....its always going to be sent to the opposite state when activated, and stay there until activated again, rinse repeat.
JIm
 That can be a pretty significant advantage, since otherwise you're looking at four(ish) instructions instead of just one...
To use single cycle instructions sbi/cbi, as you not, you have to know the initial state.
But, stop for a moment and think of what that implies.
To know the initial state, you have to read the port.
That is not enough, though. You have to test the appropriate bit from that port (often involves a mask), then make a decision based on that masked port value.
So, now, there are 4 clock cycles, more or less.
Toggle goes in 1 cycle. If you only have a few instances, that does not buy you much. But, if you have several or execute a toggle in a many-pass loop, it can add up quickly.
Now, we do know that you are a bit miffed that it does not do what you want. We are all faced with that little problem at some time, maybe several some times. It happens. And, its neither the first time nor the last. To make a short pulse, just toggle, then immediately toggle again.
Frankly, I hardly ever use toggle, because I want those port pins to be in a totally known state, not just the opposite of what ever it happens to be at this instant. For me, that is one of the aspects of "defensive programming": rather than relying on some initial condition that might or might actually be the case, do something that results in a known state, no matter what the initial state.
What about a XOR boy? You don't have to go steaming into the Mask/Test/Modify like a bull in a china shop.
(waits to see differences in cultures)
What about a XOR
But there's no XORI instruction, so you end up with
  ldi t1, BITMASK
  in t2, PORT
  xor t2, t1
  out PORT, T2
If you're lucky, you can use t1 more than once...
Your syntax is surely wrong?. You don't want to use OR do you ?
But how would you set the pulse's width? Would you want a 1 clock-cycle width pulse? Or a 2, or a 3....
Not that this really matter for this thread but:
sbi and cbi take 2 clk  out (and in) only take 1 clk.
Just have that in mind if we talk about speed.
You are so right!
Exactly my point; if you are doing this anyway, then PIN toggle has no benefit as you already know its state and can SBI or CBI it in a single instruction to the opposite state.
You bring up a good point clawson, I had the OR in their by mistake.  In C this would mean take the existing value, OR this value into it, then store it, but it is optimized into a bit operation sbi instead.  When I remove the OR and do an assignment, it takes two instructions instead:
 112:    80 e1           ldi    r24, 0x10    ; 16
 114:    8f b9           out    0x0f, r24    ; 15
I was thinking as short as possible, something on the order of twice as fast as what sbi cbi could do would have made it interesting.
Then you problem is already solved, by using = instead of |=.
Tell how that would be "interesting".  What are you doing, tickling some high-speed logic?  What kind?  If you do an SBI-CBI pair, then you get a pulse of two AVR clock cycles.  As you are on an apparent quest for speed, one would surmise that you are running at a fast AVR speed.  At 8MHz, that would be 250ns.  At 16MHz, that would be 125ns.  What is the need for something that short?
Using the toggle feature, the pulse width can be no shorter on an AVR8.  You tell us what the use is of the new-fangled toggle feature.  Yes, it is much less painful than the RMW sequence.
theusch wrote:
david.prentice wrote:
So why did Atmel change the SBI functionality?
???  That would seem fairly obvious to me -- to create a mechanism to modify [individual] port bit values without introducing possible RMW side effects.  Unless I'm way off.
It more-or-less seems to coincide with the timeline of write-to-PIN-to-toggle.  In practice that doesn't come up often, but prior it is painful to toggle an AVR8 I/O port bit.
theusch wrote:
[As seen, toggling an I/O port bit in classic AVR models is a painful process. With any of the IN/OUT methods there is a RMW situation where one must be aware of if working with the same poirt in an ISR. Thus, Atmel gave us the PINx write for toggling on new models. While I often use the construct during dev as an indication that a piece of code has been reached, and/or for timing purposes, I'm hard-pressed to think of a time I toggled a port-pin I/O bit in final production firmware.] Lee
I don't know of a way on AVR8 to create a pulse narrower than one AVR cycle.  For a single pulse, consecutive OUTs to the associated PORT with prepared registers containing the desired values for all bits in the port.  For repetitive operation or rat-a-tat-tat a few times, timer in CTC mode and a compare of 0.
'E' for an LCD has min 220ns time, wonder if it's an attempt to drive that as fast as possible?
I am not following what you mean.
Interesting as in something that was better than what you can already do with PORT.  If with PORT you can SBI/CBI in two clock cycles, it would have been interesting to write a bit to PIN and do it in one clock cycle!  I am working on an AVR to Z80 project so part of it is a response to to the Z80 doing an IN our OUT instruction.  Every cycle it waits is every cycle it is doing nothing.  So, my hope was a single SBI would toggle a pin in 1 cycle.  Not a huge deal, I just really thought the toggle a pin PIN=_BV(x) was something cooler than it is.
lol -- alank2 investigated this "pin toggle" in 2017...
just as side info, chips with a PLL like tiny85 can make shorter pulses using the timer.
Back to OP's quistion, the place I have used it is in a ISR to make interrupt taken, a 5 uS pulse is harder to see, and rare interrupts can be marked with just a LED on the port.
other side info the first AVR's like the 8515 didn't have this function.
PINx assignment can also be useful when one port is shared
among multiple modules, each of which uses a different interrupt.
If all the modules stay in their lanes, one can get the effect of
atomic assignment under mask.
Note that there is disagreement about what a compiler
is allowed to do which constructs like "PINx |= 4".
There is also disagreement about what a compiler ought to do.
My though is that a compiler ought to reject them altogether.
Instead there should be a macro or other construct
that becomes a singe sbi instruction.
At one time avr-gcc has such a macro,
but it was removed in favor of letting the
compiler proper handle the optimization.
"SCSI is NOT magic. There are *fundamental technical
reasons* why it is necessary to sacrifice a young
goat to your SCSI chain now and then." -- John Woods
What I mean is that this code
#define PORTF_WR_PIN_AL 4
int main () {
        PINF =_BV(PORTF_WR_PIN_AL); //toggle WR
Compiles to:
000000fa <main>:
  fa:	80 e1       	ldi	r24, 0x10	; 16
  fc:	8f b9       	out	0x0f, r24	; 15
  fe:	8f b9       	out	0x0f, r24	; 15
Since out takes 1 cycle to execute, unlike sbi which takes 2 cycles, this will give a 1 cycle pulse.
lol -- indeed.  IIRC some/few/one model(s) have a burst feature so the number of pulses can be controlled.
I knew I had seen/talked about this before, but couldn't find it easily.
I always forget how fast OUT is.  Thanks!
what about
  uint8_t a,b;
  a = PINB;
  b = a & ~_BV(PINB6);
  a = a | _BV(PINB6);
  PINB = a;
  PINB = b;
which generates
    in r24,0x3
    mov r25,r24
    andi r25,lo8(-65)
    ori r24,lo8(64)
    out 0x3,r24
    out 0x3,r25
MattRW wrote:
what about
No.  With your code every 1 that you write to PINx toggles that bit in PORTx.  Close, if you [perhaps] do the last two lines to PORTB.  Yet, it still is fraught with peril ["Here there be dragons"] in the unexplored territory, as a change in one of the PORTB bits in the meantime would be lost.
I believe this is a bug in avr-gcc which is seen as
a feature (I've used it myself).
The compiler knows that the PINF register is located
in the register map at a low address which supports
SBI and CBI instructions, and since you are only
setting a single bit, an SBI instruction is generated.
For a normal register like PORTF or DDRF there is
no issue, but PINF is special.  What the |= should
do if taken literally is output a 1 to every bit position
which reads as one, in addition to setting the specific
bit provided.
The effect would be to toggle the requested pin (if it
is an output) and also turn off every other output in
PORTF, and maybe disable some of the input pull-ups.
This does not happen, though, since the SBI affects
only the one bit/pin.
The problem arises if you try to use the same |= code
on a PINx register which is not located within reach
of the SBI instruction. The compiler has no choice
but to read PINx, OR in the requested bit, and then
write this value back to PINx. If any other bits in
PORTx are outputs, they will be reset to zero.
I think it's safer to always use = with PINx registers
when writing C or C++. The generated code will be
correct for all PINx registers, and there's no speed
penalty. Wastes two bytes of flash, if you're really
tight on program memory, but then you're probably
going to have to write parts in ASM anyway!  ;-)
--Mike
EDIT: mentioned pull-up resistors
I ought to stay out of this...
I find it interesting the concern about knowing the initial state of the pin, before one uses the Pin Toggle capability.
When I've written a bit-banged an SPI,  I2C, USART or LCD interface, etc., and I am about to blast a bunch of data out a pin, (or pins), I have also "wasted" a couple of clock cycles to pre-set the interface signals to their desired condition.
If they were already pre-set correctly, (as is the expected status of the pins), then it wasted a couple clock cycles.
It they, somehow mysteriously, were not how I expected them to be, then they are correctly set up before the data gets sent.
My bit-bang routines then end with the interface signals back in a known and desired state, awaiting their next usage.
I am comfortable using a pin toggle, or explicitly setting and clear the pins in this case.
I would think that if I wanted to generate a single pulse, (LCD driver, laser driver, etc.), I would once again be starting with a known condition for the hardware interface.
If I absolutely wanted to set and clear pins, then I'd take the clock cycle hit and set and clear them, without the toggle.
It kind of reminds me of the days of programming a PC in DOS vs in Windows today.
In the days of DOS I knew exactly what the 8086 was doing, and what the various peripheral interface chips were doing.
My code told them what to do.
These days my PC is running 2500 - 3000 Threads in the background, with 10K handles open, and I have no clue what the processor is actually doing at any point in time.
Fortunately, for my little embedded micro projects, their complexity is such that I still know, or at least I think I know, what the hardware is doing.
Edit: Typo
Reviewing this, it appears that the genesis is really in understanding the word "toggle". In the logic world, it means, roughly, to change a binary value from its current state to the opposite state. You see the term particularly applied to flip-flops as a description of what the device does when a clock edge happens.
I have never encountered a pulse functionality of the kind that alan seems to want, especially involving intervals smaller than 1 clock cycle.
My dream of a single instruction pulse operation is dashed!!!
Ah, finally a use for the 555 chip!
You could use an I/O pin, (Assuming you knew its initial state was low... <smirk> ), to trigger a 555 in one-shot mode.
On a more serious note:
It would be interesting to see if this is doable through the XmegaE5 series' programmable logic module.
And, unfortunately, it will have to go on the list of things to investigate some day, as I can't work on it at the moment.
can you not make a 2/4/6/8/10/12/14/16/18 clock pulse from a USART with a single out instruction?
Oooh, I like that!  Very cool.  It'd be an inverted pulse.
--Mike
Throw a pin high into a grounded inductor and pick off the flyback voltage, and you'll get a pulse a lot shorter than your clock.
Resetting is your problem.  Also not blowing up the AVR while you're at it...  wink
I like 'write PINx' toggle, and get annoyed when I'm using an AVR that doesn't have it.  Saving instructions while writing assembler is always a good thing.  S.
It's a pretty fundamental rule that it has always taken TWO toggles to make a complete "cycle". To quote Scottie "Ye cannae change the laws of physics!".
AVRs should be made from transparent aluminum.
Tell that to Q or to the legislature at Camelot or in the Dancing Gods series (a good read).
For that matter, tell it to Scottie.  He generally got the job done anyway.
All that said, 'tain't a matter of physics, 'tis a matter of mathematics.
Should we just say "one of God's laws" perhaps? cheeky
(sorry - deliberately inflammatory comment!)
Not on every target e.g. t4/5/9/10 and other reduced core tinies it is 1cycle.
I just took a look at the datasheet for tiny214 etc. and that also only say 1 clk
and xmega E manual also say 1clk.
I think it was something they had to fix when there was chips made for USB and probably also other devices, that if status changed (in HW) while you made a SBI (CBI) there could be a error.
Not even Odin can square the circle.
